The following sections describe how to configure and discover IBM AIX devices for monitoring by SL1 using the IBM: AIX Monitoring PowerPack:
Supported Operating Systems
Versions 7.X of AIX are supported by the PowerPack. Older versions of IBM AIX will work if the commands in this document will work with that version.
Prerequisites
To configure the SL1 system to monitor IBM AIX devices using the IBM: AIX Monitoring PowerPack, you must have the following information about your devices:
  • IP addresses/hostnames of the devices you want to monitor.
  • A service account with the appropriate privileges:
  • Username/Password, OR
  • SSH private keys
  • Port 22 (default SSH port) open from the SL1 Data Collector to the end device. Custom ports are supported if they are specified in the credential.
  • If you are using the "IBM: AIX CPU Utilization (sar)" Dynamic Application, then you need to be a member of the "adm" group. To add the user to "adm", execute the command below with root access:
chuser groups=adm sluser
  • Root privileges if the bootinfo command is needed.
  • If you are upgrading from any previous AIX community PowerPack, you will need to disable all events and alerts from the previous PowerPack before installing and using the IBM: AIX Monitoring PowerPack to ensure that duplicate events do not occur.
Configuring IBM AIX Devices to Collect Data
The following tables list the collection objects included in IBM AIX Dynamic Applications and the AIX commands used by each of those collection objects. You can use these commands to grant or restrict access to certain data types in your IBM AIX user account that you will use to monitor your IBM AIX devices.
Dynamic Application Collection Object(s) AIX Command(s) Used
IBM: AIX Configuration Discovery OS Level oslevel
OS Version oslevel | sed 's/\./ /g' | awk '{ if (NF>=2) print "AIX "$1"."$2; else print "AIX "$1}'
IBM: AIX Disks Active Disk % lspv;iostat -D
Disk Service Queue Full
Failed Read requests per sec
Failed Write requests per sec
Physical Volume Name
IBM: AIX Error Report TimeStamp date +"%a %b %e %H:%M:%S %Z %Y"; errpt -s
IBM: AIX ICDA Cache Filesystem df -kP
Processes ps auxww
uptime uptime
IBM: AIX Inodes Inodes Used Percentage df -i
Mount Directory
IBM: AIX LPAR CPU Configuration Maximum Memory (MB) lparstat -i
Maximum Physical CPUs in system
Maximum Virtual CPUs
Minimum Memory (MB)
Minimum Virtual CPUs
Mode
Node Name
Online Memory
Partition Name
Partition Type
IBM: AIX LPAR CPU Stats Active CPUs in Pool lparstat -i
Active Physical CPUs in system
Entitled Capacity (%entc) lparstat
Entitled Capacity (units) lparstat -i
LPAR Overall CPU Utilization % lparstat
LPAR Type
Maximum Physical CPUs in system lparstat -i
Node Name
IBM: AIX Memory Stats Available Memory svmon -G -O summary=basic,unit=MB
Free Memory
Memory Size
Pinned memory consumption
Real Memory Consumption
Virtual Memory Consumption
Paging (Swap) Space Inuse
Paging (Swap) Space Size
IBM: AIX Network Stats Packet Errors netstat
IBM: AIX Page Space Read Write Page Space Pages Read per Sec vmstat 1 1
Page Space Pages Written per Sec
IBM: AIX Path Status Path Status lspath | uniq
IBM: AIX Processor States Processor Name lsdev -Cc processor
Processor Status lsdev -Cc processor; lsattr -El <processorname>
IBM: AIX System Configuration CPU type prtconf
Default Gateway
Domain Name
Firmware Version
FQDN
Host Name
IP Address
Logical CPU Cores mpstat -s 1 1
Manufacturer prtconf
Name Server
Netmask
OS Level oslevel
OS Version oslevel | sed 's/\./ /g' | awk '{ if (NF>=2) print "AIX V"$1"."$2; else print "AIX V"$1}'
Paging Space (MB) prtconf
Physical Memory (MB)
Physical Processors
Processor Speed (MHz)
Processor Type
Processor Version
Product Name
Serial Number
System Type
Time Zone date
Uptime (days) uptime
IBM: AIX Uptime & Load Average CPU Core Count lsdev -Cc processor
Load Average (15 min) uptime
Load Average (1 min)
Load Average (5 min)
Total Uptime Minutes
