The following sections provide an overview of Dell EMC Unity and the Dell EMC: Unity PowerPack:
What is Dell EMC Unity?
Dell EMC Unity is a unified storage array. The Dell EMC: Unity PowerPack discovers the storage array and collects health, configuration, performance, and capacity information.
What Does the Dell EMC: Unity PowerPack Monitor?
To monitor Dell EMC Unity storage devices with SL1, you must install the Dell EMC: UnityPowerPack. This PowerPack lets you discover, model, and collect data about Unity storage devices using the Unisphere REST API.
The Dell EMC: UnityPowerPack includes:
- Dynamic Applications to discover, model, and monitor performance metrics and collect configuration data for Dell EMC Unity devices
- Device Classes for each type of Unity device monitored
- Event Policies that are triggered when Unity devices meet certain status criteria
- An example credential that you can use as a template to create a SOAP/XML credential to connect to Unity devices
Installing the Dell EMC: UnityPowerPack
