The following sections provide an overview of BIG-IP LTM devices and the F5 BIG-IP PowerPack:
What is F5 BIG-IP LTM?
F5 Networks' BIG-IP Local Traffic Manager (LTM) devices manage local system traffic to ensure optimal network and application performance and increase the system's operational efficiency. BIG-IP LTM solutions include BIG-IP appliances, the VIPRION application delivery controller, and software-based BIG-IP Virtual Editions.
What Does the F5 BIG-IP PowerPack Monitor?
The F5 BIG-IP PowerPack enables you to monitor LTM configuration and performance metrics for virtual servers, pools, and member nodes, as well as other chassis and asset information.
The F5 BIG-IP PowerPack includes the following features:
- Dynamic Applications that discover and monitor F5 BIG-IP LTM devices
- Device Classes for each of the F5 BIG-IP LTM devices that the F5 BIG-IP PowerPack can monitor
- Event Policies and corresponding alerts that are triggered when F5 BIG-IP LTM devices meet certain status criteria
Installing the F5 BIG-IP PowerPack
