Introduction to the CrowdStrike Falcon Automation PowerPack
This section describes the how to integrate CrowdStrike with SL1 using the CrowdStrike Falcon Automation PowerPack. This PowerPack also contains the Run Book Automation policies and Run Book Action policies you can use with the CrowdStrike Falcon Automation Synchronization PowerPack in PowerFlow.
This PowerPack is available with a ScienceLogic SL1 Standard solution. Contact your ScienceLogic Customer Success Manager or Customer Support to learn more.
What is the CrowdStrike Falcon Automation PowerPack?
The CrowdStrike Falcon Automation PowerPack includes automation policies and action policies that bidirectionally sync jobs, pipeline jobs, and node status between CrowdStrike and SL1.
The CrowdStrike Falcon Automation PowerPackb includes:
  • CrowdStrike: Clear Detection ID Run Book Automation policies
  • CrowdStrike: Clear Detection ID Run Book Action policy
  • CrowdStrike: Alert to Event event policy
  • PowerFlow CrowdStrike SOAP/XML Credentials
Installing the CrowdStrike Falcon Automation PowerPack
Before completing the steps in this section, you must import and install the latest version of the CrowdStrike Falcon Automation PowerPack.
IMPORTANT:: You must install and configure the CrowdStrike Falcon Automation Synchronization PowerPack version 1.0.0 before using the CrowdStrike Falcon Automation PowerPack.
The CrowdStrike Falcon Automation PowerPack requires SL1 version 11.1.0 or later. For details on upgrading SL1, see the appropriate SL1 Release Notes.