IBM: AIX Volumes Free Partition Size lspv
Logical Volume Name lsvg
Logical Volume State
Logical Volume Type
Physical Volume Name lspv
Physical Volume State
Stale Partitions Count
Total Partition Size
Used Partition Size
IBM: AIX Zombie Process Count Zombie Process Count ps -eo "status" | grep -c Z
The following table lists internal collection inventory and internal collection performance Dynamic Applications (ICDA) in the PowerPack:
Dynamic Application Metrics AIX Command(s) Used
IBM: AIX IC Detail uptime uptime
IBM: AIX IC Filesystem Inventory Filesystem df -kP
IBM: AIX IC Filesystem Performance
IBM: AIX IC Process Inventory Processes ps auxww
IBM: AIX IC Process Performance
The following table lists Dynamic Applications that are disabled by default and not included as part of the "IBM: AIX Dynamic Applications Template" device template. These Dynamic Applications can be enabled as needed by manually adding them to your devices or the device template:
IBM: AIX CPU Utilization (mpstat) CPU Utilization % mpstat
IBM: AIX CPU Utilization (sar) CPU Utilization % sar -u 1 3
IBM: AIX Filesystem Filesystem df -kP
IBM: AIX Total Allocated Storage Value (Bootinfo) Total Allocated Storage (GB) lspv; bootinfo -s <disk_name>
The "IBM: AIX ICDA Cache" Dynamic Application is enabled by default for SL1 versions 10.2.2 and above. The Dynamic Application acts as a cache producer for the following Dynamic Applications:
  • IBM: AIX Filesystem
  • IBM: AIX IC Detail
  • IBM: AIX IC Filesystem Inventory
  • IBM: AIX IC FIlesystem Performance
  • IBM: AIX IC Process Inventory
  • IBM: AIX IC Process Performance
For users on SL1 versions prior to 10.2.2, the "IBM: AIX ICDA Cache" Dynamic Application should be disabled and any snippet containing the word "cache" should be disabled as well. When the cache snippets are disabled, all snippets without the word "cache" in them should be enabled.
Creating an SSH/Key Credential for IBM AIX
To configure SL1 to monitor IBM AIX devices using SSH, you must first create an SSH/Key credential. This credential allows the Dynamic Applications in the IBM: AIX Monitoring PowerPack to connect with an IBM AIX device.
  2. Locate the "IBM: AIX Example Credential" and click on it. The Edit Credential modal page appears:
  • Timeout (ms). Time, in milliseconds, after which SL1 will stop trying to communicate with the device from which you want to retrieve data.
  • Hostname/IP. Type the hostname or IP address of the IBM AIX device you want to monitor. Alternatively, you can use the following variables:
  • You can include the variable %D in this field. SL1 will replace the variable with the IP address of the current device (device that is currently using the credential).
  • You can include the variable %N in this field. SL1 will replace the variable with hostname of the current device (device that is currently using the credential). If SL1 cannot determine the hostname, SL1 will replace the variable with the primary, management IP address for the current device.
  • Port. Port number associated with the data you want to retrieve. This field is required.
  • Private Key (PEM Format). Type or paste the SSH private key that you want SL1 to use, in PEM format.
The private key must include the lines "BEGIN RSA PRIVATE KEY" and "END RSA PRIVATE KEY", as well as all preceding and following dashes on those lines.
The Private Key (PEM Format) field is only required in the current SL1 user interface. The Private Key (PEM Format) field is not required if you are using the classic SL1 user interface to define a credential.
The private key can have a maximum of 64 characters per line. Therefore, you cannot use keys in the OpenSSH format, because that format uses 70 characters per line. When you attempt to save the credential, SL1 will validate that the private key entered is in the correct format. You will be able to save the credential only if the private key is correctly formatted.
