Customizing Dell EMC Unity Actions
This section describes how to customize the automation actions embedded in the Dell EMC Unity Automation PowerPack to create automation actions to meet your organization's specific requirements.
Creating a Custom Action Policy
To create a custom action policy using:
  1. Navigate to the Action Policy Manager page (Registry > Run Book > Actions).
  2. In the Action Policy Manager page, click the Create button.
  3. The Action Policy Editor modal appears.
  1. In the Action Policy Editor page, supply a value in each field.
  • Action Type. Type of action that will be executed. The Dell EMC Unity Automation PowerPack uses the HTTP Action Type.
  • Input Parameters. A JSON structure that specifies each input parameter. Each parameter definition includes its name, data type, and whether the input is optional or required.
Input parameters must be defined as a JSON structure, even if only one parameter is defined.
  1. Click [Save]. If you are modifying an existing action policy, click Save As. Supply a new value in the Action Name field, and save the current action policy, including any edits, as a new policy.
Customizing Automation Actions
The Dell EMC Unity Automation PowerPack includes two automation actions that request diagnostic information or remediate an issue. You can specify the host and the options in a JSON structure that you enter in the Input Parameters field in the Action Policy Editor modal.
The following automation actions that use the "Make an HTTP Request" action type are included in the Dell EMC Unity Automation PowerPack. Compare the commands run with the example in the image above. For more information about input parameter fields, see the table in Creating a New Dell EMC Unity Automation Action.
Action Name Description Relative URL
Dell EMC Unity LUN Info Collection
Collects information about the Dell EMC Unity LUN associated with the event
"instances/lun/name:%X?fields=id,health,name,type,
tieringPolicy,defaultNode,currentNode,sizeTotal,
sizeAllocated,sizeAllocated,dataReductionSizeSaved,
dataReductionPercent,dataReductionRatio,perTierSizeUsed,
isDataReductionEnabled,storageResource,pool,
isReplicationDestination,snapSchedule,isSnapSchedulePaused,
ioLimitPolicy,metadataSize,metadataSizeAllocated,
snapsSize,snapsSizeAllocated,hostAccess,snapCount,
isThinEnabled,wwn"
Dell EMC Unity Storage Pool Info Collection
"instances/pool/name:%X?fields=id,health,name,
description,raidType,sizeFree,sizeTotal,sizeUsed,
dataReductionSizeSaved,dataReductionPercent,
dataReductionRatio,sizeSubscribed,tiers,creationTime,
isEmpty,isHarvestEnabled,harvestState,
isSnapHarvestEnabled,metadataSizeSubscribed,
nonBaseSizeSubscribed,metadataSizeUsed,snapSizeUsed,
nonBaseSizeUsed,type,isAllFlash"
For more information about substitution variables, see Appendix A.
You can create a new automation action or use the existing automation actions in the PowerPack as a template by using the [Save As] option.
The automation actions accept the following parameters in JSON:
credential_id integer
The ID of a SOAP/XML credential to use to make the HTTP request. The URL, method, authentication parameters, headers, timeout, and proxy settings from the credential are used to build the request. If the credential_id parameter is 0, the dynapp_guid parameter is used to determine the credential to use.
dynapp_guid string If the credential_id parameter is 0, the SOAP/XML credential used to make the HTTP request is the credential aligned to the Dynamic Application with this GUID on the triggering device. If this Dynamic Application is not aligned to the triggering device, the credential aligned to the Dynamic Application with this GUID on the root device of the triggering device is used.
relative_url string This string is appended to the end of the URL in the credential before making the request. Substitution characters can be used in this parameter.
payload string If the credential specifies a POST request, this parameter is sent in the body of the request. Substitution characters can be used in this parameter.
