Configuring Microsoft Teams
To configure Microsoft Teams to work with PowerFlow, you must register an application in Azure Active Directory and perform some configuration steps for that application before using the Microsoft Teams SyncPack. To configure the application:
- Follow the steps in Microsoft's documentation to register your application in Azure Active Directory.
- Note the "app_id(client_id)", "client_secret", and "tenant_id" of your application.
- Grant scoped permissions to the web API, specifically the following:
- Calls.Initiate.All
- Call.InitiateGroupCall.All
- Channel.Create
- ChannelMessage.Send
- Channel.ReadBasic.All
- offline_access
- openid
- User.Read
- User.Read.All
- Follow these steps to authorize a user and retrieve the "refresh_token".
- Create incoming webhooks in Microsoft Teams and ensure the channel privacy setting is "standard" and not "private".
- Note the URL of your webhook(s).
- Create a bot here (only required fields are needed).
- After creating your bot, click My bots from the top menu and select your bot.
- Add Microsoft Teams as a featured channel and enable calling.
- Create an intermediary URL:
- In PowerFlow, navigate to the API Keys page (
- Select and copy the key once it is generated.
- Create the following URL, inserting your PowerFlow IP address and API key where indicated, and paste it in to your PowerFlow configuration:
https://<Your PF IP Address>/api/v1/applications/sync_event_status_from_teams_to_sl1/run?PF-APIKEY=<API Key>
If a refresh token is generated before enabling multi-factor authentication (MFA), the same token will not work once MFA is enabled. In this case you must generate a new refresh token once MFA is enabled and update it in your PowerFlow configuration.
For this SyncPack, you can make a copy of the "Sample Microsoft Teams Config" configuration object, which is the sample configuration file that was installed with the Microsoft Teams SyncPack.
The "Sample Microsoft Teams Config" configuration object contains all of the required variables. Simply update the variables from that object to match your SL1 and Microsoft Teams settings.
To create a configuration object based on the "Sample Microsoft Teams Config" configuration object:
- Click the Configuration pane appears: button for the "Sample Microsoft Teams Config" configuration object. The
. The -
In the Configuration Data Values fields, update the default variable definitions to match your PowerFlow configuration:
- sl1_host. The hostname or IP address of the SL1 system the alerts will synchronize to.
- refresh_token. The refresh token you received in Azure Active Directory.
- client_id. ID of registered app in Azure Active Directory.
- client_secret. Secret code given for the corresponding app in Azure Active Directory.
- tenant_id. Tenant ID of the Azure Active Directory.
- team_id. ID of your team in Microsoft Teams.
- ms_teams_webhook_url. The URL of the webhook you created in Azure Active Directory.
- microsoft_user_ids. Microsoft Teams user ID used for group calling. For a group call, enter multiple user IDs in your PowerFlow configuration separated by commas. For example:
- default_ack_user. The default user to acknowledge events and alerts.
- intermediary_url. URL endpoint of the intermediary between Microsoft Teams and PowerFlow for sending user interaction data.
"encrypted": false,
name":"microsoft_user_ids",
"value": "dce672e6-c430-43f9-b17e-bfe07e51816d,30127c40-12b3-436b-8523-115d3b814ea9"
With this SyncPack, any status changes made to an SL1 event is sent to Microsoft Teams to update the corresponding alert. Any status changes to the Microsoft Teams alert are synced back to the corresponding SL1 event. You will need to align the Microsoft Teams applications with the relevant configuration object in PowerFlow, and, if needed, update any other fields on the Configuration pane for the applications.
- Create Channel For Event
- Created Channel Event Notification MS Teams
- Major Event Notification To MS Teams
- Outage Event Notification
- Sync Event Status From Teams to SL1
The values and other parameters that appear in the Configuration pane with a padlock icon (
- Wait until you see the "App & Config modifications saved" pop-up message before proceeding.
To schedule an application:
On the Applications page (
When either multiple SL1 instance or multiple Microsoft Teams instances are involved with PowerFlow, you should create an individual configuration object for each SL1 or Microsoft Teams instance. Next, create an individual schedule for each configuration object. Each schedule should use a configuration object that is specific to that single SL1 or Microsoft Teams instance. Creating copies of a PowerFlow application from a SyncPack for the purpose of distinguishing between domains is not supported, and will result in issues on upgrades.
