Overview
Distributed Replicated Block Device (DRBD) is a distributed replicated storage system for Linux. It is generally used in high availability computer clusters as a kernel driver and to manage applications.
Although DRBD plays a major role in SL1 application clustering, the cluster manager that is responsible for loading, connecting, promoting, and demoting DRBD cannot automatically resolve any issues that might occur at the DRBD application level.
There are few scenarios in which DRBD might fail to connect:
- Split-brain has occurred.
- Unrelated data aborting occurred and the nodes do not recognize each other due to data divergence.
- Firewall issues occurred.
- Proxy service issues occurred (WFReportParams).
- An unstable or bad network was provided.
- Inconsistent kernel packages are created.
What is a Split-brain Configuration?
In SL1, DRBD resides on the Primary node regardless of whether the architecture is HA, DR, or HA and DR. The Primary node is replicated to the secondary node. You might have two or three nodes in the SL1 cluster, but only one can be the primary DRBD at a time. A split-brain configuration occurs when two nodes of a cluster both think they are elected to be the primary and start competing for shared resources. When a split-brain configuration occurs, both nodes will disconnect.
Resolving a Split-brain Configuration on a Disaster Recovery Stack with Two Appliances
To resolve a split-brain configuration between two nodes on a Disaster Recovery stack:
- Check the status of both appliances. To do this:
- Log in to the console of the current Primary appliance as the em7admin user and enter the following at the shell prompt:
drbdadmin status
- If your output looks like this, you have a split-brain configuration:
r0 role:Primary
disk:UpToDate
There is no peer section listed in the status output. This means the node is in Stand Alone mode and not attempting to reconnect.
- On the Disaster Recovery node, enter the following code:
drbdadmin status
You could have several outputs returned.
If your output looks like this, you have a split-brain configuration that indicates the system is split and believes it is in Primary and Stand Alone mode:
r0 role:Primary
disk:UpToDate
If your output looks like this, you have a split-brain configuration that indicates the system is split and believes it is in Primary and attempting to connect to the peer:
r0 role:Primary
disk:UpToDate
peer connection:Connecting
If your output looks like this, you have a split-brain configuration that indicates the system is split and believes it is Secondary and is in Stand Alone mode:
r0 role:Secondary
disk:UpToDate
If your output looks like this, you have a split-brain configuration that indicates the system is split and believes it is Secondary and is attempting to connect to the peer:
r0 role:Secondary
disk:UpToDate
In a safe failover/failback scenario, your output would include:
Primary:
r0 role:Primary
disk:UpToDate
peer role:Secondary
replication:Established peer-disk:UpToDate
Secondary:
r0 role:Secondary
disk:UpToDate
peer role:Primary
When using Oracle Linux 8 the output appears:
Primary:
r0 role:Primary
disk:UpToDate
db2 role:Secondary
peer-disk:UpToDate
Secondary:
r0 role:Secondary
disk:UpToDate
db1 role:Primary
peer-disk:UpToDate
- Resolve split-brain on the passive node.
- If the passive node is attempting to connect to its peer, enter the following command:
sudo drbdadm disconnect r0
- If the passive node has marked itself the Primary, enter the following command:
sudo crm_mon-1
- If you see the line Resource Group: g_em7, enter the following command to demote the system:
crm_resource --resource ms_drbd_r0--set-parameter target-role --meta --parameter-value Slave
SL1 recommends periodically checking for the output of drbdadm
status as the system transitions to secondary status while you wait for your system to demote itself.
- If your system is already Secondary, or has transitioned to Secondary, enter the following command:
sudo drbdadm -- --discard-my-data
connect r0
- Next, on the Primary node, enter the following command:
sudo drbdadm connect r0
- Validate that your split-brain issue has been resolved and is reconnected.
- To check the status on both the Primary node and Secondary note, enter the following command:
drbdadm status
Depending on your network, it can take several minutes to establish the connection and restart replication.
If the output of the status returns connecting, DRBD is attempting to establish the connection. When you see the peer line, connection is established and replication has resumed.
However, if the connecting line disappears and no peer line appears, you have failed to resolve the split-brain situation. Please contact ScienceLogic Support for further assistance.
You must always perform your resolution on the passive node first.
