The following sections provide an overview of Cisco: CloudCenter and the Cisco: CloudCenter PowerPack:
What is Cisco CloudCenter?
Cisco CloudCenter is a cloud-management platform used for deploying and managing applications in data centers, private clouds, and public clouds.
What Does the Cisco: CloudCenter PowerPack Monitor?
The Cisco: CloudCenter PowerPack enables you to discover and collect configuration and performance data about standard or high-availability CloudCenter deployments and their components. The Cisco: CloudCenter PowerPack can monitor CloudCenter Manager version 4.7 and later.
The Cisco: CloudCenter PowerPack includes:
- Sample Credentials you can use as templates to create your own Credentials to monitor CloudCenter deployments
- Dynamic Applications and Run Book Actions to discover, model, and monitor performance metrics and/or collect configuration data for the following CloudCenter components:
- CloudCenter Clusters
- CloudCenter Manager
- CloudCenter Load Balancers
- CloudCenter Postgres Databases
- CloudCenter Heath Monitor
- CloudCenter Tenants
- CloudCenter Application Instances
- CloudCenter Clouds
- CloudCenter Regions
- CloudCenter Orchestrator
- CloudCenter ELK components
- RabbitMQ Servers
- RabbitMQ Load Balancers
- Device Classes for each of the CloudCenter components that SL1 monitors
- Event Policies and corresponding alerts that are triggered when CloudCenter components meet certain status criteria
Installing the Cisco: CloudCenter PowerPack
