Prerequisites for Creating a Configuration Object
To integrate Salesforce and SL1, you must create or use an existing application for SL1 to communicate with. When creating or editing the Salesforce application, ensure that OAuth Settings are enabled and add the following OAuth Scopes:
- Access Lightning applications (lightning)
- Access Visualforce applications (visualforce)
- Access content resources (content)
- Manage user data via APIs (api)
- Perform requests at any time (refresh_token, offline_access)
For this SyncPack, you can make a copy of the "Base Salesforce Configuration" configuration object, which is the sample configuration file that was installed with the Salesforce Service Cloud SyncPack.
The "Base Salesforce Configuration" configuration object contains all of the required variables. Simply update the variables from that object to match your SL1 and Salesforce settings.
For more information about the Salesforce terms and concepts in this section, see the Salesforce documentation.
To create a configuration object based on the "Base Salesforce Configuration" configuration object:
Click the
) for the "Base Salesforce Configuration" configuration object and select Edit. The Configuration pane appears:
button (
. The -
- sl1_host. Type the hostname or IP address of your SL1 system.
- salesforce_client_id. Type the consumer key for your Salesforce application.
- salesforce_client_secret. Type the consumer secret for your Salesforce application.
- salesforce_username. Type the username for your Salesforce system.
- salesforce_password. Type the password for your Salesforce system.
- add_template. Toggle the JSON editor to define the template to translate SL1 event information to the subject of the Salesforce case or incident.
- summary_template. Toggle the JSON editor to define the template to translate SL1 event information to the description of the Salesforce case or incident.
- populate_external_url. The option to add a Salesforce case or incident URL to the corresponding SL1 event. The default value is 'enabled'.
- salesforce_instance_url. Type the URL for your Salesforce system.
- default_ack_user. Type the API command for the default user to acknowledge Salesforce cases or incidents.
- resolve_from_sf. The option to allow SL1 events to be resolved if they are resolved in Salesforce. The default value is 'enabled'.
With this SyncPack, any status changes made to an SL1 event is sent to Salesforce to update the corresponding case or incident. Any status changes to the Salesforce case or incident are synchronized back to the corresponding SL1 event. You will need to align the Salesforce applications with the relevant configuration object in PowerFlow, and, if needed, update any other fields on the Configuration pane for the applications.
To run this SyncPack, you must "align" the configuration object to run with the PowerFlow applications included in this SyncPack.
The values for salesforce_client_id and the other parameters that appear in the Configuration pane with a padlock icon (
To schedule an application:
On the Applications page (
When either multiple SL1 instances or multiple Salesforce instances are involved with PowerFlow, you should create an individual configuration object for each SL1 or Salesforce instance. Next, create an individual schedule for each configuration object. Each schedule should use a configuration object that is specific to that single SL1 or Salesforce instance. Creating copies of a PowerFlow application from a SyncPack for the purpose of distinguishing between domains is not supported, and will result in issues on upgrades.
