What is the HTTP Action Type PowerPack?
The HTTP Action Type PowerPack contains an automation action template that can be used to create custom automation actions that perform HTTP requests. The PowerPack also includes action types that are used by the automation action.
Installing the HTTP Action Type PowerPack
