This PowerPack is available with a ScienceLogic SL1 Standard solution. Contact your ScienceLogic Customer Success Manager or Customer Support to learn more.
This PowerPack requires a subscription that includes CMDB/Inventory Workflow Automations.
What is the Ansible Automation PowerPack?
The Ansible Automation PowerPack includes automation policies and action policies that unidirectionally sync Towers and Commands from Ansible to SL1 events.
Installing the Ansible Automation PowerPack
IMPORTANT: You must install and configure the Ansible SyncPack version 1.0.0 before using the Ansible Automation PowerPack.
The Ansible Automation PowerPack requires SL1 version 11.1.0 or later. For details on upgrading SL1, see the appropriate SL1 Release Notes.
