You must have an Elastic Cloud account before you integrate the ELK Stack SyncPack with PowerFlow.
For this SyncPack, you should make a copy of the "ElasticSearch Logstash Kibana Configuration" configuration object, which is the sample configuration file that was installed with the ELK Stack Automation PowerPack.
The "ElasticSearch Logstash Kibana Configuration" configuration object contains all of the required variables. Simply update the variables from that object to match your SL1 and ELK settings.
To create a configuration object based on the "ElasticSearch Logstash Kibana Configuration" configuration object:
Click the
) for the "ElasticSearch Logstash Kibana Configuration" configuration object and select Edit. The Configuration pane appears:
button (
- Click Create Configuration pane appears. . The
- In the Configuration Data field, include the required block of code to ensure that the applications aligned to the ELK configuration object is successful:
- elk_username. Type the username for your ELK system.
- elk_password. Type the password for your ELK system.
- elk_document_url. Enter the URL for your ELK document.
- ELK_Cloud_id. Type the ELK Cloud ID for login.
- create_index_name. Type the name of the log data.
- URI_for_log_data. Type the Log Data URL.
- from_date. Type the start date in dd-mm-yyyy hh:mm:ss.
- to_date. Type the end date in dd-mm-yyyy hh:mm:ss.
The following fields are required only if you choose to manually create a virtual device for your ELK instance:
- device_class_id. Type the device class ID for your ELK instance.
- collector_group_id. Type the collector group ID for your ELK instance.
- device_id.Type the device ID for your ELK instance.
With this SyncPack, you can create SL1 events based on ELK jobs. You will need to align the ELK Stack SyncPack applications with the relevant configuration object in PowerFlow, and, if needed, update any other fields on the Configuration pane for the applications.
- On the Applications page of the PowerFlow user interface, open each of the PowerFlow applications listed above and click (
) one at a time. The Configurations pane for that application appears:
To create a schedule on PowerFlow version 2.5.0 and later:
- On the Applications page (
), click the button for the application you want to schedule. The Scheduler window appears:
- Click Schedule List pane. Also, on the Applications page, the button now displays with a dark blue background: . The schedule is added to the
To create a schedule on PowerFlow version 2.4.1 or earlier:
- Click the + icon to create a schedule. A blank Schedule window appears:
- Click Schedule window. Also, on the Applications page, the word "Scheduled" appears in the Scheduled column for this application, and the button contains a check mark: . The schedule is added to the list of schedules on the initial
- Click the down arrow icon (
) and select .
When either multiple SL1 instances or multiple ELK instances are involved with PowerFlow, you should create an individual configuration object for each SL1 or ELK instance. Next, create an individual schedule for each configuration object. Each schedule should use a configuration object that is specific to that single SL1 or ELK instance. Creating copies of a PowerFlow application from a SyncPack for the purpose of distinguishing between domains is not supported, and will result in issues on upgrades.
