Configuration and Credentials
The following sections describe how to configure Cisco Unified Contact Center Enterprise services for monitoring by SL1 using the Cisco: Contact Center Enterprise PowerPack:
Configuring Unified Contact Center Enterprise Monitoring Using SNMP
Before you can discover and monitor Cisco Unified Contact Center Enterprise (UCCE) devices in SL1, you must first configure SNMP community strings in each of the UCCE services that you will monitor with SL1.
Enabling SNMP in Cisco Unified Contact Center Enterprise
To enable SNMP in Cisco Unified Contact Center Enterprise, perform the following steps:
  1. Log in to the Cisco Unified Contact Center Enterprise Server as an administrator.
  1. Open Microsoft Management Console (32-bit).
  1. Click File, then select Add/Remove Snap-In. The Add or Remove Snap-ins page appears.
  1. In the Available snap-ins field, select Cisco SNMP Agent Management, then click Add > to move it to the Selected snap-ins field.
  2. Click OK.
  1. In the left panel of the Microsoft Management Console, click Cisco SNMP Agent Management. Then, in the right panel, right-click Community Names (SNMP v1, v2c) and select Properties.
  1. In the Community Names (SNMP v1/v2c) Properties modal page, click the Add New Community button to enable the fields on the page.
  1. Make entries in the following fields:
  • Community Name. Enter a name for the new community string.
  • SNMP Version. Select SNMP v2c.
  • Access Rights. Select Read Only.
  1. Click Save, and then click OK.
  2. Close the Microsoft Management Console.
  3. Open the Microsoft Windows Services console.
  1. In the Microsoft Windows Services console, select Cisco Contact Center SNMP Management from the list of local services, then click the Restart hyperlink to restart the service.
  1. Close the Microsoft Windows Services console.
  2. Click the Windows Start menu, then go to Control Panel > System and Security > Windows Firewall.
  3. In the left panel, click the Turn Windows Firewall on or off hyperlink. The Customize Settings page appears.
  4. Under Domain network location settings, select Turn off Windows Firewall, then click OK.
  5. To enable SNMP in Cisco Unified Contact Center Enterprise Data Server, log in to Cisco Unified Contact Center Enterprise Data Server as an administrator and repeat steps 2-16.
Enabling SNMP in Cisco Unified Customer Voice Portal (CVP)
To enable SNMP in Cisco Unified Customer Voice Portal, perform the following steps:
  1. Log in to Cisco Unified Customer Voice Portal as an administrator.
  1. Click the SNMP tab, then select V1/V2c > Community String.
  1. On the Find, Add, Delete, Edit V1/V2c Community Strings page, click the Add New button.
  1. The V1/V2c SNMP Community String Configuration page appears. Make entries in the following fields:
  • Community String Name. Enter a name for the new community string.
  • SNMP Version Information. Select V2C.
  • For the other fields on the page, use the default values.
  1. Click the Devices tab.
  1. Select one or more of the devices in the Available field, then click the right-arrow icon to move the selected device(s) to the Selected field.
  2. Click the Save & Deploy button. A message confirms that the configuration of the SNMP community string was successfully applied to the selected device(s).
Enabling SNMP in Cisco Unified Intelligence Center (CUIC)
To enable SNMP in Cisco Unified Intelligence Center, perform the following steps:
  1. Log in to Cisco Unified Intelligence Center as an administrator.
  1. In the left panel, click Network Management, then select SNMP.
  1. On the SNMP Community String Configuration page, under Search Options, click Find. The Search Results section appears.
  1. Under Search Results, click Add New.
  • Access Privileges. Select ReadOnly.
  1. Click OK to restart the SNMP master agent.
Enabling SNMP in Cisco Finesse Server
To enable SNMP in Cisco Finesse Server, perform the following steps:
  1. Log in to Cisco Unified Operating System Administration as an administrator.
  1. In the top-right corner of the page, in the Navigation field, select Cisco Unified Serviceability and then click Go.
You might be required to enter your login credentials again before proceeding.
