Prerequisites for ServiceNow SyncPacks
This section describes the prerequisites for the ServiceNow SyncPacks. For more information about the specific software versions required by a ServiceNow SyncPack, see the release notes for that SyncPack.
To install any of the ScienceLogic ServiceNow SyncPacks, you must have administrator access to both SL1 and ServiceNow. Specifically, you will need:
If you want to upload and install multiple ServiceNow SyncPacks at the same time, you should upload all of the SyncPacks first, and then install them to address any dependencies between the SyncPacks.
SL1 | ServiceNow |
Asset, Custom Attribute |
Asset (ITAM) |
Device |
CI (Configuration Item) |
Discovery Session |
Event |
Incident, Event, or Case (depending on the SyncPack you are using) |
Alert |
Event |
Organization |
Company, Domain |
Downloading and Installing the SyncPack
If you are upgrading to this version of the SyncPack from a previous version, make a note of any settings you made on the Configuration pane of the various PowerFlow applications in this SyncPack, as these settings are not retained when you upgrade.
Importing the SyncPack
- On the SyncPacks page (
You must import and install the ServiceNow Base SyncPack before uploading and installing any of the other ServiceNow SyncPacks.
) appears.
Installing the "Service Graph Connector for ScienceLogic" Application in ServiceNow
You must install the "Service Graph Connector for ScienceLogic" application on the ServiceNow instance to enable this SyncPack. You must first request the "Service Graph Connector for ScienceLogic" application from the ServiceNow Store, and then you can install it.
You must have a ServiceNow HI Service Account to request this application and download it onto your ServiceNow instance.
To request and install the "Service Graph Connector for ScienceLogic" application:
Go to the ServiceNow Store at https://store.servicenow.com/ and search for "ScienceLogic".
Select the "Service Graph Connector for ScienceLogic" application. The detail page for the application appears.
Click Get and log in with your HI credentials.
After the request is approved, log in to ServiceNow as an administrator and navigate to Application Manager (System Applications > Applications).
Click Downloads in the menu header or search for "ScienceLogic".
Click the version drop-down for the "Service Graph Connector for ScienceLogic" application listing to make sure you are using the correct version of the application that is compatible with your version of the ServiceNow Service Graph Connector SyncPack.
Click Install for the "Service Graph Connector for ScienceLogic" application. The installation is complete when the button changes to Installed.
In the filter navigator, search for "ScienceLogic" and locate the application in the navigation menu in the left pane.
You might need to log out of ServiceNow and log in again to see the updated left-hand navigation menu.