Creating an SSH/Key Credential for IBM AIX in the SL1 Classic User Interface
To define an SSH/Key credential:
  1. Collect the information you need to create each credential (usually username and password).
  3. In the Credential Management page, located the "IBM: AIX Example Credential" and click its wrench icon (). The Credential Editor appears:
  1. In the Credential Editor, supply values in the following fields:
  • Timeout (ms). Time, in milliseconds, after which SL1 will stop trying to communicate with the authenticating server.
  • Password. Password for an SSH user account on the device to be monitored. (Optional if using a PEM key.)
  1. Click the Save button to save the new SSH/Key credential.
Configuring the AIX Device Template
A device template allows you to save a device configuration and apply it to multiple devices. The Dynamic Applications in the IBM: AIX Monitoring PowerPack do not align automatically. Configuring and applying the "IBM: AIX Dynamic Applications Template" device template when you discover your IBM AIX device will align the appropriate Dynamic Applications.
To configure the IBM AIX device template:
  1. Go to the Configuration Templates page (Devices > Templates or Registry > Devices > Templates in the SL1 classic user interface).
  1. Locate the "IBM: AIX Dynamic Applications Template" and click its wrench icon (). The Device Template Editor page appears.
  • Credentials. Select the SSH/Key credential that you created for IBM AIX.
  1. Click the next Dynamic Application listed in the Subtemplate Selection section on the left side of the page and then select the AIX SSH/Key credential in the Credentials field.
  2. Repeat step 5 until the you have selected the IBM AIX SSH/Key credential in the Credentials field for all of the Dynamic Applications listed in the Subtemplate Selection section.
  3. Click Save As.
 Do not click the Save button, as it will save over the "IBM: AIX Dynamic Applications Template", which you may need for future use.
Preventing IBM AIX Devices from Dynamically Aligning Unwanted Dynamic Applications
As the Dynamic Applications in this PowerPack do not get automatically aligned during discovery, you can choose to disable the "Dynamic Discovery" flag on your IBM AIX device to ensure that other Dynamic Applications do not automatically align to your IBM AIX device and cause increased scale on your SL1 system.
To disable the "Dynamic Discovery" flag from the Device Investigator:
  1. In the Devices page, locate your IBM AIX device and click on it.
  2. In the Device Investigator page, click the Settings tab.
  3. Locate the Dynamic Discovery checkbox and deselect it.
  4. Click the Save button.
To disable "Dynamic Discovery" from the device template:
  1. In the Configuration Templates page (Devices > Templates), locate your IBM AIX device and click on its wrench icon ().
  2. In the Device Template Editor, in the Device Preferences pane of the Config tab, click on Dynamic Discovery to enable the option.
  3. Deselect the Dynamic Discovery checkbox.
Discovering IBM AIX Devices
To create and run a discovery session that will discover IBM AIX devices, perform the following steps:
  1. Click the Unguided Network Discovery Workflow button. Additional information about the requirements for discovery appears in the General Information pane to the right.
  1. Click Select. The Basic Information page appears:
  1. Click Next. The Credential Selection page of the Add Devices wizard appears:
  1. On the Credentials page, locate and select the SSH/Key credential you created.
  • List of IPs/Hostnames. Type the IP addresses for the IBM AIX devices you want to monitor, separated by a comma.
  • Apply Device Template. Select the device template that you created for IBM AIX.
Discovering IBM AIX Component Devices in the SL1 Classic User Interface
  2. Click the Create button to create a new discovery session. The Discovery Session Editor modal page appears:
  • IP Address Discovery List. Type the IP addresses for the IBM AIX devices you want to monitor, separated by a comma.
  • Other Credentials. Select the SSH/Key credential that you created for IBM AIX.
  1. Optionally, you can enter values in the other fields on this page. For more information about the other fields on this page, see the Discovery & Credentials manual.
  2. Click the Save button and then close the Discovery Session Editor modal page.
  4. The Discovery Session window appears. When the IBM AIX device is discovered, click its device icon () to view the Device Properties page for the IBM AIX device.
Enabling More Than Two Thresholds for Filesystem
The "IBM: AIX IC Filesystem Inventory" and "IBM: AIX IC Filesystem Performance" Dynamic Applications provide two thresholds - Major and Critical. If you need more than two thresholds for Filesystem, you will need to disable the IC Filesystem Dynamic Applications and enable the "IBM: AIX Filesystem" Dynamic Application.
