SL1 allows you to generate reports based on organizations. You can generate two types of reports about organizations:
- A report with overview information on multiple organizations in SL1.
- A report with detailed information on a single organization.
Generating a Report on Multiple Organizations in SL1
The Organizational Account Administration page (Registry > Accounts > Organizations). From the Organizational Account Administration page you can generate an Excel report that contains all the information in the Organizational Account Administration page, plus some additional information from the Organization Properties page for each organization.
tab includes the
To generate a report on all or multiple organizations in SL1:
Go to the Organizational Account Administration page (Registry > Accounts > Organizations).
On the Organizational Account Administration page, click the button. The Export current view as a report modal page appears:
NOTE: If you want to include only certain organizations in the report, use the "search as you type" fields at the top of each column. You can filter the list by one or more column headings. You can then click the button, and only the organizations displayed in the Organizational Account Administration page will appear in the report.
- In the Export current view as a report page, you must select the format in which SL1 will generate the report. Your choices are:
- Web page (.html)
- Open Document Spreadsheet (.ods)
- Excel spreadsheet (.xlsx)
- Acrobat document (.pdf)
- Click the Organizational Account Administration page. You can immediately view the report or save it to a file for later viewing. button. The report will contain all the information displayed in the
For each organization in SL1, this report displays:
- Organization ID
- Organization Name
- Address
- City
- State / Province
- Postal Code
- Country
- Contact's Last Name
- Contact's First Name
- Phone
- Fax
- Contact's Title
- Contact's Department
- Billing ID
- CRM ID
- Toll Free
- Number of User Accounts
- Number of Devices
- Number of Assets Records
- Number of Network Interfaces
- Date and Time of Last Edit
Detailed Report About a Single Organization
SL1 can generate a custom report about a single organization. You can specify the level or detail to include in the report and the output format for the report.
To generate a detailed report about a single organization:
- In the Organizational Account Administration page, find the organization you want to generate a report about.
- Click its printer icon (). The Report Creator modal page appears. The Report Creator modal page allows you to generate an organization report. From the Report Creator modal page, you can specify which information to include in the report and the format in which the report will be generated.
- You can select from the following list of formats in which the report can be generated:
- Create Report as HTML Document
- Create Report as PDF Document
- Create Report as Open Document Spreadsheet
- Create Report as MS Excel Document
- You can select one of the following to specify the information to include in the report:
- Organization Properties page plus any product SKUs associated with the organization and all notes and attachments for the organization, as displayed in the Organizational Notes page. . Displays all the contact information (address, phone numbers, email, contact person) from the
- Organization Properties page. . Displays all the contact information (address, phone numbers, email, contact person) plus any critical contact persons from the
- Organization Properties page. . Displays only the address and contact information in the
- Organization Properties page. . Displays all notes and attachments for the organization from the
- Organization Properties page. . Displays a list of all user accounts in the organization from the
- Organization Properties page. . Displays a list of product SKUs associated with the organization from the
- When you select the information to include the report, SL1 will generate the report. You can immediately view the report or save it to a file for later viewing.
See Also
