Introduction to the Salesforce Service Cloud: Synchronization Policies PowerPack
This section describes how to install the Salesforce Service Cloud: Synchronization Policies PowerPack.
This PowerPack requires a subscription that includes CMDB/Inventory Workflow Automations.
What is the Salesforce Service Cloud: Synchronization Policies PowerPack?
The Salesforce Service Cloud: Synchronization Policies PowerPack includes Run Book Automation and Action policies that can be used to trigger, acknowledge, and resolve Salesforce cases or incidents and SL1 events.
Installing the Salesforce Service Cloud: Synchronization Policies PowerPack
Before completing the steps in this section, you must import and install the latest version of the Salesforce Service Cloud: Synchronization Policies PowerPack.
You must install and configure the Salesforce Service Cloud Synchronization PowerPack version 1.0.0 before using the Salesforce Service Cloud: Synchronization Policies PowerPack.
The Salesforce Service Cloud: Synchronization Policies PowerPack requires SL1 version 10.2.0 or later. For details on upgrading SL1, see the appropriate SL1 Release Notes.
