This SyncPack requires a subscription to ScienceLogic Standard solutions.
- A subscription to the SL1 Standard solution
- AWS Base SyncPack
- SL1 Base Notifications SyncPack
PowerFlow | AWS API | Any | TCP 443 | AWS API Access |
Contents of the SyncPack
This section lists the contents of the AWS Incident Manager SyncPack.
PowerFlow Applications
- Bulk Resolve SL1 Events From AWS. This application collects resolution state data from AWS and resolves corresponding SL1 events.
- Create Timeline Event In AWS Incident Manager. This application collects acknowledged event data from SL1 and creates a timeline event in AWS.
- Resolve AWS Incident. This application resolves an AWS incident that was resolved by a corresponding SL1 event.
- Send SL1 Event to AWS Incident Manager. This application collects event details from SL1 and creates an incident in AWS.
For more information about how to configure these applications, see Configuring and Aligning the AWS Incident Manager Applications.
Configuration Object
- AWS Incidents Base Config. This configuration object can be used as a template after the SyncPack is installed on the PowerFlow system. The configuration object includes the following:
- Details for connecting to SL1, including the host, username, and password.
- Details for connecting to AWS, including the region name, access key ID, secret access key ID, and service.
- Details for event and incident response including templates, maps, time, external URL population, and response plans.
Steps
- CreateSL1Payload
- Get Event Details From SL1 Start AWS Incident
- Get Resolved Incidents And Pass To SL1
- PostUpdateToSL1
- Resolve Incident In AWS Incident Manager
Installing the SyncPack
You must download the AWS Base SyncPack before downloading the AWS Incident Manager SyncPack.
Downloading the SyncPack
Importing the SyncPack
- On the SyncPacks page (
) appears.
