Introduction
The following sections provide an overview of Cisco: Viptela devices and the Cisco: Viptela PowerPack:
What is Cisco: Viptela?
Cisco: Viptela provides a cloud-based, software-defined wide area networking (SD-WAN) solution. Cisco: Viptela includes advanced routing, segmentation, and security capabilities for enterprise networks. Cisco: Viptela's cloud-based network management and orchestration technologies help you deploy and manage the latest WAN architectures.
What Does the Cisco: Viptela PowerPack Monitor?
To monitor Cisco: Viptela resources using the ScienceLogic platform, you must install the Cisco: Viptela PowerPack. This PowerPack enables you to discover, model, and collect data about Viptela resources.
The Cisco: Viptela PowerPack includes:
  • Example credentials that you can use as templates to create SOAP/XML credentials to connect to Viptela
  • The "Cisco: Viptela vManage Template" for aligning all dynamic applications to the root component device
  • Dynamic Applications to discover, model, and monitor performance metrics or collect configuration data for the following Cisco: Viptela resources:
  • vManage
  • vSmart Controller
  • vEdge Routers
  • vBond Orchestrator
  • Device Classes for each type of Cisco: Viptela device monitored:
  • ASR1000 Series
  • ISR1000 Series
  • ISR4000 Series
  • vEdge
  • vEdge Cloud
  • vEdge 100
  • vEdge 1000
  • vEdge 5000
  • vEdge 2000
  • vEdge 100-B
  • vEdge 100-M
  • vEdge 100-WM
  • vEdge Container
  • vManage
  • vSmart Controller
  • Event Policies and corresponding alerts that are triggered when Viptela resources meet certain status criteria
  • Dashboards that display information about Cisco: Viptela component devices
Installing the Cisco: Viptela PowerPack
Before completing the steps in this section, you must import and install the latest version of the Cisco: Viptela PowerPack.
