Viewing Global Devices
This section describes how to view devices in the SL1 Global Manager system. You can view devices on the Devices page, which you can access by clicking the Devices icon (). From there, you can select a device from the list to view detailed data on the Device Investigator page for that device.
The following video explains how the SL1 Global Manager allows operations across multiple environments to be consolidated in a single view:
Viewing the Global List of Devices
The Devices page allows you to view all of your managed devices in SL1. This section explains how to gather more information about a device from this page.
To navigate to the Devices page, click the Devices icon ():
In a Global Manager system:
  • When the Global View button on the Devices page is toggled on, you can view a list of all of the devices discovered across all of the stacks in your Global Manager system.
  • When the Global View button on the Devices page is toggled off, you can view a list of devices discovered only on the Global Manager system itself.
You cannot add devices from the Devices page while in Global View mode. You can add devices on a particular stack only while on that stack in non-Global View mode.
If you are looking for a very specific set of devices, click the gear icon () to the right of the Search field and select Advanced. In this mode you can create an advanced search using "AND" or "OR" for multiple search criteria. For more information, see Performing an Advanced Search.
For each device, the Devices page displays the following information:
  • IP Address. The device's IP address.
  • Category. The category assigned to the device. Categories include servers, routers, switches, firewalls, and printers, among others. The category is assigned automatically during discovery. For more information about Device Categories, see the section on Managing Device Classes and Device Categories.
  • Class. The manufacturer and type of device. The Device Class is assigned automatically during discovery. For more information about Device Classes, see the section on Managing Device Classes and Device Categories.
  • ID. The device ID. This is a unique number that SL1 automatically assigns to the device during discovery. In a Global Manager system with Global View enabled, the device ID will be preceded by a number and an underscore, where the number preceding the underscore represents the stack on which the device was discovered.
  • State. The current condition of the device, based upon events generated by the device. The device can have one of the following States:
    • Minor. Device has a less serious problem.
  • Collection State. The current condition of data collection for the device. The device can have one of the following Collection States:
  • Disabled. SL1 is not currently collecting data from the device.
  • Component Vanished. The component device is not being reported currently by its root device. SL1 cannot collect data from the device at this time.
  • Hostname. The fully qualified hostname for the device, for devices that are discovered and managed by hostname (instead of by IP address).
  • Stack Name. The name of the stack on which the device was discovered.
  • Stack ID. The numeric ID of the stack on which the device was discovered.
To rearrange the columns in the list, click and drag the column name to a new location. You can adjust the width of a column by clicking and dragging the right edge of the column. For more information about editing and adding columns, see Editing the Settings for an Inventory Page.
Viewing Additional Data about a Device
On the Devices page, you can click the Expand icon () next to a device name to open a drop-down panel called the Device Drawer. The Device Drawer contains additional data about that device:
Image of the Device Drawer
The Device Drawer contains the Vitals graph pane and the Logs pane.
  • The Vitals pane displays graph data for the past four hours of CPU usage, memory usage, and latency for that device, where relevant. You can zoom in on a shorter time frame in the Vitals graph by clicking and dragging your cursor over a timeframe, and you can go back to the original time span by clicking the Reset zoom button.
  • The Tools pane enables you to run a set of diagnostic tools or user-initiated actions in the Activity Center, or to click on custom links that will open in a separate browser window. Click the search bar to search for tools, actions, or custom links that are available for the device. For more information, see the section on Using the Activity Center.
From the list of devices, click the device name to go to the Device Investigator page for more details about that device. For more information, see the Device Investigator section.
Using the Device Investigator
You can view detailed data about a specific device by clicking the device name on the Devices page to open the Device Investigator page for that device:
Image of a new metric in the Device Investigator
The tabs on the Device Investigator page provides access to data associated with a device.
Only tabs relevant to the selected device are available on the Device Investigator page. For example, the Interfaces tab does not display if the selected device does not use interfaces. Also, widgets on the Investigator tab display as empty where no metrics exist for that widget.
The Device Investigator page can include the following menus and buttons:
  • Info. This drawer on the Investigator tab displays additional information about the device, along with the most recently updated values for uptime and collection time.
  • Tools. This button opens the Activity Center, where you can run a set of diagnostic tools or user-initiated actions, or click on custom links that will open in a separate browser window.
