This ) to create or use a configuration object that contains a set of variables that all steps and applications can use.
What is a Configuration Object?
A configuration object is a stand-alone JSON file that lives on the PowerFlow system. A configuration object supplies the login credentials and other global variables that can be used by all steps and applications in PowerFlow. Configuration objects allow the same application to be deployed in multiple PowerFlow instances, with different configurations.
Configuration objects can map variables from SL1 to a third-party platform. For instance, SL1 has device classes and various third-party platforms have CI classes; the configuration object would map these two variables.
You can create and edit configuration objects on the Configurations page of the PowerFlow user interface. After you create the configuration object, it appears in the Configuration drop-down on the Configuration pane of the Applications page. Before you can run an application, you must select a configuration object and "align" that configuration object with the application.
You can select none from the Configuration drop-down to clear or "un-align" the selected configuration object from an application. Also, if you did not select a configuration object when editing fields on the Configuration pane, the previously set configuration object will remain aligned (if there was a previously set configuration object).
You can include the config. prefix with a variable to tell PowerFlow to use a configuration file to resolve the variable. If you want to re-use the same settings between applications, such as hostname and credentials, define configuration variables.
The Configurations page () displays a list of available configurations. From this page you can create and edit configuration objects:
You can search for a specific configuration object by typing the name of that configuration in the Search field at the top of the Configurations page. The user interface filters the list as you type.
Click the edit icon () to edit an object, or click the delete icon (
) to delete that object.
Click the down arrow icon () for a configuration object to see which applications are currently "aligned" with that configuration object.
When creating or editing a configuration object on the Configurations page, the name-value pairs in the Configuration Data section display in fields by default instead of a block of JSON code.
For more complex configuration objects, you can click Configuration Data section, you can press to search for code. Also, a red warning icon () appears in the first column of the Configuration Data section for a row where the JSON is not valid.
If you set 'null' as a value for a JSON parameter in a configuration object, the value reverts to its default value, if a default value exists. You can clear JSON parameters by specifying an empty dictionary {} as the value. Also, upgrading or downgrading a Synchronization PowerPack will not overwrite a user configuration.
Many Synchronization PowerPacks for PowerFlow contain an "example" configuration object that you can use as a template. You should do a Save As with the example configuration objects so you can make a copy of the example configuration that you can customize for your specific PowerFlow system. Do not use the example configuration objects to run PowerFlow applications.
To create a new configuration object:
From the Configurations page (
), click . The Create Configuration pane appears.
Instead of creating a completely new configuration object, you can also edit an existing configuration object that has some of the configuration data that you want to use and click Configuration pane to create a copy of that configuration object.
from the
- Friendly Name. Name of the configuration object that will display in the user interface.
Configuration Data Values. To add configuration values in the form of name-value pairs, click . Complete the Name and Value fields, and select Encrypted if needed.
Click
to view the JSON configuration data for the configuration object at the bottom of the pane. Click again to return to the original view.
In the Configuration Data section, include the required block of code to ensure that the applications aligned to this configuration object do not fail:
"encrypted": false,
"name": "sl1_db_host",
"value": "${config.sl1_host}"
"encrypted": false,
"value": "10.2.11.42"
Click Configuration Data Values section.
to show the JSON code. Click the button again to see the fields. You can also click and add a new name-value pair in theIf you are using SL1 with an External Database (SL1 Extended architecture or a cloud-based architecture), update the "value" of that block of code to be the host of your database. This field accepts IP addresses. For example: "value": "db.sciencelogic.com". If you are not using the SL1 Extended architecture or a cloud-based architecture, you do not need to make any changes to the block of code other than pasting the code into the configuration object.
- To create a configuration variable, define the following keys:
- Click , or click to save the configuration object as a new configuration object with a different name.
- Align this configuration object with the PowerFlow applications that you want to run by clicking the Configure button from the detail page for each application and selecting this configuration object from the Configuration drop-down.
Editing a Configuration Object
To edit an existing configuration object:
- Go to the Configurations page.
) for the configuration object you want to edit. The Configuration pane appears for that object.
- Edit the values in the following fields as needed:
Click Configuration Data Values section with the button instead.
to view the JSON configuration data for the configuration object at the bottom of the pane. Click again to view the
- If you want to make a copy of this configuration object, click Create Configuration pane. and update the relevant fields in the
- Click to save your changes.
