SL1 PowerFlow includes an API that is available after you install the PowerFlow system.
Interacting with the API
To view the full documentation for the PowerFlow API:
- From the PowerFlow system, copy the /opt/iservices/scripts/swagger.yml file to your local computer.
- Open a browser session and go to editor.swagger.io.
- In the Swagger Editor, open the File menu, select Import File, and import the file swagger.yml. The right pane in the Swagger Editor displays the API documentation.
Available Endpoints
POST
/api/v1/apikeys/. Add a new API key.
/api/v1/applications. Add a new application or overwrite an existing application.
/api/v1/applications/{appName}/run. Run a single application by name with saved or provided configurations.
/api/v1/applications/run. Run a single application by name.
/api/v1/configurations. Add a new configuration or overwrite an existing configuration.
/api/v1/roles/owner. Add a new owner assigned a specific role.
/api/v1/schedule. Add a new scheduled PowerFlow application.
/api/v1/status. Runs the "PowerFlow Control Tower HealthCheck" application to generate health status data.
/api/v1/steps. Add a new step or overwrite an existing step.
/api/v1/steps/run. Run a single step by name.
/api/v1/syncpacks/{syncpackName}/install. Install a specific SyncPack version by name.
/api/v1/tasks/{taskId}/replay. Replay a specific PowerFlow application. Replayed applications run with the same application variables, configuration, and queue as the originally executed application.
/api/v1/tasks/{taskId}/revoke. Revoke or terminate a specific task or application. By default, this command will not terminate the current running task. If an application ID is provided, all tasks associated with that application are revoked.
/api/v1/me/widgets/{widget_id}. Creates a new widget or updates a existing widget used on the PowerFlow Control Tower page.
Querying for the State of a PowerFlow Application
When triggering PowerFlow application from the applications/run endpoint, you can query for the state of that application in two ways:
- Asynchronously. When you POST a run of a PowerFlow application to /applications/run, the response is an integration status with a Task ID, such as: isap-23233-df2f24-etc. At any time, you can query for the current state of that task from the endpoint /api/v1/tasks/isap-23233-df2f24-etc. The response includes all of the steps run by the application, along with the status of the steps, and URL links to additional info, such as logs for each step.
- Synchronously. When you POST a run of an application, you can tell PowerFlow to wait responding until the application is complete by adding the wait argument. For example, /api/v1/applications/run?wait=20 will wait for 20 seconds before responding. The maximum wait time is 30 seconds. When the application completes, or 30 seconds has passed, the API returns the current status of the integration run. This process works the same as if you had manually queried /api/v1/tasks/isapp-w2ef2f2f. Please note that while the API is waiting for your application to complete, you are holding on to a thread. If you have multiple applications that run for a long period of time, do not use a synchronous query unless you have no other option. ScienceLogic recommends using an asynchronous query whenever possible.
GET
/api/v1/about. Retrieve version information about the packages used by this PowerFlow system, including the version of PowerFlow.
/api/v1/apikeys. Retrieve all available API keys saved in the PowerFlow system.
/api/v1/apikeys/{api_key}. Get details of a single API key.
/api/v1/applications. Retrieve a list of all available applications on this PowerFlow system.
/api/v1/applications/{appName}. Retrieve a specific application.
/api/v1/applications/{appName}/logs. Retrieve the logs for the specified application.
/api/v1/cache/{cache_id}. Retrieve a specific cache to gather information about the user interface and the PowerFlow applications.
/api/v1/cache/{cache_key}. Retrieve cache documents, but only if this cache document was explicitly saved to be exposed to the API. You will need to save the cache document using the latest version of the "SaveToCache" step in the Base Steps Synchronization PowerPack. This step has a step parameter called "read_from_api" that lets you decide whether the cache document can be requested from the API.
/api/v1/configurations. Retrieve a list of all configurations on this PowerFlow system.
/api/v1/configurations/{configName}. Retrieve a specific configuration.