To disable the "IBM: AIX IC Filesystem Inventory" and "IBM: AIX IC Filesystem Performance" Dynamic Applications:
  1. Locate your IBM AIX device in the Devices page and click on it.
  2. In the Device Investigator page for the IBM AIX device, go to the Collections tab.
  3. In the Collections tab, click the Edit button.
  4. Locate the "IBM: AIX IC Filesystem Inventory" Dynamic Application, click its Actions icon (), and select Disable Collection.
  5. Click the Save button.
  6. Repeat these steps to disable the "IBM: AIX IC Filesystem Performance" Dynamic Application.
Next, you will need to enable the "IBM: AIX ICDA Cache" and "IBM: AIX Filesystem" Dynamic Applications:
  1. In the Device Investigator page for the IBM AIX device, go to the Collections tab.
  1. In the Collections tab, click the Edit button.
  2. Locate the "IBM: AIX ICDA Cache" Dynamic Application, click its Actions icon (), and select Enable Collection.
  3. Click the Save button.
  4. Repeat these steps to enable the "IBM: AIX Filesystem" Dynamic Application.
Disabling the "IBM: AIX IC Filesystem Inventory" and "IBM: AIX IC Filesystem Performance" Dynamic Applications will result in no filesystem data collection in the Hardware page and hiding the filesystem option will not be available.
Enabling both ICDA and non-ICDA Dynamic Applications will result in duplicate filesystem alerts.
Changing the Collection Commands for CPU Utilization
Some IBM AIX administrators prefer to calculate CPU utilization using the SAR command as opposed to the MPSTAT command. SL1 administrators can chose to use the approach that best fits their use case.
There are two CPU utilization Dynamic Applications in the PowerPack:
  • IBM: AIX CPU Utilization (mpstat)
  • IBM: AIX CPU Utilization (sar)
The "IBM: AIX CPU Utilization (sar)" and "IBM: AIX CPU Utilization (mpstat) Dynamic Applications and their alerts are disabled by default and cannot be aligned using the device template. To enable the "IBM: AIX CPU Utilization (sar)" and "IBM: AIX CPU Utilization (mpstat)" Dynamic Applications:
  1. Ensure that the user has the proper privileges to run the SAR command.
  2. Go to the Dynamic Applications Manager page (System > Manage > Dynamic Applications).
  3. Locate the "IBM: AIX CPU Utilization (sar)"/"IBM: AIX CPU Utilization (mpstat)" Dynamic Application and click its wrench icon ().
  4. In the Operational State dropdown field, select Enabled. Click Save.
  5. Go to the Event Policies page (Events > Event Policies) and enable the following events:
  • IBM: AIX Logical CPU Utilization % has exceeded threshold
  • IBM: AIX Logical CPU Utilization % has returned below threshold
  1. Go to the Alerts tab for both Dynamic Applications and enable their alerts.
  2. The "IBM: AIX CPU Utilization (sar)" and "IBM: AIX CPU Utilization (mpstat)"  Dynamic Applications can now be manually aligned to individual devices.
Updating Virtual Memory Alerts
The "IBM: AIX Memory Stats" Dynamic Application has virtual memory events enabled by default. You must ensure that there are no other previously built custom PowerPacks with virtual memory events running to use these events.
If you are using the AIX Virtual Memory Utilization Monitoring PowerPack, you must disable the alerts and events in that PowerPack or disable the alerts in the "IBM: AIX Memory Stats" Dynamic Application in the IBM: AIX Monitoring PowerPack.
To disable these events:
  1. Go to the Dynamic Applications Manager page (System > Manage > Dynamic Applications) .
  2. Locate the "IBM: AIX Memory Stats" Dynamic Application and click its wrench icon ().
  3. Click the Alerts tab and locate the "IBM: AIX Virtual Memory Utilization Critical" alert and click its wrench icon ().
  4. In the Active State dropdown, select Disabled. Click Save.
  5. Repeat the above steps for the following event policies:
  • IBM: AIX Virtual Memory Utilization Healthy
  • IBM: AIX Virtual Memory Utilization Major
  • IBM: AIX Virtual Memory Utilization not Critical
