Versions 105 and earlier of this PowerPack were named the ScienceLogic: Integration Service PowerPack.
The following topics provide an overview of the ScienceLogic: PowerFlow PowerPack:
What Does this PowerPack Monitor?
This PowerPack lets you configure SL1 to create an alert if an SL1 PowerFlow application fails.
The ScienceLogic: PowerFlow PowerPack includes the following features:
- The "REST: Performance Metrics Monitor (PowerFlow)" Dynamic Application, which monitors outgoing REST requests from SL1 to PowerFlow
- The "ScienceLogic: PowerFlow Healthcheck Configuration" Dynamic Application includes an Event Policy that generates a Major event when the state returned by the healthcheck action is "not okay" or "not skipped". This Dynamic Application runs every six hours by default and it does not work for single-node PowerFlow systems
- The "ScienceLogic: PowerFlow Queue Configuration" Dynamic Application, which monitors the status of the PowerFlow RabbitMQ service
- The "ScienceLogic: PowerFlow Workers Configuration" Dynamic Application, which monitors the status of the PowerFlow RabbitMQ workers
- Event Policies and corresponding alerts that are triggered when an application in PowerFlow fails
- A Device Class and a Device Template for PowerFlow
- Sample SOAP/XML and SSH/Key Credentials for connecting to PowerFlow
Installing the PowerPack
Before completing the steps in this section, you must import and install the latest version of the ScienceLogic: PowerFlow PowerPack.
- In the PowerPack Manager page, click the button, then select Import PowerPack.
