Configuring Applications for the Ansible SyncPack
This section describes how to set up the PowerFlow applications for the AnsibleSyncPack.
For this SyncPack, you should make a copy of the "Sample Ansible Configuration" configuration object, which is the sample configuration file that was installed with the Ansible SyncPack.
The "Sample Ansible Configuration" configuration object contains all of the required variables. Simply update the variables from that object to match your SL1 and Ansible settings.
To create a configuration object based on the "Sample Ansible Configuration" configuration object:
  2. Click the Actions button () for the "Sample Ansible Configuration" configuration object and select Edit. The Configuration pane appears:
An image of the configuration object page.
    • sl1_host. Type the hostname or IP address of the SL1 system the alerts will synchronize with.
    • sl1_password. Type the password for your SL1 system.
    • sl1_user. Type the username for your SL1 system.
    • ansible_url. Enter the URL for your Ansible system.
    • ansible_username. Type the username for your Ansible system.
    • ansible_password. Type the password for your Ansible system.
    • template_id. Type the Ansible Tower template ID. This field is only required if you are monitoring an Ansible Tower.
    • host_name. Type the host name for your Ansible system.
    • playbook. Type the name of your Ansible playbook.
    • inventory_id. Type the Ansible Tower inventory ID. This field is only required if you are monitoring an Ansible Tower.
    • credential_id. Type the Ansible Tower credential ID. This field is only required if you are monitoring an Ansible Tower.
    • ssh_username. Type your SSH username.
    • ssh_password. Type your SSH password.
    • host_name_status. Toggle on (blue) to enter the host name status from the event details.
    • ssh_pem_status. Toggle on (blue) to enter the SSH status from the event details.
    • ssh_pem. Enter the RSA key for SSH connection and type "\n" before and after your RSA key.
    • ssh_host. Type your SSH host name.
    • add_template. Toggle the JSON editor to define a message for the description field in the SL1 event.
For more information about the Ansible terms and concepts in this section, see the Ansible documentation.
With this SyncPack, you can create SL1 events based on Ansible Towers and Commands. You will need to align the Ansible SyncPack applications with the relevant configuration object in PowerFlow, and, if needed, update any other fields on the Configuration pane for the applications.
  1. On the Applications page of the PowerFlow user interface, open one of the PowerFlow applications listed above and click Configure (). The Configurations pane for that application appears:
An image of the Configure Application page.
  2. Repeat this process for the other PowerFlow applications.
To trigger some applications in this SyncPack, you must schedule the application. If you want to use the following applications, you must schedule the application:
PowerFlow Application Recommended Schedule Time
Ansible Tower Job Status Update Every five minutes
Clear SL1 Events Every 10 minutes
To schedule an application:
  1. To delete the selected schedule, click Delete. The schedule is removed.
When either multiple SL1 instances or multiple Ansible instances are involved with PowerFlow, you should create an individual configuration object for each SL1 or Ansible instance. Next, create an individual schedule for each configuration object. Each schedule should use a configuration object that is specific to that single SL1 or Ansible instance. Creating copies of a PowerFlow application from a SyncPack for the purpose of distinguishing between domains is not supported, and will result in issues on upgrades.
