This chapter describes how to manage ScienceLogic Libraries in SL1.
Viewing the List of ScienceLogic Libraries
The ScienceLogic Library Manager page (System > Customize > ScienceLogic Libraries) lets you view a list of all of the ScienceLogic Libraries available for use and download those libraries for your own use. From this page, you can also import new libraries, delete existing libraries, or view and edit a list of Execution Environments that you can then associate with a library.
For each library, the page displays the following information:
To sort the list of ScienceLogic Libraries, click on a column heading. The list will be sorted by the column value, in ascending order. To sort by descending order, click the column heading again. The Last Edited column sorts by descending order on the first click; to sort by ascending order, click the column heading again.
- Library Name. The name of the ScienceLogic Library.
- Version. The version number of the ScienceLogic Library.
- System. Displays True if the ScienceLogic Library is included in the latest release of SL1 and is aligned with the "System" environment. Displays False if the ScienceLogic Library is included in an imported PowerPack or manually installed by an administrator.
- Type. The file type used to bundle and deliver the ScienceLogic Library. Supported types include the following:
- py_directory (.tar format). A py_directory is a tar file that includes Python files and is typically used by novice developers to share short code snippets between Dynamic Applications or SL1 stacks. This format does not let you manage dependencies, version, test, and so on, and is not recommended.
- py_package (.tar format). A py_package is a tar file that contains Python packages and metadata files (name, version, description, etc.). The py_package format is typically used by more experienced developers to build complex solutions. ScienceLogic recommends using the py_package format because it is easier to test and maintain.
- Dependencies. Developer notes about library dependencies for this library. This field supports a comma-separated list of other ScienceLogic Libraries on which the selected library is dependent, if applicable. These additional libraries are included in the selected library's py_package.tar file.
- Description. A single-line description of the ScienceLogic Library's intended use.
- Python Version. The Python compatibility version.
- Edited By. The name of the ScienceLogic user who created or last edited the ScienceLogic Library.
- Last Edited. The date and time the ScienceLogic Library was created or last edited.
Searching and Filtering the List of ScienceLogic Libraries
By default, the cursor is placed in the first Filter-While-You-Type field. You can use the <Tab> key or your mouse to move your cursor through the fields.
- Library Name. You can enter text to match, including special characters, and the ScienceLogic Library Manager page will display only ScienceLogic Libraries that have a matching name.
- Version. You can enter text to match, including special characters and the ScienceLogic Library Manager page will display only ScienceLogic Libraries that have a matching version number.
- System. You can enter text to match, including special characters and the ScienceLogic Library Manager page will display only ScienceLogic Libraries that have a matching System value.
- Type. You can enter text to match, including special characters and the ScienceLogic Library Manager page will display only ScienceLogic Libraries that have a matching Type value.
- Dependencies. You can enter text to match, including special characters and the ScienceLogic Library Manager page will display only ScienceLogic Libraries that have matching dependencies.
- Description. You can enter text to match, including special characters and the ScienceLogic Library Manager page will display only ScienceLogic Libraries that have matching descriptions.
- Python Version. You can enter text to match, including special characters and the ScienceLogic Library Manager page will display only ScienceLogic Libraries that have matching versions.
- Edited By. You can enter text to match, including special characters and the ScienceLogic Library Manager page will display only ScienceLogic Libraries that were created or last edited by a matching username.
- Last Edited. You can select from a list of time periods, and the ScienceLogic Library Manager page will display only ScienceLogic Libraries that have been created or edited within that time period.
Special Characters
String and Numeric
String
"!^" would match null values.
"!$" would match null values.
Numeric
Examples
- "*". Matches all text.
Downloading a ScienceLogic Library
From the ScienceLogic Library Manager page, you can download ScienceLogic Libraries for your own use.
ScienceLogic-authored libraries are copyrighted content and should not be modified without the express permission of ScienceLogic.
Libraries that are included in SL1 are bundled in either a py_package or a py_directory format.
To download a ScienceLogic Library:
- Go to the ScienceLogic Library Manager page (System > Customize > ScienceLogic Libraries).
- Click the save icon () of the ScienceLogic Library you want to download.
- The library file is downloaded to your computer.
Importing a ScienceLogic Library
In addition to the ScienceLogic Libraries that are included in the latest version of SL1 or included in a PowerPack, you can use the ScienceLogic Library Manager page to import additional libraries for your own use.
To import a library:
- Click the Import ScienceLogic Library. menu and then select
- The Import ScienceLogic Library dialog box appears. Use the button to navigate to the ScienceLogic Library file you want to import and then click the button.
