You should not use the ServiceNow Cases Synchronization PowerPack and the ServiceNow Events Synchronization PowerPack on the same PowerFlow system. Also, do not use the Cases and Incident Synchronization PowerPacks on the same PowerFlow system.
With this Synchronization PowerPack, any changes (except for acknowledgments) made to an SL1 Event is sent to ServiceNow to update the corresponding Case. Any status changes to the ServiceNow Case are synced back to the corresponding SL1 Event.
You can also use this Synchronization PowerPack in conjunction with the ServiceNow Configuration Management Database (CMDB) Synchronization PowerPack to create cases with a linked ServiceNow Configuration Item (CI).
The label "SyncPack" is used in place of "Synchronization PowerPack" in the PowerFlow user interface.
The following video explains how automated Case management in SL1 helps resolve issues quicker:
Architecture Overview for ServiceNow Synchronization PowerPacks
The following diagram details the various elements that are contained in SL1 and the PowerFlow system, and how PowerFlow sits between the core SL1 platform and an external data platform:
SL1 | ServiceNow |
Asset, Custom Attribute |
Asset (ITAM) |
Device |
CI (Configuration Item) |
Discovery Session |
Event |
Incident, Event, or Case (depending on the Synchronization PowerPack you are using) |
Alert |
Event |
Organization |
Company, Domain |
Dependency Map for ServiceNow Synchronization PowerPacks
The following graphic describes which Synchronization PowerPacks depend on other Synchronization PowerPacks:
For more information about the Standard Base Steps Synchronization PowerPack, see Default Synchronization PowerPacks.
Prerequisites for ServiceNow Synchronization PowerPacks
This section describes the prerequisites for the ServiceNow Synchronization PowerPacks. For more information about the specific software versions required by a ServiceNow Synchronization PowerPack, see the release notes for that Synchronization PowerPack.
To install any of the ScienceLogic ServiceNow Synchronization PowerPacks, you must have administrator access to both SL1 and ServiceNow. Specifically, you will need:
Contents of the Synchronization PowerPack
This section lists the contents of the ServiceNow Cases Synchronization PowerPack.
PowerFlow Applications
The following PowerFlow applications are included with the ServiceNow CasesSynchronization PowerPack:
- Create or Update ServiceNow Case from SL1 Event. From a new or existing SL1 Event, transforms SL1 Event data into a new or existing ServiceNow Case and then posts the Event details to ServiceNow.
- Resolve ServiceNow Case from SL1 Event. Resolves a ServiceNow Case when an SL1 Event is cleared.
- Sync Case or Incident State from ServiceNow to SL1 Event. Clears or updates SL1 Events when the related ServiceNow Case or Incident is updated.
Steps
The following step is included with the Synchronization PowerPack:
Process Cases and Incidents
