Configuring Device Credentials
This section describes how to configure the credentials required by the automation actions in the Microsoft Automations PowerPacks.
Creating a Credential
If you are creating a credential for the Windows PowerShell Automations PowerPack and do not have the Microsoft: Windows Server PowerPack installed, you must create a credential that includes the username and password to communicate with your Windows devices.
To prepare your Windows systems for monitoring, follow the instructions in Configuring Windows Servers for Monitoring with PowerShell.
If you have the Microsoft: Windows Server PowerPack installed and configured, you may skip this section.
To define a PowerShell credential in SL1:
  • You can include the variable %D in this field. SL1 will replace the variable with the IP address of the device that is currently using the credential.
  • You can include the variable %N in this field. SL1 will replace the variable with the hostname of the device that is currently using the credential. If SL1 cannot determine the hostname, SL1 will replace the variable with the primary, management IP address for the current device.
  • You can include the prefix HOST or WSMAN before the variable %D in this field if the device you want to monitor uses a service principal name (for example, "HOST://%D" or "WSMAN://%D"). SL1 will use the WinRM service HOST or WSMan instead of HTTP and replace the variable with the IP address of the device that is currently using the credential.
  • Encrypted. Select whether SL1 will communicate with the device using an encrypted connection. Choices are:
  • yes. When communicating with the Windows server, SL1 will use a local user account with authentication of type "Basic Auth". You must then use HTTPS and can use a Microsoft Certificate or a self-signed certificate.
  • no. When communicating with the Windows server, SL1 will not encrypt the connection.
  • Timeout (ms). Type the time, in milliseconds, after which SL1 will stop trying to collect data from the authenticating server. For collection to be successful, SL1 must connect to the authenticating server, execute the PowerShell command, and receive a response within the amount of time specified in this field.
For more information about configuring credentials in SL1, see Credentials.
