For this SyncPack, you can make a copy of the "Infoblox Base Config" configuration object, which is the sample configuration file that was installed with the Infoblox: InventorySyncPack.
The "Infoblox Base Config" configuration object contains all of the required variables. Simply update the variables from that object to match your SL1 and Infoblox settings.
To create a configuration object based on the "Infoblox Base Config" configuration object:
Click the
) for the "Infoblox Base Config" configuration object and select Edit. The Configuration pane appears:
button (
. The -
- infoblox_username. Type the username for your Infoblox system.
- infoblox_password. Type the password for your Infoblox system.
- infoblox_url. Type the URL for your Infoblox system.
- organization_id. Type the SL1 organization ID that you want recently discovered Inflobox IP addresses to be added to.
- zone_name. Type the zone you want an SL1 device to be assigned when added to Infoblox.
- aligned_device_template. Type the ID of the SL1 device template that you want recently discovered Infoblox IP addresses to use when added to SL1 using the following format, in which you replace [ID] with the device template ID:
- credentials. Type the credential type and list of SL1 credentials that you want to use using the following format, in which you replace [type] with the credential type and [ID] with the credential ID:
- snmp
- db
- soap
- basic
- ssh
- powershell
- device_groups. Type the ID of the SL1 device group that you want recently discovered Inflobox IP addresses to be added to in SL1 using the following format, in which you replace [ID] with the device group ID:
- aligned_collector. Type the ID of the collector in SL1 that you want recently discovered Inflobox IP addresses to use when added to SL1.
- scan_ports. Type the list of ports that you want recently discovered Inflobox IP addresses to scan when added to SL1.
- infoblox_id. Type the name of the custom attribute you want to use when synchronizing SL1 devices and Infoblox IP addresses.
- time_period. Type the default time configuration in hours to synchronize your Infoblox IP addresses and SL1 devices.
/api/device_tempalte/56
You can find your device template IDs on the Templates page (Devices > Templates).
/api/credential/[type]/[ID]
The credentials field accepts the following credential type values:
You can find your credential IDs on the Credential page (System > Manage > Credentials).
Examples: If the device has an SSH/Key credential with the ID 105, then you would type "/api/credential/ssh/105".
If the devices have a PowerShell and SOAP/XML credentials with the ID 100 and 120, then you would type "/api/credential/powershell/100,/api/credential/soap/120".
/api/device_group/[ID]
You can find your device group IDs on the Device Group page (Devices > Device Groups).
Example: If the device group you want to add Infoblox IP addresses to has the ID 10, then you would type "/api/device_group/10".
With this SyncPack, any IP addresses discovered in Infoblox are added to SL1 and any devices discovered in SL1 are added to Infoblox. Any devices with the same name in SL1 and Infoblox that have different IP addresses will create an event in SL1. You will need to align the Infoblox: Inventory SyncPack applications with the relevant configuration object in PowerFlow, and, if needed, update any other fields on the Configuration pane for the applications.
To run this SyncPack, you must "align" the configuration object to run with the PowerFlow applications included in this SyncPack.
- Wait until you see the "App & Config modifications saved" pop-up message before proceeding.
To schedule an application:
On the Applications page (
When either multiple SL1 instances or multiple Infoblox instances are involved with PowerFlow, you should create an individual configuration object for each SL1 or Infoblox instance. Next, create an individual schedule for each configuration object. Each schedule should use a configuration object that is specific to that single SL1 or Infoblox instance. Creating copies of a PowerFlow application from a SyncPack for the purpose of distinguishing between domains is not supported, and will result in issues on upgrades.
