Debugging Reports
This section describes the logging options that are available to report and widget developers. Logging can be enabled on any appliance that provides the user interface (Administration Portals, Database Servers, and All-In-One Appliances). When logging is enabled on an appliance:
  • As a user navigates the user interface on that appliance, the ScienceLogic user interface code will write messages to the user interface log file.
  • When reports are generated on the appliance, reports that are configured to log messages will write to the user interface log file.
  • When widgets are loaded in the user interface of the appliance, widgets that are configured to log messages will write to the user interface log file.
Log rotation is not enabled on the log files described in this chapter. The log files described in this chapter can cause the file system to become full if they remain enabled for a long period of time. Do not leave the log files described in this chapter enabled unless you are actively debugging a problem with the user interface, a report, or a widget.
Controlling Log Settings
This page is is only available for Administrator-level users in SL1.
  • 1. Critical
  • 2. Error
  • 4. Warning
  • 8. Info
  • 16. Debug
  • 32. Trace
  • Error
  • Warning
  • Info (non-error)
  • Suppression List. This list acts as a bitmask to log entries. For example, to suppress all entries for css-em7, you would enter "css.em7::127", where 127 is the sum of all possible log levels. You can specify multiple suppressions in the list, separated by commas.
  • Datetime Format. Specifies a user-defined date format that will be used for5 system logs. You can use any date variables supported by the PHP date function in this field.
  • Include IP in log filenames. Select this option to add the IP address from which the user is logged in to the name of each log file.
The following video explains a new method for accessing user interface logs:
Writing to the Log File
PHP code for reports and widgets can write messages to the log file by using one of the following functions. Although these functions can be called at any time, messages will be written to the log file only if logging is configured with a log level that includes the message type created by the function. Each function takes one parameter, a message string (denoted by $msg) to be written to the log file:
  • To write a log message of type "Critical", use the following function:
  • devlog::crit($msg);
  • To write a log message of type "Error", use the following function:
  • devlog::err($msg);
  • To write a log message of type "Warning", use the following function:
  • devlog::warn($msg);
  • To write a log message of type "Info", use the following function:
  • devlog::inf($msg);
  • To write a log message of type "Debug", use the following function:
  • devlog::dbg($msg);