  1. Click the SNMP tab, then select V1/V2cCommunity String.
Creating an SNMP Credential for Unified Contact Center Enterprise
To configure SL1 to monitor Cisco Unified Contact Center Enterprise (UCCE), you must create an SNMP credential. This credential allows the Dynamic Applications in the Cisco: Contact Center Enterprise PowerPack to communicate with your UCCE account.
To configure an SNMP credential for UCCE:
  1. Click the Create button.
  1. In the drop-down list that appears, select SNMP Credential. The Credential Editor page appears:
  1. In the Profile Name field, enter a name for the credential.
  2. In the SNMP Version field, select SNMP V2.
  3. In the SNMP Community (Read Only) field, enter the community string for the UCCE services.
  4. Optionally, supply values in the other fields in this page. In most cases, you can use the default values for the other fields.
  5. Click the Save button.
Compiling SNMP MIBs for Unified Contact Center Enterprise
You must manually compile some of the Management Information Base (MIB) files that are required for monitoring Cisco Unified Contact Center Enterprise in SL1. To compile these MIBs, perform the following steps:
  1. Locate the CISCO-CONTACT-CENTER-APPS-MIB and then click its lightning bolt icon ().
  2. Repeat step 2 for the CISCO-CUICAPPS-MIB and the CISCO-CVP-MIB.
The MIB Compiler page displays "Yes" in the Compiled column for the MIBs before these steps are completed. However, you must still compile the MIBs manually using the lightning bolt icon ().
If the message "MIB File Missing" appears when you click the lightning bolt icon (), you must download and import the MIB(s) before compiling them. To do so:
  1. Download the MIB(s) you need:
  2. Click the Import button.
  3. Click the Browse button to locate the downloaded MIB. Select the MIB, and then click the Import button.
  4. Click OK to confirm.
  5. On the MIB Compiler page, locate the imported MIB and click its lightning bolt icon () to compile it.
  6. If you downloaded more than one MIB, repeat steps 2-6 for the additional MIB(s) that need to be imported and compiled.
Configuring Unified Contact Center Enterprise Monitoring Using REST API
Some Dynamic Applications in the Cisco: Contact Center Enterprise PowerPack collect data from Cisco Unified Contact Center Enterprise (UCCE) using the UCCE REST API. The following Dynamic Applications require a Basic/Snippet credential to enable SL1 to communicate with your UCCE account:
  • Cisco: CCE Administration and Data Server Enhanced Performance
  • Cisco: CCE Call Router Enhanced Performance
  • Cisco: CCE Campaign Manager Enhanced Performance
  • Cisco: CCE CTI Gateway Enhanced Performance
  • Cisco: CCE CTI Object Server Enhanced Performance
  • Cisco: CCE Dialer Enhanced Performance
  • Cisco: CCE Enhanced Performance Caching
  • Cisco: CCE ICM Distributor Enhanced Performance
  • Cisco: CCE Logger Enhanced Performance
  • Cisco: CCE PG OPC Enhanced Performance
  • Cisco: CCE PG PIM Enhanced Performance
  • Cisco: CCE PG VRU PIM Enhanced Performance
To use these Dynamic Applications, you will need credentials for a UCCE user with either a local account in the Windows security group "ICMDiagnosticFrameworkUsers" or a domain user in the "CONFIG" domain security group of the UCCE instance.
An example Basic/Snippet credential that you can edit for your own use is included in the Cisco: Contact Center Enterprise PowerPack. To create a Basic/Snippet credential to monitor UCCE:
  1. Locate the Cisco: CCE Credential, then click its wrench icon (). The Edit Basic/Snippet Credential modal page appears.
  • Hostname/IP. Enter "%D".
  • Port. Enter "7890".
  • Timeout. Enter "60000".
  • Username. Enter the username for a user with administrator access to the UCCE system. This user has either a local account in the Windows security group "ICMDiagnosticFrameworkUsers" or a domain user in the "CONFIG" domain security group of the UCCE instance.
  • Password. Enter the password for the UCCE administrator account.
  1. Click the Save As button.