  • Manage. In Global View mode, the Device Investigator displays only a few of the tabs that appear in the Device Investigator in non-Global View mode. The tabs that appear in the Device Investigator in Global View mode let you view some device data but not manage the device or change any of its settings. Click the Manage button to view the full Device Investigator and manage the device on its native stack in a separate browser window. After editing the device and saving your changes, you can either close the window to return to Global View mode or keep it open to continue managing the device on its native stack in non-Global View mode.
The Device Investigator page contains the following tabs:
  • Investigator. Displays metrics about a device. For most devices, the default metrics include Logs and the three Vitals: CPU Utilization (percentage), Physical Memory (percentage), and Latency (milliseconds). You can select additional metrics from the Add a metric drop-down list under the Device List pane on the left side of the screen. You can also compare devices on this tab.
  • Settings. Enables you to manage your preferences for that device, such as whether to auto-clear events, accept all logs, run daily port scans, and more. You can also set user maintenance preferences and disable or enable collection on that device.
  • Configs. Displays configuration information collected from the device by Dynamic Applications. If the device does not have any configuration data, this tab does not appear.
  • Events. Displays a list of active and cleared events for the device. You can acknowledge events from this tab or add event notes.
  • Software. Displays a list of all software installed on the device.
  • More. This drop-down list lets you select additional tabs to display on the Device Investigator page by clicking the star icon next to the tab name. You can search for specific items on a tab and the relevant tab will appear in the search results. You can also remove a tab by clicking the star icon again, turning it from blue to white. Your tab selections are saved and persist until you change them.
On the Device Investigator page, you can view read-only information about the device in the Info drawer:
Image of the Info drop-down on the Device Investigator page
  • Collector. The Collector Group that was last used to collect data from the device. For All-In-One Appliances, this field will contain the name of the default, built-in Collector Group.
  • Collecting. Indicates that the device collection is "Collecting" with a green check mark icon (), meaning SL1 is periodically collecting data from the device, or "Not Collecting" with a prohibition icon (), meaning the SL1 is not currently collecting data from the device.
  • Category. The device category associated with the device. The device category usually describes the primary function of the device, such as a "server", "switch", or "router".
  • Uptime. The number of days and hours that the device has been continuously up and communicating with SL1.
Additionally, the Info drawer also displays the following stack information for devices in Global Manager systems:
  • ID. The numeric ID of the stack on which the device was discovered.
  • Name. The name of the stack on which the device was discovered.
  • Version. The SL1 version running on the stack on which the device was discovered.
  • Hostname. The hostname of the stack on which the device was discovered.
  • IP. The IP address of the stack on which the device was discovered.
Using Device Tools in the Action Runner
On the Device Investigator page, you can click the Tools menu to display the Action Runner. The Action Runner enables you to run a set of diagnostic tools or user-initiated actions, or to click on custom links that will open in a separate browser window.
NOTE: For more information about user-initiated actions, see the section on User-Initiated Automations. For more information about custom links, see the section on Custom Links.
To use the Action Runner:
  • Click Activity in the navigation bar at the top of any page in SL1. Click the search bar.
  1. When you click the search bar, a list appears of the default tools, actions, or custom links that are available for the selected device. Click one of these tools, actions, or custom links, or use the search bar to search for a tool or action that is not listed. The following default tools are available in the Action Runner:
  • Ping. Displays statistics returned by the ping tool. The ping tool sends a packet to the device's IP address (the one used by SL1 to communicate with the device) and waits for a reply. SL1 then displays the number of seconds it took to receive a reply from the device and the number of bytes returned from the device. If the device has an IPv6 address, SL1 uses the appropriate IPv6 ping command.
  • Trace Route. Displays the network route between SL1 and the device. The tool provides details on each hop to the endpoint. If the device has an IPv6 address, SL1 uses the appropriate IPv6 traceroute command.
The tools found in the Action Runner can also be found in the Device Toolbox in the classic SL1 user interface.
  1. If you clicked a custom link, the link opens in a new browser window. If you clicked on a tool or action, then as it runs, its progress and results appear in a log in the Activity Center.
The Activity Center
Managing a Device in a Separate Window
In Global View mode, the Device Investigator displays only a few of the tabs that can appear in the Device Investigator in non-Global View mode. The tabs that do appear in the Device Investigator in Global View mode enable you to view some device data but not manage the device or change any of its settings.