/api/v1/license?type=platform. Retrieve license data for this PowerFlow system.
/api/v1/reports. Retrieve a list of paginated reports.
/api/v1/reports/{reportId}. Retrieve a specific report by ID.
/api/v1/roles. Retrieve a list of available roles on this PowerFlow system.
/api/v1/roles/owner. Retrieve a list of roles assigned to owners on this PowerFlow system.
/api/v1/roles/owner/{owner}. Retrieve the role assigned to a specific owner.
/api/v1/sessions. Retrieve a list of sessions for this PowerFlow system.
/api/v1/sessions/status. Retrieve the Session Management status for this PowerFlow system.
/api/v1/sessions/username/{username}. Retrieve the session IDs for a specific user.
/api/v1/sessions/{session_id}. Retrieve a specific session from Session Management for this PowerFlow system.
/api/v1/schedule. Retrieve a list of all scheduled applications on this PowerFlow system.
/api/v1/status. Retrieve all the health status cache documents without running the "PowerFlow Control Tower HealthCheck" application.
/api/v1/status?all=true. Retrieve all health metrics for PowerFlow services and merge all the health status cache documents to return only one JSON response.
/api/v1/status/{service}. Retrieve all health metrics for a specific PowerFlow service, including the following services: contentapi, couchbase, dexserver, iservices_syncpack_steprunner, iservices_syncpacks_steprunner, pfctl_output, rabbitmq, redis, steprunner.
Starting with PowerFlow version 2.6.0, you can run a GET api/v1/status operation that returns all the health status cache documents without running the HealthCheck application.
/api/v1/steps. Retrieve a list of all steps on this PowerFlow system.
/api/v1/steps/{stepName}. Retrieve a specific step.
/api/v1/syncpacks. Retrieve a list of all SyncPacks on this PowerFlow system.
/api/v1/syncpacks/{synpackName}. Retrieve the full details about a specific SyncPack.
/api/v1/syncpacks?only_installed=true. Retrieve a list of only the installed SyncPacks on this system.
/api/v1/syncpacks?only_activated=true. Retrieve a list of only the activated SyncPacks on this system.
/api/v1/tasks/{taskId}. Retrieve a specific task.
/api/v1/webhooks. Retrieve all available webhooks saved in the PowerFlow system.
/api/v1/me/widgets. Returns a list of all installed widgets used on the PowerFlow Control Tower page.
/api/v1/me/widgets/{widget_id}. Returns a specific widget using the specified widget ID.
DELETE
/api/v1/apikeys/{api_key}. Delete an API key.
/api/v1/applications/{appName}. Delete a PowerFlow application by name.
/api/v1/cache/{cache_id}. Delete a cache entry by name.
/api/v1/configurations/{configName}. Delete a configuration by name.
/api/v1/license?type=platform. Delete license data for this PowerFlow system.
/api/v1/me/widgets/{widget_id}. Delete the specified widget used on the PowerFlow Control Tower page.
/api/v1/roles/owner. Delete a specific owner role.
/api/v1/schedule. Delete a scheduled PowerFlow application by ID.
/api/v1/sessions. Delete a list of sessions for this PowerFlow system.
/api/v1/sessions?all=true. Delete all sessions for this PowerFlow system.
/api/v1/sessions/status. Delete the Session Management status for this PowerFlow system.
/api/v1/sessions/username/{username}. Delete the session IDs for a specific user.
/api/v1/sessions/{session_id}. Delete a specific session from Session Management for this PowerFlow system.
/api/v1/reports/{appName}. Delete a specific report by name.
/api/v1/reports/{reportId}. Delete a specific report by report ID.
/api/v1/steps/{stepName}. Delete a specific step by name.
/api/v1/syncpacks/{spName}. Delete a specific SyncPack by name.
/api/v1/tasks. Terminate all running tasks.
/api/v1/tasks/{taskId}. Terminate a specific running task.
