What is the Microsoft Teams Integration PowerPack?
The Microsoft Teams IntegrationPowerPack includes automation policies and actions that create channels and trigger event updates between SL1 and Microsoft Teams.
Installing the Microsoft Teams Integration PowerPack
IMPORTANT: You must install and configure the Microsoft Teams Synchronization PowerPack version 1.0.0 before using the Microsoft Teams Integration PowerPack.
The Microsoft Teams Integration PowerPack requires SL1 version 11.1.0 or later. For details on upgrading SL1, see the appropriate SL1 Release Notes.
