Editing the Microsoft Teams Integration Automation Actions
The Microsoft Teams Integration PowerPack includes seven automation actions that use the "Run Integration Service Application" action type to trigger the PowerFlow applications that send and receive data to and from Microsoft Teams. You can specify the credential ID in a JSON structure that you enter in the Input Parameters field in the Action Policy Editor modal.
To edit the automation actions included in the PowerPack:
- Locate the automation action that you want to use, and then click its wrench icon (
- credential_id. Change the value to the credential ID that you noted earlier when creating a credential for your SL1PowerFlow system. This field is required.
