Introduction to the ThousandEyes Integration SyncPack
This section describes how you can use the "ThousandEyes Integration" SyncPack to automatically trigger SL1 events from ThousandEyes alerts. The integration is asynchronous, from ThousandEyes to SL1.
Source IP Destination Source Port Destination Port Requirement
ThousandEyes PowerFlow API Any TCP 443 PowerFlow API Access
PowerFlow SL1 Database Any TCP 7706 SL1 Database Access
Contents of the SyncPack
This section lists the contents of the "ThousandEyes Integration" SyncPack.
PowerFlow Applications
  • ThousandEyes: Process Alert. This application processes ThousandEyes alert data and creates an SL1 event.
For more information about how to configure these applications, see Configuring the ThousandEyes Application.
Configuration Object
  • ThousandEyes Base Config. This configuration object can be used as a template after the SyncPack is installed on the PowerFlow system. The configuration object includes the following:
  • Details for connecting to the SL1 database, including the URL, username, and password
  • Details for converting ThousandEyes alerts into SL1 events including event and yname format, device matching, default device, and custom attribute matching
Steps
  • Get Alert Data From ThousandEyes
  • Transform ThousandEyes Alert Data to SL1 Event
  • Trigger ThousandEyes Event Payload
Installing the SyncPack
If you are upgrading to this version of the SyncPack from a previous version, make a note of any settings you made on the Configuration pane of the various integration applications in this SyncPack, as these settings are not retained when you upgrade.
Downloading the SyncPack
  2. Click the Product Downloads tab and select PowerPacks & SyncPacks.
  3. In the Search field, search for the SyncPack and select it from the search results. The Release Version page appears.
Importing the SyncPack
  4. You will need to activate and install the SyncPack in PowerFlow. For more information, see the following topic.