To manage a device, click the Manage button in the top-right corner of the Device Investigator while in Global View mode. When you do so, SL1 opens the full Device Investigator for that device on its native stack in a separate browser window.
For more information about all of the device management options available in non-Global View mode, see the section on Using the Device Investigator.
The following section provides an overview of how to use the tabs on the Device Investigator page for a selected device.
The Investigator Tab
The Investigator tab of the Device Investigator page displays a customizable set of metrics about the selected device:
The device type determines which metrics appear in the Investigator tab. For most devices, the following panels and metrics appear by default:
  • Overview. Displays a panel that includes basic information about the device, including its IP address, Device Class, organization, current state, event count, and collection status.
  • Availability. Displays a panel for the device's availability over time. Availability means a device's ability to accept connections and data from the network.
  • Latency. Displays a panel for latency for the device over time, in milliseconds. Latency means the amount of time it takes SL1 to communicate with the device.
  • Map. Displays a panel with a map of the device and all of the devices with which the device has relationships. You can also click the Map panel heading to go to the Map tab for that device. This panel is disabled by default, but can be enabled by clicking the Edit button, and then selecting the Map checkbox.
  • CPU Utilization, Physical Memory Utilization, and Swap Memory Utilization. Displays a combined chart panel with the percentage of CPU, physical memory, and swap memory used by the device over time.
  • Utilization In and Out. Displays a combined chart panel with the percentage of utilization in and out for the device's network interfaces.
  • Discards In and Out. Displays a combined chart panel with the number of discards in and out for the device's network interfaces over time.
  • Errors In and Out. Displays a combined chart panel with the number of errors in and out for the device's network interfaces over time.
  • Logs. Displays a panel with a list of the logs for the device, sorted from newest to oldest by default. You can use the Search field to search device logs for specific event messages, event IDs, date ranges, source types, and other relevant text for troubleshooting. You can also click on the column headers for Date/Time, Source, Event ID, Severity, and Message to sort by that column.
You can customize the look and feel of the Investigator tab by contracting, expanding, and resizing panels as needed. Click the contract icon () in the panel header to display only the header or click the expand icon () to display the panel's full contents. Click the Actions icon () in the panel header and then select Small, Medium, or Large to resize the panel.
You can customize the appearance of leaderboard panels for interfaces, file systems, and Dynamic Applications in the Investigator tab. Click the Leaderboard Bar Chart icon () to switch from a bar chart to a line chart, or click the Line Chart icon () to switch from a line chart to a leaderboard bar chart.
The Investigator tab panel layout is responsive. Panels are automatically resized or relocated whenever a panel is added or removed, the panels are rearranged on the page, or the browser page increases or decreases in size.
The Device Investigator page also includes the following sidebar buttons:
Select the Always display raw data checkbox at the top of the timespan selector to ensure that the metric data that appears in the panels on the Investigator tab always includes the most recent data available. If you do not select that checkbox, SL1 will still display raw data when you select a timespan of less than 2 days, but will automatically display rolled up hourly data for timespan selections of 2-45 days and rolled up daily data for timespan selections of more than 45 days.
Optionally, you can add metrics to the Investigator tab for Dynamic Applications, interfaces, and the SL1 agent (if applicable), among other things. You can also remove metrics from the Investigator tab.
  1. To add a metric panel that is not currently on the Investigator tab, click the Edit button on the right sidebar to expand the layout panel, and then click the Add a metric field. A list of metrics appears:
The list of metrics in the Device Investigator
  1. Select a metric from the list, or type the name of a metric and select it from the list. The metric is added to the right pane, and a corresponding widget appears in the left pane.
  2. Some metrics might require you to make additional selections, such as the network interfaces associated with a device. Click the field and add one or more additional metrics, as needed.
  1. To remove a metric panel from the Investigator tab, uncheck the corresponding box in the right panel. The metric remains listed in the right panel, but the panel is removed from the Investigator tab.
  2. To completely remove the metric and its corresponding panel from the Investigator tab, click the Remove from Layout button (Image of the Close button) for that metric in the right panel.
The Investigator tab retains any changes you made to the set of device metrics displayed for each device, on a per-user basis.
You can prioritize the order in which information is presented on the Investigator tab of the Device Investigator by changing the order in which the metric panel widgets appear on the page. You can click the Edit button on the right side of the page and then drag and drop the panels up or down in the right panel to edit the order in which the metric panels appear on the left panel.
