For this SyncPack, you can make a copy of the "Xmatters Config Template" configuration object, which is the sample configuration file that was installed with the xMattersSyncPack.
The "Xmatters Config Template" configuration object contains all of the required variables. Simply update the variables from that object to match your SL1 and xMatters settings.
To create a configuration object based on the "Xmatters Config Template" configuration object:
Click the
) for the "Xmatters Config Template" configuration object and select Edit. The Configuration pane appears:
button (
. The -
- sl1_host. The hostname or IP address of the SL1 system the alerts will synchronize to.
- xmatters_alert_api_webhook. To send events to xMatters, you must configure a generic webhook workflow in xMatters. Enter the integration URL for that workflow.
- xmatters_instance_url. The URL to use for links to the xMatters user interface. Enter the base URL you navigate to. This URL will be displayed in SL1 and will open your xMatters instance in a browser.
- proxy_host. The hostname or IP address of the HTTP proxy that will be used when making an API request to xMatters.
- xm_user. The username for your xMatters system.
- xm_password. The password for your xMatters system.
- xm_group_id. The xMatters group ID you want to use.
- resolve_from_xm. The option to resolve events from xMatters.
- populate_external_url. The option to add an xMatters incident URL to the corresponding SL1 event.
- default_ack_user. The default user to acknowledge events in SL1.
With this SyncPack, any status changes made to an SL1 event is sent to xMatters to update the corresponding incident. Any status changes to the xMatters incident are synced back to the corresponding SL1 event. You will need to align the xMatters applications with the relevant configuration object in PowerFlow, and, if needed, update any other fields on the Configuration pane for the applications.
- "Bulk Resolve SL1 Events"
- "Get Acknowledged Incidents And Post Data To SL1"
- "Get Oncall Details And Post Oncall List To SL1"
- "Pass Acknowledgment details from SL1 to Xmatters"
- "Pass Resolution to Xmatters from RBA"
- "Save Accounts to Cache"
- "Get Event Details And Post Incident URL to SL1"
- Wait until you see the "App & Confg modifications saved" pop-up message before proceeding.
To trigger some applications in this SyncPack, you must schedule the application. You must schedule the following applications if you want to trigger them:
- "Get Acknowledged Incidents and Post Data to SL1"
- "Save Accounts To Cache"
To schedule an application:
On the Applications page (
When either multiple SL1 instance or multiple xMatters instances are involved with PowerFlow, you should create an individual configuration object for each SL1 or xMatters instance. Next, create an individual schedule for each configuration object. Each schedule should use a configuration object that is specific to that single SL1 or xMatters instance. Creating copies of a PowerFlow application from a SyncPack for the purpose of distinguishing between domains is not supported, and will result in issues on upgrades.