Resolving a Split-brain Configuration on a High Availability Stack with Two Appliances
To resolve a split-brain configuration between two nodes on a High Availability Primary or Secondary stack:
drbdadmin status
r0 role:Primary
disk:UpToDate
drbdadmin status
r0 role:Primary
disk:UpToDate
r0 role:Primary
disk:UpToDate
r0 role:Secondary
disk:UpToDate
r0 role:Secondary
disk:UpToDate
Primary:
r0 role:Primary
disk:UpToDate
peer role:Secondary
Secondary:
r0 role:Secondary
disk:UpToDate
peer role:Primary
Primary:
r0 role:Primary
disk:UpToDate
db2 role:Secondary
peer-disk:UpToDate
Secondary:
r0 role:Secondary
disk:UpToDate
db1 role:Primary
peer-disk:UpToDate
- If the passive node has marked itself the Primary (i.e. both nodes are claiming Primary) this indicates an issue with the High Availability cluster not being able to establish cluster connectivity and/or not being able to control resources correctly. Please stop the process and contact ScienceLogic Support for assistance.
connect r0
drbdadm status
Resolving a Split-brain Configuration on a High Availability and Disaster Recovery Stack with Three Appliances
There are two scenarios you might encounter when working on a high availability and disaster recovery stack involving three appliances. Refer to the steps below for your specifications.
Resolving a Split-brain Between the Primary High Availability and Secondary High Availability Nodes
To resolve a split-brain configuration between three nodes on a High Availability Primary or Secondary stack:
- Check the status of all appliances. To do this:
drbdadm status
- On an OL7 system, your output will be similar to:
r0-L role:Primary
disk:UpToDate
The output for OL7 might contain a peer line listing various state information. When the nodes are disconnected, your output will either look similar to the example above or will indicate peer:Connecting.
- On an OL8 system, your output will be similar to:
r0 role:Primary
disk:UpToDate
db2 connection:StandAlone
db3 connection:Secondary
peer-disk:UpToDate
- On the High Availability (secondary) node enter the following code:
drbdadm status
Stacked resources are no longer used in OL8. Instead, all nodes are direct peers and you have to associate the name to the correct nodes role. In the example above, the db2 is the high availability secondary.
r0-L role:Secondary
disk:UpToDate
r0 role:Secondary
disk:Outdated
db1 connection:Connecting
db3 connection:StandAlone
Stacked resources are no longer used in OL8. Instead, all nodes are direct peers and you have to associate the name to the correct nodes role. In the example above, the db1 is the high availability primary and is outdated compared to the other nodes.
- Resolve split-brain on the passive node on OL7 systems.
- On the High Availability (secondary) node, enter the following command:
drbdadm -- --discard-my-data connect r0-L
- Next, on the High Availability Primary node, enter the following command:
drbdadm connect r0-L
Resolve split-brain on the passive node on OL8 systems.
On the High Availability Secondary node enter the following command:
drbdadm connect r0 --discard-my-data
On the High Availability Primary node enter the following command:
drbdadmin connect r0
Ensure there are no existing connections to the Disaster Recovery node as errors might appear in the output because the connections have already been made. Check the status with drbdadm status to make sure the nodes connect.
Resolving a Split-brain Between the Primary High Availability and the Disaster Recovery Nodes
To resolve a split-brain configuration between three nodes on a High Availability (primary) and Disaster Recovery stack:
- On OL7
drbdadm --stacked
- On OL8
r0-L role:Primary
disk:UpToDate
The output for OL7 might contain a peer line listing various state information. When the nodes are disconnected, your output will look similar to the example above indicating replication is not established.
r0 role:Primary
disk:UpToDate
db2 role:SEcondary
peer-disk:UpToDate
- On the Disaster Recovery node enter the following code:
drbdadm status
drbdadm status
In the example above, the db3 system is the Disaster Recovery node and the connection is StandAlone. Regardless of the db3 connection state it is important to note that it is not connected and will not list a peer-disk status.
1: cs:StandAlone ro:Secondary/Unknown ds:UpToDate/DUnknown r-----
ns:0 nr:0 dw:0 dr:0 al:0 bm:0 lo:0 pe:0 ua:0 ap:0 ep:1 wo:d oos:0
In a safe failback scenario, your output would include ro:Primary/Secondary ds:UpToDate/UptoDate. Also, the kernel logs will include a message indicating that split-brain is detected but unresolved.
- On the Disaster Recovery node, enter the following command:
drbdadm connect --stacked r0
drbdsetup connect r0 2
Diverged Data
Overview
In some situations, DRBD nodes will not connect. When you inspect your logs, you might find the following error message:
2020-07-14T00:01:54.831938+00:00 sl1db02 kernel: [15919.112878] block drbd1: Unrelated data, aborting!
Resolving a Diverged Data Issue
DRBD will not connect if data has diverged beyond the point that the peers no longer recognize each other's generation identifiers. To resolve a diverged data issue:
- Stop the DRBD completely on the secondary (passive) node and delete the metadata:
drbdadm down r0
drbdadm wipe-md r0
- Recreate the DRBD metadata and restart the DRBD:
drbdadm create-md r0
drbdadm up r0
- Check to you see if the notes are connected and synchronizing by running the following command:
drbdadm status
Firewall Issues
Overview
DRBD uses TCP port 7788 for communication between Database Servers. The port must be open in both directions to allow DRBD connection and replication.
