Preparing Hardware Appliances for SL1
This section describes how to prepare hardware appliances before installing SL1.
Hardware Specifications
For details about supported ScienceLogic Hardware Appliances, see the ScienceLogic Support Site. https://support.sciencelogic.com/s/system-requirements?tabset-e65a2=2
Prerequisites for SL1 Hardware Appliances
Perform the following steps to prepare an SL1 appliance for configuration:
  • Install the SL1 appliance in a server rack and connect the power cables according to the instructions provided with the hardware.
  • Connect the SL1 appliance to your network.
  • Connect a monitor and keyboard to the SL1 appliance.
Initial Configuration for SL1 Hardware Appliances
You must perform the following tasks during initial configuration of an SL1 hardware appliance shipped by ScienceLogic:
  • Change the password for the administrative user em7admin.
  • Change the primary IP address of the appliance. You must have already allocated IP addresses for the SL1 appliances.
  • Change the netmask for the primary IP address of the appliance.
  • Change the IP address for the network gateway.
  • Change the IP address for the primary Nameserver.
Changing the Password for em7admin
  2. Log in as user em7admin with the appropriate password. The default password is em7admin.
  3. At the shell prompt, type the following:
    passwd
  4. When prompted, type and re-type the new password.
Changing Network Settings
To change the IP address, Netmask, Gateway address, and DNS Server for an appliance in the ifconfig file:
  2. Login as user em7admin with the appropriate password.
  3. Enter the following at the command line:
sudo ifconfig
  1. Your output will look like this:
ens32: flags=4163<UP,BROADCAST,RUNNING,MULTICAST> mtu 1500
inet 10.64.68.20 netmask 255.255.255.0 broadcast 10.64.68.255
inet6 fe80::250:56ff:fe84:455f prefixlen 64 scopeid 0x20<link>
ether 00:50:56:84:45:5f txqueuelen 1000 (Ethernet)
RX packets 1774927 bytes 161985469 (154.4 MiB)
RX errors 0 dropped 861 overruns 0 frame 0
TX packets 1586042 bytes 158898786 (151.5 MiB)
TX errors 0 dropped 0 overruns 0 carrier 0 collisions 0
lo: flags=73<UP,LOOPBACK,RUNNING> mtu 65536
inet 127.0.0.1 netmask 255.0.0.0
inet6 ::1 prefixlen 128 scopeid 0x10<host>
loop txqueuelen 0 (Local Loopback)
RX packets 13406577 bytes 4201274223 (3.9 GiB)
RX errors 0 dropped 0 overruns 0 frame 0
TX packets 13406577 bytes 4201274223 (3.9 GiB)
  1. Examine the output, find the first interface in the output, and note its name.
  1. Use the vi editor to edit the settings for the interface. To do this, enter the following at the command line:
sudo vi /etc/sysconfig/network-scripts/ifcfg-interface name you noted in step #4
For example, from our output, we could enter:
sudo vi /etc/sysconfig/network-scripts/ifcfg-ens32
TYPE=Ethernet
BOOTPROTO=none
DNS1=10.64.20.33
DEFROUTE=yes
IPV4_FAILURE_FATAL=no
IPV6INIT=yes
IPV6_AUTOCONF=yes
IPV6_DEFROUTE=yes
IPV6_FAILURE_FATAL=no
NAME=ens32
UUID=d471435d-9adf-47c9-b3f3-32f61dccbad8
DEVICE=ens32
ONBOOT=yes
IPADDR=10.64.68.20
PREFIX=24
GATEWAY=10.64.68.1
IPV6_PEERDNS=yes
IPV6_PEERROUTES=yes
  1. You can edit one or more of the following settings:
  • DNS1=IP address of the DNS server that will be used by the SL1 appliance.
  • IPADDR=IP address of the SL1 appliance.
  • PREFIX=netmask for the SL1 appliance.
  • GATEWAY=IP address of the network gateway that will be used by the SL1 appliance.
  1. Save your changes and exit the file (:wq)
  2. At the command line, enter the following:
sudo service network restart
Ports for SL1 Hardware Appliances
See the section on ports to configure firewalls to allow traffic to and from the SL1 appliances.
