Using the Devices Page
The Devices page allows you to view all of your managed devices in SL1 and also run a discovery to find more devices to monitor. You can select a device from the list on the Devices page to view detailed data on the Device Investigator page for that device.
The list of devices on the Devices page matches the list of devices on the Device Manager page (Devices > Device Manager).
Viewing Devices
The Devices page allows you to view all of your managed devices in SL1. This section explains how to gather more information about a device from this page.
To navigate to the Devices page, click the Devices icon ():
The Devices page
For each device, the Devices page displays the following information:
  • IP Address. The device's IP address.
  • Category. The category assigned to the device. Categories include servers, routers, switches, firewalls, and printers, among others. The category is automatically assigned during discovery, at the same time as the as Device Class. For more information about Device Categories, see the section on Managing Device Classes and Device Categories.
  • Class. The manufacturer and type of device. The Device Class is automatically assigned during discovery, at the same time as the Category.
  • ID. The Device ID. This is a unique number that SL1 automatically assigns to the device during discovery.
  • State. The current condition of the device, based upon events generated by the device. The device can have one of the following States:
  • Hostname. The fully qualified hostname for the device, for devices that are discovered and managed by hostname (instead of IP address). This column does not appear by default, but you can add it by clicking Grid Settings > Column Preferences.
Viewing Additional Data about a Device
On the Events page and the Devices page, you can click the Expand icon () next to an event or device to open a new Device Summary modal:
The Device Summary window for a device
  • The Tools pane enables you to run a set of diagnostic tools or user-initiated actions in the Activity Center, or to click on custom links that will open in a separate browser window. Click the search bar to search for tools, actions, or custom links that are available for the device.
  • The Vitals pane displays graph data for the past four hours of CPU usage, memory usage, and latency for that device, where relevant. You can zoom in on a shorter time frame in the Vitals graph by clicking and dragging, and you can go back to the original time span by clicking the Reset zoom button.
Favorite Devices
In SL1, you can select one or more devices so that they always display at the top of the list on the Devices page. This process is called favoriting devices or favorite device.
To make a device a favorite, click the Favorite Dashboard star icon () to add the devices to your favorites list. Click the icon () again to remove the favorite status.
With favorite devices, you can:
  • View your favorite devices at the top of the Devices page by default.
  • Filter devices by favorite.
Aligning a Device with a Different Organization
To align a device with a different organization:
  1. On the Devices page, click the Actions button () for the device and select Align Organization. The Align to Organization window appears.
    To align more than one device to an organization, select the checkboxes to the left of those devices and click the Align Organization button.
  2. In the Align to Organization window, use the Organization drop-down to search for and select an organization.
  3. Click the Align Organization button. The organization you selected now appears in that Info drop-down on the Device Investigator page for that device.
Adding Devices with Discovery
On the Devices page, you can click the Add Devices button to run a guided or unguided network discovery session, a process that searches for and adds more devices to SL1 for monitoring.
For more information about adding devices using guided or unguided discovery, see the section on Discovering Devices.
Assigning Icons to Devices
  2. Click the Actions button () for that item and select Assign Icon. The Select an Icon window appears:
  3. To use an existing icon, select that icon from the list of icons and click the Select Icon button.
  4. To upload an icon from your local drive, make sure that the image file meets the following criteria:
  2. In the Icon name field, type a name for the icon you want to upload.
  3. In the Add Tags field, type a short descriptor for the icon, without spaces. You can use this tag for searching later.
  4. You can click the Browse or Drop area to browse for and select the icon, or you can drag and drop the icon file onto the Add an Icon window.
  5. Click the Add Icon button. The icon is added to the Select an Icon window.
  6. Click the Select Icon button to add the icon to the selected item.