Resolving Firewall Issues
To verify there are no port issues and that data can flow bidirectionally:
firewall-cmd --list-all | grep 7788
- If your output looks like this, you have establish connections:
tcp 0 0 10.64.70.42:54787 10.64.70.24:7788 ESTABLISHED 7181/drbd-proxy
tcp 0 0 169.254.1.6:56207 169.254.1.5:7788 ESTABLISHED -
tcp 0 0 10.64.70.42:7788 10.64.70.24:54728 ESTABLISHED 7181/drbd-proxy
tcp 0 0 169.254.1.6:7788 169.254.1.5:53315 ESTABLISHED
- If your output looks like this, you have established connections:
tcp 0 0 10.64.70.24:7788 10.64.70.42:54787 ESTABLISHED 1397/drbd-proxy
tcp 0 0 10.64.70.24:54728 10.64.70.42:7788 ESTABLISHED 1397/drbd-proxy
Ahead-Behind or Disconnect/Reconnect Issues
Overview
These conditions are always caused by a network issue between the Primary node and the Disaster Recovery node. There are several reasons why you might experience network issues, ranging from very simple to very complex, but the root cause is always an insufficiency in data transit. The most common reasons are:
- insufficient bandwidth for the data
- latency plus insufficient bandwidth
- network congestion and queue drops
- packet loss
Resolving Self-Monitoring Network Issues
ScienceLogic has many tools that illustrate some of the insufficient network issues you might face. Viewing the self-monitoring graphs can help you narrow the reason for your network issues.
- DRBD Status Performance| Disk Write. This graph shows the amount of data DRBD is writing to the disk.
- DRBD Status Performance |Network Send. This graph shows the amount of data DRBD has sent across the network from DRBD to the "next hop." This graph should be identical to the Disk Write graph. If not, it means that DRBD cannot send data as fast as it can write it.
- DRBD Status Performance| Disk Write vs. Network Send. This graph is a presentation of the Disk Write and Network Send collectors in comparison to each other. This graph should be relatively flat if everything is operating normally on the network.
Another solution to these network issues is to enable compression on the DRBD proxy. For more information about enabling compression on the DRBD proxy, see the following Knowledge Base article: Using Compression with DRBD.
Other causes of network issues might require more in-depth intervention due to limitations beyond your control. The following suggestions are actions you can implement to help your situation:
- If the bandwidth to the Disaster Recovery node is shared, implement quality of service (QoS) on the network and ensure the DRBD traffic is placed in a low latency, no-drop queue.
- Monitor all network interfaces for all links between SL1 nodes and then enable packet, error, and discard collections on those interfaces. You will be able to see if there are drops or errors, or if it is overrunning the packet switching ability of a switch or router.
- Check for retransmissions on the SL1 system with netstat -s. If you see a high number of retransmits compared to the total number of sent packets, your network is having a problem. In this case, "high" is 0.2% or greater.
In some cases, when the steps above do not resolve your network issue, you might need to escalate the issue to ScienceLogic Support. Before contacting Support, you should collect the following data:
- Screenshots of all three of the DRBD Status Performance graphs referenced above. You should convert the time window when issues are found.
- The output of netstat -s and ifconfig on both the Primary and the Disaster Recovery nodes.
- Capture the output of each of these commands after running on the Database Server:
- Basic ping: ping -w 60 <Dr IP>
- Large packet ping: ping -w 60 -M do -s 1472 <dr IP>
- Rapid ping: ping -w 60 -f <dr IP>
- Large packet rapid ping: ping -w 60 -s 1472 -f <dr IP>
Do not control -C these commands, because they will expire after 60 seconds.
Other Issues
WFReportParams Loops
In the event the DRBD fails to reconnect during the process of a failover to Disaster Recovery, the DRBD will stall and you will see the symptoms of a "WFReportParams" loop error message.
To reconnect the DRBD on the High Availability node, enter the following command:
drbdadm proxy-down r0 && drbdadm proxy-up r0
To reconnect the DRBD on a stacked High Availability node, enter the following command:
drbdadm proxy-down r0 -S && drbdadm proxy-up r0 -S
To reconnect the DRBD on the Disaster Recovery node, enter the following command:
If you need assistance, contact ScienceLogic Support.
Network Issues
As with any network-dependent application, the DRBD proxy requires a stable network. If the network has issues such as flapping link or fluctuating bandwidth capacity, it affects DRBD data replication. Make sure network issues are properly diagnosed and addressed.
Kernel Package Issues
Although rare, two DRBD nodes might fail to communicate due to incompatible DRBD modules. This could sometimes result from one node that was not rebooted after a kernel package update, which will only take effect after a reboot.
