Creating a Credential
To use the automation actions in the PowerPack to collect data from a device, you must create an SSH or Telnet credential that includes the username and password for that device.
The automation actions in the PowerPack do not support SSH key-based authentication or non-standard SSH or Telnet ports. You must use the Basic/Snippet credential type when creating credentials for the Datacenter Advanced Enrichment Actions PowerPack.
To create a credential:
- Click Create Basic/Snippet credential. The Create New Basic/Snippet Credential page appears. and select
- Credential Name. Enter a name for the credential.
- Hostname/IP. Enter "%D" in this field.
- Port. To use SSH to connect to the device, enter "22" in this field. To use Telnet, enter "23" in this field.
- Timeout(ms). Enter a timeout, in milliseconds, for the connection.
- Username. Enter the username for a user that can login to the device using SSH or telent connect and execute diagnostic commands.
- Password. Enter the password for the user you entered in the Username field.
Aligning Credentials to Devices
The Datacenter Advanced Enrichment Actions PowerPack includes the "Automation Remote Login" Dynamic Application. When the "Enrichment: Util: Collect Enrichment Data" action executes, it uses the credential associated with the "Automation Remote Login" Dynamic Application for the device associated with the triggering event. The following sections describe how to align the "Automation Remote Login" Dynamic Application to devices using the credentials that you created.
For automation actions that are designed to trigger for events associated with component devices (e.g. the automation actions for Cisco UCS components), this configuration must be performed on the root device. The "Automation Remote Login" Dynamic Application does not need to be associated with the component device(s).
During discovery, you might see a significant number of connections made to network devices, as all Dynamic Applications that accept the Basic/Snippet credential type are tested against the specified devices. This might include testing Dynamic Application types that are not appropriate for network devices. Consider aligning Dynamic Applications and credentials using a device template. For more information, see Aligning a Credential Using a Device TemplateAligning a Credential Using a Device Template.
Aligning a Credential Manually to a Device
To manually align the "Automation Remote Login" Dynamic Application and credential to a device, perform the following steps:
- Click the wrench icon (
) for the device. The Device Administration panel appears.
- Click the Dynamic Application Collections page appears. tab. The
- Click the Add Dynamic Application. The Dynamic Application Alignment modal page appears. button and select
- In the Dynamic Applications field, select Automation Remote Login. In the Credentials field, select the credential you created in the previous section.
You can use a device template to align the "Automation Remote Login" Dynamic Application with a specified credential during discovery. This is useful when you want to limit the tests against certain devices (such as network devices) during discovery.
To align the "Automation Remote Login" Dynamic Application and credential using a device template:
Create the credential you want to align to the devices. In this example, we will create a Cisco IOS-XR Telnet credential.
You will do this for each credential you want to apply for the Dynamic Application.
- Select Create Basic/Snippet Credential. and then choose
- Credential Name. Specify a unique name for this credential with any combination of alphanumeric characters.
- Hostname/IP. You can specify a particular device or use a variable, such as %D.
- Port. Specify the port to use when logging in to the device.
- Timeout(ms). Specify a timeout value, in milliseconds, after which SL1 will stop trying to communicate with the device.
- Username. Specify the username for the user account you will use to log in to the device.
- Password. Specify the password for the user account you identified in the previous field.
Click
. - Create a device template that aligns the "Automation Remote Login" Dynamic Application, which includes the new credential.
- Go to the Configuration Templates page (Devices > Templates).
- Click Device Template Editor opens. . The
- Enter a Template Name in the field provided.
- Click the Dyn Apps tab.
- In the "Subtemplate Selections" pane, click Add New Dynamic App Sub-Template.
- Select "Automation Remote Login" as the Dynamic Application.
Select the Credential you created in the previous step. Continuing our example, we will select "Cisco IOS-XR Telnet".
- Specify the device template for discovery.
Aligning Credentials Automatically During Discovery
The "Automation Remote Login" Dynamic Application includes a discovery object that you can use to automatically align the Dynamic Application to devices during discovery. To configure a discovery session to automatically align the "Automation Remote Login" Dynamic Application, select the credential you created in the previous section in the Other Credentials field in the Discovery Session Editor.
