This appendix contains information about how SL1 and ServiceNow discover and model out different technologies, using VMware as an example. The VMware example explains how the differences between the systems requires rules be configured to bridge the gap between SL1 and ServiceNow.
This appendix includes the following topics:
Overview
In certain cases, SL1 and ServiceNow will not discover model other technologies and applications in the same way. As a result, you might need to configure the class rules to satisfy the Identification and Reconciliation Engine in ServiceNow.
One such example of where SL1 and ServiceNow differ in how they model other devices is when PowerFlow attempts to sync VMware devices from SL1 to ServiceNow. Because of these differences, the required configurations for VMware and a number of other technologies are packaged into an update set provided by SL1. This update set removes any manual effort for users.
However, there are many technologies where SL1 has not yet created an update set. For those situations, the following topics will cover how SL1 and ServiceNow differ, and what configuration steps are required in ServiceNow.
VMware Discovery
For more information about how the Identification and Reconciliation Engine works within ServiceNow, see this ServiceNow Knowledge Base article.
Conflicts
The vCenter Discovery process in ServiceNow creates Configuration Items, but does not send the payload data through Identification Engine. The sensors or probes process the payload and use scripts to insert records.
For more information about this situation, see this ServiceNow Knowledge Base article.
vCenter
The vCenter (cmdb_ci_vcenter) default relationship is to a hardware class table, and by default this relationship is a dependent class. The Identification Rule is derived using the Application Rule.
Conflicts
The instance UUID, which is a more unique field, is not collected. As a result, identification falls to the Name field alone, which is an unreliable source. You can perform the following edits to the name to match what ServiceNow does, although this practice leads to duplicates:
- Set the name of the vCenter to the "vcenter@ip_address" of the device instead of the hostname. You can edit a modification of the name value being sent from SL1 through PowerFlow.
You can use the following Jinja2 template for name mapping:
"{{ 'vcenter@{}'.format(device.ip) if device.snow_ci_class == 'cmdb_ci_vcenter' else device.name }}": [ "name" ],
This name setup has a high chance of causing multiple Device IDs to sync to one ServiceNow Configuration Item.
For more information about Jinja2 templates, see Using a Jinja2 Template.
The order in which SL1 loads data fails to make the specific relationships that ServiceNow populates, because Discovery does not appear to follow rules of the Identification Engine.
Working Solution
To address this situation, complete the following steps:
Replace the identification rule with a rule that applies specifically to a VMware vCenter Instance (cmdb_ci_vcenter):
Add an identifier to the Name field:
Datacenter
DataCenter (cmdb_ci_vcenter_datacenter) is a dependent class, and the identification is derived from the logical Datacenter table (cmdb_ci_logical_datacenter). The Identification rules are listed under Local Datacenter Rule.
Conflicts
The instance UUID (account ID) is not available to be pulled from SL1, and the unique_id field is not a reliable source for identification. As a result, you cannot generate the default relationship to the cloud service account with the values collected.
Working Solution
To enable SL1 to sync VMware vCenter Data Centers, an override dependency is required.
Relationship for vCenter > Datacenter is required:
Hosting Rule Child type cmdb_ci_vcenter
Is reverse true
Parent type cmdb_ci_vcenter_datacenter Relation type (Parent::Child) Managed by::Manages
Folders
VMware Folders (cmdb_ci_vcenter_folder) is a dependent class, with no mapped dependency by default.
Conflict
The ServiceNow Discovery Expected Relationship is different from the default identification of Hosted On.
Hosting Rule | |
Child type | cmdb_ci_vcenter_folder |
Is reverse | true |
Parent type | cmdb_ci_logical_datacenter |
Relation type (Parent::Child) | Contains::Contained by |
Default
Hosting Rule | |
Child type | cmdb_ci_logical_datacenter |
Is reverse | false |
Parent type | cmdb_ci_vcenter_folder |
Relation type (Parent::Child) | Hosted on::Hosts |
Working Solution
To address this situation, use the following override set in PowerFlow to handle the default relationship:
"cmdb_ci_vcenter_folder": { "relations": [ { "parent": "cmdb_ci_vcenter_datacenter", "rel_type": "Hosted on::Hosts", "reverse": true } ], "values": { } }
For more information about setting overrides, see Configuring Customer CI Relation Overrides.
Cluster
VMware vCenter Cluster (cmdb_ci_vcenter_cluster) is a dependent class, and the identification is derived from the Host Cluster (cmdb_ci_host_cluster). The Identification rules are listed under Host Cluster Rule.
Conflicts
The order in which PowerFlow loads data is not compatible with making the specific relationships that ServiceNow populates. This issue occurs because Discovery does not appear to follow the rules of the Identification Engine.
Working Solution
Additional relationships are also listed but not shown below. This data is specific to the identification of the device.
"cmdb_ci_vcenter_cluster": { "relations": [ { "parent": "cmdb_ci_vcenter_datacenter", "rel_type": "Contains::Contained by", "reverse": false } ], "values": { } }
Network
VMware vCenter Network (cmdb_ci_vcenter_network) is a dependent class, and the identification is derived from the Network Rule (cmdb_ci_network). The Identification rules are listed under the Host Cluster Rule.
