Editing the Opsgenie Automation Action
The Opsgenie Incident Integration PowerPack includes five automation actions that use the "Run Integration Service Application" action type to trigger the PowerFlow application that sends and receives data to Opsgenie. You can specify the credential ID in a JSON structure that you enter in the Input Parameters field in the Action Policy Editor modal.
To edit the automation actions included in the PowerPack:
- Locate the automation action that you want to use by searching for "Opsgenie", and then click its wrench icon (
). The Editing Action page appears:
- credential_id. Change the value to the credential ID that you noted earlier when creating a credential for your SL1PowerFlow system. This field is required.
