- SL1 Advanced or Premium solutions included in the 2020 pricing model
- SL1 Standard or Premium solutions in the Change and Configuration workflow automation option included in the 2022 pricing model
The following video explains how to integrate SL1 with Restorepoint:
What is the Restorepoint Automation PowerPack?
The Restorepoint AutomationPowerPack includes automation policies that:
- Enrich SL1 events for devices managed by Restorepoint (for example, devices that have been synced using the Restorepoint SyncPack) by automatically running diagnostic commands. The command output is added to the SL1 event log or associated incident.
- Start or revert a backup in Restorepoint and add the command output to the SL1 event log or associated incident.
The Restorepoint Automation actions are executed on the SL1 All-In-One Appliance or Database Server.
In addition to using the standard content, you can use the content in the Restorepoint Automation PowerPack to:
- Create your own automation policies that include the pre-defined actions that run different sets of diagnostic commands.
- Use the supplied "Restorepoint: Generic Action type" custom action type to configure your own automation action by supplying a set of commands.
Installing the Restorepoint Automation PowerPack
IMPORTANT: You must install the Datacenter Automation Utilities PowerPack version 103 before using the Restorepoint Automation PowerPack.
The Restorepoint Automation PowerPack requires SL1 version 8.14.0 or later. For details on upgrading SL1, see the appropriate SL1 Release Notes.
