Configuration and Credentials
The following sections describe how to configure Dell EMC Isilon storage arrays for monitoring by SL1 using the Dell EMC: Isilon PowerPack:
Prerequisites for Monitoring Dell EMC Isilon
To configure the SL1 system to monitor Dell EMC Isilon storage arrays using the Dell EMC: Isilon PowerPack, you must have already installed and configured the storage arrays that you want to monitor.
If you are using a Secure Sockets Layer (SSL) certificate to communicate with the Isilon storage arrays you are monitoring, you must add an Isilon SSL certificate on your SL1 appliance in the following file:
/var/lib/em7/content/silo_core_rest/certs.crt
If you are not using an SSL certificate to communicate with the Isilon storage arrays, then you do not need to add a certificate. For more information about installing an SSL certificate, see
Additionally, you should take note of the SNMP community string used by the Isilon storage arrays you want to monitor.
Creating a SOAP/XML Credential for Dell EMC Isilon
To configure SL1 to monitor Dell EMC Isilon storage arrays, you must first create a credential that allows the Dynamic Applications in the Dell EMC: Isilon PowerPack to communicate with your Isilon storage devices. The PowerPack includes an example SOAP/XML credential that you can edit for your own use.
To configure the SOAP/XML credential to access Dell EMC Isilon devices:
- Locate the Dell EMC: Isilon SOAP Example credential, and then click its wrench icon (). The Edit SOAP/XML Credential modal page appears.
- Update the values in the following fields:
Basic Settings
- Profile Name. Type a new name for the credential.
- HTTP Auth User. Type the Isilon administrator username.
- HTTP Auth Password. Type the Isilon administrator password.
SOAP Options
- Embed Value [%1]. Do one of the following:
- Type "True" to enable verification of the storage array's SSL certificate.
- Type "False" or leave this field blank to disable SSL verification.
This field is not case-sensitive.
Creating an SNMP Credential for Dell EMC Isilon
In addition to the SOAP/XML credential, you will also need to configure an SNMP credential to enable SL1 to monitor Dell EMC Isilon storage arrays. The Dell EMC: Isilon PowerPack includes an example SNMP credential that you can edit for your own use.
To configure the SNMP credential to access Dell EMC Isilon devices:
- Locate the Dell EMC: Isilon SNMPv2 Example credential, and then click its wrench icon (). The Edit SNMP Credential modal page appears.
Basic Settings
SNMP V1/V2 Settings
- SNMP Community (Read-Only). Type the Isilon storage array's SNMP community string.
