ServiceNow Cases Synchronization PowerPack
You should not use the ServiceNow Cases Synchronization PowerPack and the ServiceNow Events Synchronization PowerPack on the same PowerFlow system. Also, do not use the Cases and Incident Synchronization PowerPacks on the same PowerFlow system.
With this Synchronization PowerPack, any changes (except for acknowledgments) made to an SL1 Event is sent to ServiceNow to update the corresponding Case. Any status changes to the ServiceNow Case are synced back to the corresponding SL1 Event.
You can also use this Synchronization PowerPack in conjunction with the ServiceNow Configuration Management Database (CMDB) Synchronization PowerPack to create cases with a linked ServiceNow Configuration Item (CI).
The following topics are covered in this manual:
