Discovery
The following sections describe how to discover Microsoft Azure resources for monitoring by SL1 using the Microsoft: Azure PowerPack.
Microsoft Azure Guided Discovery
You can use the Universal Discovery Framework process in SL1 that guides you through a variety of existing discovery types in addition to traditional SNMP discovery. This process, which is also called "guided discovery", lets you pick a discovery type based on the type of devices you want to monitor. The Universal Discovery workflow includes a button for Microsoft Azure.
To run a guided or Universal Discovery:
  1. Select the Microsoft Azure button. Additional information about the requirements for device discovery appears in the General Information pane to the right.
  1. On the Credential Selection page of the guided discovery process, select the Azure credential that you configured, and then click Next. The Root Device Details page appears.
Image of the Root Device Details page
  • Root Device Name. Type the name of the root device for the Microsoft Azure root device you want to monitor.
  1. Click Next. SL1 creates the Microsoft Azure root device with the appropriate Device Class assigned to it and aligns the relevant Dynamic Applications. The Final Summary page appears.
Image of the Final Summary page
  1. Click Close.
Creating an Azure Virtual Device for Discovery in the SL1 Classic User Interface
Because the Azure service does not have a static IP address, you cannot discover an Azure device using discovery. Instead, you must create a virtual device that represents the Azure service. A virtual device is a user-defined container that represents a device or service that cannot be discovered by SL1. You can use the virtual device to store information gathered by policies or Dynamic Applications.
To create a virtual device that represents your Azure service:
  1. Go to the Device Manager page (Devices > Device Manager, or Registry > Devices > Device Manager in the classic SL1 user interface).
  1. Click the Actions button and select Create Virtual Device from the menu. The Virtual Device modal page appears.
  • Device Name. Enter a name for the device. For example, "Azure Cloud".
  • Device Class. Select Microsoft | Azure Services.
When monitoring an account with multiple child subscriptions, you can load-balance how SL1 monitors your Azure components by discovering groups of subscriptions and their components across multiple collectors. For details, see the section on Load-Balancing an Account with Multiple Subscriptions.
Aligning the Azure Dynamic Applications
The Dynamic Applications in the Microsoft: Azure PowerPack are divided into the following types:
  • Discovery. These Dynamic Applications poll Azure for new instances of services or changes to existing instances of services.
  • Configuration. These Dynamic Applications retrieve configuration information about each service instance and retrieve any changes to that configuration information.
  • Performance. These Dynamic Applications poll Azure for performance metrics.
When configuring SL1 to monitor Azure services, you can manually align Dynamic Applications to discover Azure component devices.
Discovering Azure Component Devices
To discover all the components of your Azure platform, you must manually align the "Microsoft: Azure Account Discovery" Dynamic Application with the Azure virtual device.
When monitoring an account with multiple child subscriptions, ScienceLogic recommends that you first review your device capacity and load limits to determine the best method for implementation prior to discovery. For details, see the section on Load-Balancing an Account with Multiple Subscriptions.
To manually align the "Microsoft: Azure Account Discovery" Dynamic Application:
  1. Click the wrench icon () for your Azure virtual device.
  3. Click the Actions button and select Add Dynamic Application from the menu.
  1. In the Dynamic Application Alignment modal:
  • In the Dynamic Applications field, select Microsoft: Azure Account Discovery.
  • In the Credentials field, select the credential you created for your Azure service.
  1. Click Save to align the Dynamic Application with the Azure virtual device.
When you align the "Microsoft: Azure Account Discovery" Dynamic Application with the Azure virtual device, SL1 does one of the following, depending on your subscription model:
  • If you are monitoring an account with multiple child subscriptions, SL1 creates a root component device representing the Azure account and one or more child component devices representing all of your Azure subscriptions.
  • If you are monitoring a single subscription, SL1 creates a root component device representing your Azure subscription.
SL1 then automatically aligns several other Dynamic Applications to the subscription component devices. These additional Dynamic Applications discover and create component devices for Active Directory tenants, Traffic Manager profiles, and each location used by the Azure account.
Under each location, SL1 then discovers the following component devices:
  • Application Gateway Services
    • Application Gateways
  • App Services
    • App Service Plan
      • Function App
      • Web App
  • Azure API Management Service
      • Azure API Management API
  • Azure Automation Service
    • Azure Automation Resource
  • Azure Cache for Redis
  • Azure Data Factory Service
  • Azure Database for MySQL Services
    • Azure Database for MySQL Servers
  • Azure Database for PostgreSQL Services
    • Azure Database for PostgreSQL Servers
  • Azure Databricks Service
    • Azure Databricks Resource
  • Azure Firewall Service
    • Azure Firewall
  • Azure Functions
  • Azure HDInsight Cluster Service
  • Azure Host Pool Service
    • Azure Host Pool
  • Azure Kubernetes Services (AKS)
    • Azure Kubernetes Clusters
  • Azure Logic Apps
  • Azure Service Buses (Relay)
  • Batch Accounts
  • Content Delivery Networks
    • CDN Profiles
      • CDN Endpoints
  • Cosmos DB Accounts
  • DNS Services
    • DNS Zones
  • ExpressRoute Services
    • ExpressRoute Circuits
      • ExpressRoute Peering
        • ExpressRoute Circuit Connections
  • Key Vaults
  • Load Balancer Services
    • Load Balancers
  • Network Security Group Services
    • Network Security Groups
  • Recovery Service Vaults Services
  • Resource Groups Services
    • Resource Groups
  • SQL Managed Instance Service
      • SQL Managed Instance Database
  • SQL Server Services
    • SQL Servers
    • SQL Databases
  • Storage Manage Disks
    • Manage Disk Service
      • Manage Disk
  • Storage Services
    • Storage Accounts
  • Virtual Desktop Services
  • Virtual Machines Services
    • Virtual Machines
  • Virtual Network Services
    • Virtual Networks
      • ExpressRoute Gateways
      • Virtual Network Gateways
      • Virtual Network Subnets
  • VM Scale Set Services
    • VM Scale Sets
      • Virtual Machines
  • Web Application Firewalls (WAF)
    • WAF on CDN Policies
    • WAF on Application Gateway Policies
SL1 might take several minutes to align these Dynamic Applications and create the component devices in your Azure service.
When discovering a large number of component devices, such as when discovering an account with multiple child subscriptions, the discovery process can cause the appearance of numerous critical events with the message, "Large backlog of asynchronous jobs detected". This will occur only during the initial discovery session.
Viewing Azure Component Devices
In addition to the Devices page, you can view the Azure service and all associated component devices in the following places in the user interface:
  • The Device Components page (Devices > Device Components) displays a list of all root devices and component devices discovered by SL1. The Device Components page displays all root devices and component devices in an indented view, so you can easily view the hierarchy and relationships between child devices, parent devices, and root devices. To view the component devices associated with an Azure service, find the Azure service and click its plus icon (+).
  • The Component Map page (Classic Maps > Device Maps > Components) allows you to view devices by root node and view the relationships between root nodes, parent components, and child components in a map. This makes it easy to visualize and manage root nodes and their components. SL1 automatically updates the Component Map as new component devices are discovered. The platform also updates each map with the latest status and event information. To view the map for an Azure service, go to the Component Map page and select the map from the list in the left NavBar. To learn more about the Component Map page, see the section on Maps.
In addition to parent/child relationships between component devices, SL1 also creates relationships between the following component devices:
  • Apps and Resource Groups
  • Application Gateways and Resource Groups
  • Application Gateways and Virtual Network Subnets
  • Azure Automation and Resources Groups
  • Azure CosmosDB and Resource Groups
  • Azure CosmosDB and Virtual Networks
  • Azure CosmosDB and Virtual Network Subnets
  • Azure Traffic Managers and Traffic Managers
  • Batch Accounts and Key Vaults
  • Batch Accounts and Resource Groups
  • Batch Accounts and Storage Groups
  • CDN Profiles and Resource Groups
  • Data Lakes and Resource Groups
  • Data Lakes and Storage Accounts
  • Databricks and Resource Groups
  • Databricks and Storage Accounts
  • HDInsight Clusters and Storage Groups
  • HDInsight Clusters and Virtual Networks
  • HDInsight Clusters and Resource Groups
  • Host Pool sand Resource Groups
  • Host Pools and Virtual Machines
  • Key Vaults and Resource Groups
  • Key Vaults and Virtual Networks
  • Key Vault Rules and Subnets
  • Kubernetes Agent Pools and Subnets
  • Load Balancers and Resource Groups
  • Logic Apps and Resource Groups
  • Managed Disks and Resource Groups
  • Managed Disks and Virtual Machines
  • Network Security Groups and Resource Groups
  • Network Security Groups and Virtual Network Subnets
  • PostgreSQL Servers and Resource Groups
  • PostgreSQL Servers and Subnets
  • PostgreSQL Servers and PostgreSQL Server Replicas
  • PostgreSQL Servers and Virtual Networks
  • Recovery Service Vaults and Resource Groups
  • Redis Cache Servers and Redis Cache Servers
  • Redis Caches and Resource Groups
  • Redis Caches and Subnets
  • Redis Caches and Virtual Networks
  • Service Bus Namespaces and Resource Groups
  • Service Bus Namespaces and Service Bus Namespaces
  • Service Bus Namespaces and Subnets
  • Service Bus Namespaces and Virtual Networks
  • SQL Databases and Resource Groups
  • SQL Servers and Resource Groups
  • SQL Servers and Server Replicas
  • SQL Servers and Subnets
  • SQL Servers and Virtual Networks
  • SQL Servers and Virtual Network Subnets
  • Storage Accounts and Resource Groups
  • Traffic Manager Profiles and Resource Groups
  • Virtual Machines and Network Security Groups
  • Virtual Machines and Resource Groups
  • Virtual Machines and Storage Accounts
  • Virtual Machines and Virtual Networks
  • Virtual Machines and Virtual Network Subnets
  • Virtual Machine Scale Sets and Load Balancers
  • Virtual Machine Scale Sets and Resource Groups
  • Virtual Machine Scale Sets and Virtual Network Subnets
  • Virtual Machine Scale Set Virtual Machines and Resource Groups
  • Virtual Networks and Resource Groups
  • VPN Gateways and Resource Groups
  • VPN Gateways and Virtual Network Subnets
  • WAF CDN Policies and Endpoints
  • WAF CDN Policies and Resource Groups
  • WAF Gateway Policies and Application Gateways
  • WAF Gateway Policies and Resource Groups
Additionally, the platform can automatically build relationships between Azure component devices and other associated devices:
  • If you discover Cisco Cloud Center devices using the Dynamic Applications in the Cisco: CloudCenter PowerPack version 103 or later, SL1 will automatically create relationships between Azure Virtual Machines and Cisco Cloud Center applications.
  • If you discover Dynatrace environments using the Dynamic Applications in the Dynatrace PowerPack, SL1 will automatically create relationships between the following device types:
  • Azure Virtual Machines and Dynatrace Hosts
  • Azure Virtual Machine Scale Sets and Dynatrace Hosts
  • If you discover Office 365 services using the Dynamic Applications in the Microsoft: Office 365 PowerPack version 101 or later, SL1 will automatically create relationships between Azure Active Directory tenants and Office 365 Active Directory tenants.