  1. On the Investigator tab of the Device Investigator page, click the Edit button on the right sidebar to expand the layout panel.
  2. Hover your mouse over the "Panel" heading of the panel that you want to move until you see an open hand icon appear.
  3. Click and hold down the left button on your mouse to grab the panel, and then use your mouse to drag the panel to a different location in the list. When you do so, the open hand icon becomes a closed hand icon, and a blue dotted box appears around the panel.
  4. Release the left mouse button to drop the panel in your desired location. The new right-hand panel order will be reflected in the left-hand widget panel.
On the Investigator tab of the Device Investigator page, you can combine charts for different time-series metrics to see all of the combined data for those metrics in a single chart.
To combine charts:
  3. Click and hold down the left button on your mouse to grab the metric, and then use your mouse to drag the metric into the panel of a different time-series metric in the list. When you do so, the open hand icon becomes a closed hand icon, and the panel containing the combined metrics turns blue.
  4. Release the left mouse button to drop the metric into the desired panel. The newly combined metric panel will be reflected in a "Combined Charts" widget in the left-hand widget panel.
The Settings Tab
On the Settings tab of the Device Investigator page, you can manage your preferences for that device, such as whether to auto-clear events, accept all logs, run daily port scans, and more.
Image of the Settings tab in the Device Investigator
The Settings tab in the Device Investigator
    Starting with SL1 version 11.3.0, if you specify 60 seconds for the upload interval, the summary upload now will include "watched" or "monitored" files, just like the snapshot upload does.
  • Collection Poller. Select the name of collector group you want to use for collection on this device.
  • Auto-Update. This checkbox specifies whether or not you want SL1 to perform a nightly discovery of the device and update records with changes to the device. If this field is unchecked, SL1 will not perform nightly discovery. Changes to the device, including newly opened ports, will not be recorded by SL1.
  • Scan All IPs. If the device uses multiple IP Addresses, SL1 will scan for open ports on all IPs during initial discovery and nightly discovery.
  • Enable User Maintenance. Specifies whether the device is in user maintenance mode. User maintenance is an option that allows a user to manually put a device in to "maintenance mode". During maintenance mode, for the selected devices, SL1 generate only events with a severity less than the system-wide Maintenance Minimum Severity setting. If you select Enabled, the device is put in user maintenance mode, and the device will remain in this state until you or another user disables user maintenance mode.
  • Enable Collection During Maintenance . Specifies whether SL1 will poll the device when user maintenance mode is enabled. If you select Enabled, SL1 will continue to poll and collect data from this device during user maintenance mode.
  • Event Mask. Specify the time frame for masking events. When a device uses the Event Mask setting, SL1 groups together events that occur on that device within the specified span of time.
  • Always Create Latency Alert. Select this option to generate two alerts when availability and latency checks fail. Deselect to generate only an availability alert and suppress latency alerts.
  • Allow Events to Auto-Clear. Deselect this option to override an event policy's auto-clear setting for this device.
  • Critical Ping. Pings the device and creates an event if the device does not respond. When enabled you can select between 5 and 120 seconds.
  • Preserve Device Name. If selected, the name of the device in SL1 will remain the same, even if the name of the actual device is changed. If unselected, the SL1 name for the device will be updated if the name of the actual device is changed.
  • Disable Asset Update. If selected, SL1 will not automatically create a new asset record for the device or update the existing asset record for the device. For the single device, this checkbox over-rides any settings defined in the Asset Automation page (System > Settings > Assets).
  • Bypass Interface Inventory. Specifies whether or not the discovery session should discover network interfaces. Your options include:
  • Selected. SL1 will not attempt to discover interfaces for this device during re-discovery and nightly auto-discovery.
  • Not Selected. SL1 will attempt to discover network interfaces for this device during re-discovery and nightly auto-discovery using the Interface Inventory Timeout value and Maximum Allowed Interfaces value specified in the Device Thresholds page.
  • Dynamic Discovery. If selected, SL1 will automatically assign the appropriate dynamic applications to the device during discovery.
The Configs Tab
On the Configs tab of the Device Investigator, you can view configuration information that has been collected from the device by Dynamic Applications.
All objects of type "config" are included on the Configs tab. Usually, "config" objects contain static information about hardware and configuration settings, such as serial numbers, version numbers, and hardware status.