The derived relationship is a Hosted On relationship type, and the expected relationship would be Contains. You will need to create a new metadata rule to get the expected relationship, if the rule does not already exist.
Conflicts
The default relationship in ServiceNow is Hosted On, and ServiceNow Discovery is expecting a relationship of Contains instead of Hosted. This situation requires a change to the Dependent Relationships:
The relationship for VMware vCenter Network > VMware vCenter Datacenter is required.
Hosting Rule Child type cmdb_ci_vcenter_network Is reverse true Parent type cmdb_ci_vcenter_datacenter Relation type (Parent::Child) Contains::Contained by -
Working Solution
"cmdb_ci_vcenter_network": { "relations": [ { "parent": "cmdb_ci_vcenter_datacenter", "rel_type": "Hosted on::Hosts", "reverse": true } ], "values": { } }
Switch
VMware Distributed Virtual Switch (cmdb_ci_vcenter_dvs) is a dependent class, and the identification is derived from the Cloud Network (cmdb_ci_network). The Identification rules are listed under Network Rule.
Conflicts
The derived relationship is a Hosted On relationship type, and the expected relationship would be Contains for ServiceNow Discovery. You will need to create a new metadata rule to get the expected relationship, if the rule does not already exist.
Hosting Rule Child type cmdb_ci_vcenter_dvs Is reverse true Parent type cmdb_ci_vcenter_datacenter Relation type (Parent::Child) Contains::Contained by -
Working Solution
"cmdb_ci_vcenter_dvs": { "relations": [ { "parent": "cmdb_ci_vcenter_datacenter", "rel_type": "Hosted on::Hosts", "reverse": true } ], "values": { } }
Virtual Port Group
VMware Distributed Virtual Port Group (cmdb_ci_vcenter_dv_port_group) is a dependent class and the identification is derived from the Port Group (cmdb_ci_port_group). The Identification rules are listed under Port Group Rule.
Conflicts
The relationship for VVMware Distributed Virtual Port Group > VMware vCenter Datacenter is required.
Hosting Rule Child type cmdb_ci_vcenter_dv_port_group Is reverse true Parent type cmdb_ci_vcenter_datacenter Relation type (Parent::Child) Contains::Contained by -
Working Solution
"cmdb_ci_vcenter_dv_port_group": { "relations": [ { "parent": "cmdb_ci_vcenter_datacenter", "rel_type": "Hosted on::Hosts", "reverse": true } ], "values": { } }
ESX Server
VMware vCenter Network (cmdb_ci_esx_server) is an independent class, and the Identification rules are listed under ESX Server Rule.
Conflicts
Because no GUID is being collected, the Identification attributes need to be updated. The ability to correlate values in both systems to identify might case issues with some integrations.
Working Solution
Add an Identifier Entry to the ESX Server rule in addition to the current Correlation ID entry:
ESX Resource Pool
ESX Resource Pool (cmdb_ci_esx_server) is a dependent class, and the identification is derived from the VM Object (cmdb_ci_vcenter_object). The Identification rules are listed under Port Group Rule.
Conflicts
No derived relationship or any relationship type is defined within ServiceNow by default (ServiceNow Base + Discovery). You will need to create a new metadata rule to get the expected relationship, if the rule does not already exist.
No DCM+R relationships exist on vCenter Resource Pools, which causes issues when trying to create matching relations from that ServiceNow Discovery.
Working Solution
"cmdb_ci_esx_resource_pool": { "relations": [ { "parent": "cmdb_ci_esx_server", "rel_type": "Defines resources for::Gets resources from", "reverse": true } ], "values": { } }
Datastore
VMware vCenter Datastore (cmdb_ci_vcenter_datastore) is a dependent class, and the identification is derived from the VM Object (cmdb_ci_vm_object). The Identification rules are listed under VM Object.
Default Identification:
Object ID
Name
Correlation ID
Conflicts
Identification by defaulting to name does not appear to be unique enough, and it results in false matching. You will need to change the priority identification.
The relationship that ServiceNow Discovery sends does not line up with the defined dependent relationships.
Working Solution
To address this situation:
Use the following override set in PowerFlow to handle the default relationship:
"cmdb_ci_vcenter_datastore": { "relations": [ { "parent": "cmdb_ci_vcenter_datacenter", "rel_type": "Contains::Contained by", "reverse": false } ], "values": { } }
Add an Identifier Entry to the VM Object Rule in addition to the current entries:
Object ID
Name
Correlation ID
Virtual Machine Instance
VMware Virtual Machine Instance (cmdb_ci_vmware_instance) is a dependent class, and the identification is derived from the Virtual Machine Instance (cmdb_ci_vm_instance). The Identification rules are listed under VM Instance.
Conflicts
The VC-VM Iinstance UUID, which is a more unique field, is not collected. As a result, identification falls to the Name field alone, which is an unreliable source.
The relationship that ServiceNow Discovery sends does not line up with the defined dependent relationships. The default relationship Hosted On or Runs for dependency, but the relationships that Discovery updates do not line up.
Working Solution
"cmdb_ci_vmware_instance": { "relations": [ { "parent": "cmdb_ci_vcenter_datacenter", "rel_type": "Hosted on::Hosts", "reverse": true } ], "values": { } }