- The imported ScienceLogic Library appears on the ScienceLogic Library Manager page.
Creating a ScienceLogic Library
You can create your own library to import into SL1 in either a py_directory or py_package library file saved in uncompressed .tar format. This section describes the requirements for a ScienceLogic compatible library.
Important Notes on Creating ScienceLogic Libraries
The following are important items to note when creating a ScienceLogic library:
- Library files must be saved in uncompressed .tar format.
- For best results, use GNU tar rather than bsdtar.
- For a py_directory library, the library name comes from the name of the directory that you saved.
- You can only include wheel files (.whl) as additional dependencies. You cannot include any additional packages in your library file that require compilation or linking because Python build tools are not included in the SL1 platform.
Any libraries that are bundled as dependencies in your py_package file will not be used if a newer version of that library exists on the appliance unless you have a restriction in your package specifying a given version to use.
For example, if your library "my-library" requires the Python community package "requests" version 2.25.1, you would create the library "requests" version "2.25.1" first. You would then import the requests library into SL1 and align it and "my-library" to your Execution Environment. At runtime, both libraries, at those specific versions, will be used.
For an alternative example, if your library "my-library" requires the Python community package "requests", but the version is not important, you would include the "requests" package as a "whl" file in your "my-library" library, adding it to the "manifest.txt" file. After aligning "my-library" to your Execution Environment, it will be available at runtime. The "requests" package included in the "manifest.txt" will be available during the install of "my-library", but may not be used if a newer acceptable package is found for install.
- For a py_package library, an optional "metadata.json" file can be included but it must include the requires_python element otherwise an error will be displayed upon import.
A best practice is to version your libraries. Each time you make modifications to a library, create a new version and a new execution environment that uses that version. In that way, you can use different versions in different Dynamic Applications for testing purposes, for example.
Library File Type: py_package
The py_package file type is the preferred library file type used to bundle Python packages and metadata files. A py_package must have the metadata files described below along with the wheel file(s) and must be saved in uncompressed .tar format. You must create this tar file with Red Hat Enterprise Linux or a similar operating system to ensure compatibility. Tar files created on MacOS are not supported.
All metadata files included in the package must be at the root level of the directory.
A py_package tar file must include the following files:
- __init__.py. This file is required for the directory to be used as a Python package. It identifies this as a package.
- name.txt. This text file specifies the name of the library and must match the name of the package being installed.
- version.txt. This text file specifies the version of the library and must match the version of the package being installed.
- type.txt. This text file specifies that the library is a py_package type library.
- manifest.txt. This text file includes the Python package name and version (as specified in the name.txt and version.txt files), followed by a list of additional supporting files that must be deployed to the internal package repository to use the library. For example, if the library is dependent on another package, that other package must be listed in the manifest file.
- Wheel (.whl) file. This is a standard wheel file that you create. See Python documentation for more information about creating wheel files. Wheel files must be Python 2 or Python 2/3 compatible and must be created in Red Hat Enterprise Linux or a similar operating system. You may include multiple wheel files in the py_package.
The package name of the library must be the first entry in the manifest file.
Library File Type: py_directory
The py_directory file type is used to share short code snippets, for example, between Dynamic Applications or SL1 stacks. Files must be organized in a directory. You must then save the directory in uncompressed .tar format in Red Hat Enterprise Linux or a similar operating system. Tar files created in MacOS are not supported.
The name of the library comes from the name of the directory.
A py_directory tar file can include the following files:
- __init__.py. This file is required for the directory to be imported as a Python package.
- version.txt. This text file contains a version string specifying the version of the library.
- dependencies.txt. This text file includes a comma-separated list of other libraries on which the library is dependent.
- description.txt. This text file includes a single-line description of the library's intended use.
- Python bytecode (.pyc) files or other source files. These are the additional relevant files that you might want to include in the library.
Deleting a ScienceLogic Library
The ScienceLogic Library Manager page allows you to delete ScienceLogic Libraries that are not currently in use.
SL1 will not allow you to delete ScienceLogic Libraries that are aligned to execution environments that are being used by any Dynamic Applications, credential tests, or Run Book Actions. You also cannot delete libraries that are aligned to the "System" environment.
To delete a library:
- Select the ScienceLogic Library that you want to delete.
- Click the Select Actions menu in the lower right of the page and select DELETE ScienceLogic Library, and then click the button.
- The selected ScienceLogic Library is deleted from the ScienceLogic Library Manager page.
