The following sections describe how to configure and discover Cisco Email Security Appliances for monitoring by SL1 using the Cisco: ESA PowerPack:
Prerequisites for Monitoring Cisco Email Security Appliances
To configure SL1 to monitor Cisco Email Security Appliances using the Cisco: ESA PowerPack, you must first have the following information about the appliance that you want to monitor:
  • The appliance's IP address.
  • The appliance's SNMP community string.
Creating an SNMP Credential for Cisco ESA
To configure SL1 to monitor Cisco Email Security Appliances, you must create an SNMP credential. This credential allows the Dynamic Applications in the Cisco: ESA PowerPack to connect with the Cisco ESA and collect data from it.
To create an SNMP credential:
  1. Click the Actions button, and then select Create SNMP Credential. The Create New SNMP Credential modal page appears:
  • SNMP Version. SNMP version. Choices are SNMP V1, SNMP V2, and SNMP V3. The default value is SNMP V2. This field is required.
  • Port. The port SL1 will use to communicate with the external device or application. The default value is 161. This field is required.
  • Timeout (ms). Time, in milliseconds, after which SL1 will stop trying to communicate with the SNMP device. The default value is 1500. This field is required.
  • Retries. Number of times SL1 will try to authenticate and communicate with the external device. The default value is 1. This field is required.
SNMP V1/V2 Settings
These fields appear if you selected SNMP V1 or SNMP V2 in the SNMP Version field. Otherwise, these fields are grayed out.
  • SNMP Community (Read Only). The SNMP community string (password) required for read-only access of SNMP data on the remote device or application. For SNMP V1 and SNMP V2 credentials, you must supply a community string, either in this field or in the SNMP Community (Read/Write) field.
SNMP V3 Settings
These fields appear if you selected SNMP V3 in the SNMP Version field. Otherwise, these fields are grayed out.
  • Authentication Protocol. Select an authentication algorithm for the credential. Choices are MD5 or SHA. The default value is MD5. This field is required.
  • Privacy Protocol. The privacy service encryption and decryption algorithm. Choices are DES or AES. The default value is DES. This field is required.
Discovering a Cisco Email Security Appliance
To discover the Cisco ESA that you want to monitor:
  1. On the Credentials page, select the SNMP credential you created for ESA.
  • List of IPs/Hostnames. Type the IP address for the ESA device that you want to monitor.
Discovering a Cisco Email Security Appliance in the SL1 Classic User Interface
  1. Click the Create button. The Discovery Session Editor page appears.
  1. On the Discovery Session Editor page, define values in the following fields:
Image of Cisco Meraki Discovery
  • IP Address/Hostname Discovery List. Type the IP address for the ESA device that you want to monitor.
  • SNMP Credentials. Select the SNMP credential you created for ESA.
  2. Click Save, and then close the Discovery Session Editor window.
  4. When the ESA is discovered, click its device icon () to view its Device Properties page.