For more information about this tab, see the section on Viewing Device Configuration Data.
The Events Tab
The Events tab of the Device Investigator page
For each event, the Events tab displays the following information:
  • ID. The unique ID for the event, generated by SL1. The ID appears as a hyperlink. To view the Event Investigator page for the event, click the ID hyperlink. For more information about the Event Investigator page, see the section on Using the Event Investigator.
  • Severity. The severity of the event. Possible values are:
  • Critical
  • Major
  • Minor
  • Notice
  • Healthy
  • Message. The message generated for the event. The message appears as a hyperlink. To view the Event Investigator page for the event, click the Message hyperlink. For more information about the Event Investigator page, see the section on Using the Event Investigator.
  • Age. The amount of time (in days, hours, and minutes) since the event first occurred or since its last occurrence without having been cleared.
  • Ticket ID. If a ticket has been created for the event, this column displays the ticket ID of that ticket.
  • Count. The number of times this event has occurred, the number of child events associated with the event, or the number of masked events associated with the event.
  • Last Detected. The date and time at which the event last occurred on the device.
  • Ticket External Reference. The numeric ID associated with a ticket from an external ticketing system (that is, a ticket that was not created in SL1). If this field displays a value, you can click on that value to spawn a new window and view the external ticket.
    NOTE: To link an external ticket to an event, you must create a custom Run Book Automation policy and a custom Run Book Action or use the ScienceLogic APIs. For help with these tasks, contact ScienceLogic Customer Care.
  • Event Source. The system or application that generated this event. Possible values are:
  • Syslog. Event was generated from a system log generated by a device.
  • Email. Event was generated by an email from an external agent. For example, Microsoft Operations Manager (MOM).
  • Internal. Event was generated by SL1.
  • Trap. Event was generated by an SNMP trap.
  • Dynamic. Event was generated by a Dynamic Application collecting data from the device.
  • API. Event was generated by a snippet Run Book Action, a snippet Dynamic Application, a request to the ScienceLogic API, or by an external system.
  • SL1 agent. Message is generated by log file messages collected by the SL1 agent. For more information about creating Log File Monitoring Policies to monitor log file messages collected by the agent, see the section on Monitoring Device Logs Using an Agent.
  • Event Note. A user-defined note to accompany the event. To create or edit a note, click the Note icon (). The Edit Event Note window appears, where you can create or edit a note and save your changes.
  • Acknowledge. If the event has been acknowledged, this column displays a check mark and the username of the user who acknowledged the event. If the event has not yet been acknowledged, this column displays an Acknowledge button; click the Acknowledge button to acknowledge the event. When you acknowledge an event, you let other users know that you are aware of that event and are working on a response.
  • Clear. Click the Clear button to clear the event. When you clear an event, you let other users know that this event has been addressed. Clearing an event removes a single instance of the event from the Events tab. If the same event occurs again on the same device, it will reappear in the Events tab, even if you have previously cleared that event.
You can toggle between Active events and Cleared events by using the drop-down to the left of the Search field. On this tab, you can also acknowledge and clear an event if you have permission for those actions.
Clicking the Actions menu () next to an event gives you the following options, based on your permissions:
  • View Event. Navigates to the Event Investigator page for that event.
  • Edit Event Note. Lets you update the Note associated with this event.
  • Create Ticket. Opens a new ticket in the SL1 Ticket Editor, if you are using SL1 for your ticketing.
  • Edit Ticket. Opens an existing ticket in the SL1 Ticket Editor, if you are using SL1 for your ticketing.
  • Create External Ticket. Creates a new ticket for the event if you are using an external ticketing system instead of SL1.
  • View Event Policy. Opens the Event Policy page for the policy aligned with this event.
  • Suppress Event for this Device. Suppresses the current event on the current device. When you suppress an event, you are specifying that in the future, if this event occurs again on the same device, the event will not appear in
  • View Automation Actions. Displays a log of automations that have occurred for that event. This option is hidden if the event does not have any automation actions aligned to it.
The Interfaces Tab
The Interfaces tab of the Device Investigator page
For more information about this tab, see the section on Viewing Interfaces for a Single Device.
The Software Tab
The Software tab of the Device Investigator page
  • Name. Name of the software.
For more information about this tab, see the section on Monitoring Hardware and Software.
