For this SyncPack, you should make a copy of the "Jira ITSM Configuration" configuration object, which is the sample configuration file that was installed with the Jira Service Management SyncPack.
The "Jira ITSM Configuration" configuration object contains all of the required variables. Simply update the variables from that object to match your SL1 and Jira settings.
To create a configuration object based on the "Jira ITSM Configuration" configuration object:
Click the
) for the "Jira ITSM" configuration object and select Edit. The Configuration pane appears:
button (
. The -
- jira_username. Type the username for your Jira system.
- jira_password. Type the password for your Jira system.
- jira_token. Enter a Jira API token.
- jira_url. Type the URL for your Jira system.
- project_key. Type the project key for the Jira project you want to be used when making the API request.
- populate_external_url. Type whether to add an Jira ticket URL to the corresponding SL1 event. The default value is 'enabled'.
- account_id. Enter the Jira account ID.
- issue_type. Type the type of ticket you want to be created in Jira when an event is triggered in SL1.
- jira_request_type_id. Type the Jira request type ID.
- severity_field_id. Enter the Jira severity field ID.
- event_url_field_id. Enter the SL1 event URL field ID from Jira.
- prirority. Type the Jira incident priority value for incidents created from SL1 events.
- impact. Type the impact value for incidents created from SL1 events.
- severity_def. Toggle the JSON editor to define severity mapping between SL1 and Jira.
- add_template. Toggle the JSON editor to define a message for the description field in Jira.
For more information on creating a Jira API token, see Creating an API token in Jira.
For more information on your Jira account ID, see Locating the Account ID in Jira.
For more information on your Jira request type ID, see Locating the Request Type ID in Jira.
For more information on your severity field ID, see Locating the Severity Custom ID in Jira.
For more information on your Jira Event URL Field, see Configuring an SL1 Event URL Custom Field in Jira.
For more information about the Jira terms and concepts in this section, see the Jira documentation.
Creating an API Token in Jira
For PowerFlowto communicate with Jira, you must create a Jira API token and enter it in your configuration object.
To create an API token in Jira:
- Click on your profile icon and select Account Settings.
- Navigate to the API Tokens page (Security > Create and manage API tokens).
- Click to generate a new API token.
For PowerFlow to make changes to Jira, you must enter a Jira account ID in your configuration object.
To locate your Jira account type ID:
- Click on your profile icon and select Account.
- The page reloads and you can find the account ID at the end of the URL.
For PowerFlow to make changes to Jira, you must enter a Jira request type ID for the type of request you want in your configuration object.
To locate a Jira incident request type ID:
- Select the Jira project you want to use.
- Navigate to the Incidents page (Project Settings > Request Types > Incidents).
- Select the request type (for example, "Report a system problem"). The page reloads and you can find the request type ID at the end of the URL.
For PowerFlow to identify the severity of a Jira issue, you must enter a severity custom ID in your configuration object.
To locate your severity custom ID in Jira:
- Navigate to the Screens page (Project Settings > Screens).
- If you have not already added the Severity field to your issues list, select any of the screens to expand its details and select the Edit issue link. You can then add the Severity issue by selecting Severity in the Select Field drop down at the bottom of the Issuespage.
- On the Screens page, select any of the screens to expand its details and select the Create Issue link.
- Navigate to the Field Configurations page (Fields > Field configurations).
- Select Default Field Configuration.
- Locate the Severity field and click Edit.
- The page reloads and you can find the severity custom ID at the end of the URL.
For PowerFlow to make changes to Jira, you must enter an SL1 event URL field ID in your configuration object.
To configure an SL1 event URL custom field in Jira:
- Select the Jira Service Management: Change Management Screen Scheme screen to expand its details and select the Create Issue link.
- Navigate to the Custom Fields page (Fields > Custom fields).
- Click URL Field. and select
- Supply a value in the required field and click .
- The page reloads and you can find the custom field ID in the URL.
- Repeat these steps for the Jira Service Manage: Incident Management Screen Scheme screen.
With this SyncPack, you can synchronize your SL1 events and Jira issues including creating Jira incidents, updating acknowledgment data, resolving SL1 events and updating SL1 event notes. You will need to align the Jira Service Management SyncPack applications with the relevant configuration object in PowerFlow, and, if needed, update any other fields on the Configuration pane for the applications.
To trigger the applications in the SyncPack, you must schedule the following PowerFlow applications, which are included in the SyncPack:
- "Resolve SL1 Event from Jira"
- "Show Jira Change Log in SL1 Event Notes"
To schedule an application:
On the Applications page (
When either multiple SL1 instances or multiple Jira instances are involved with PowerFlow, you should create an individual configuration object for each SL1 or Jira instance. Next, create an individual schedule for each configuration object. Each schedule should use a configuration object that is specific to that single SL1 or Jira instance. Creating copies of a PowerFlow application from a SyncPack for the purpose of distinguishing between domains is not supported, and will result in issues on upgrades.
