The following sections describe how to configure and discover Microsoft SQL Servers for monitoring in SL1 using the Microsoft: SQL Server Enhanced PowerPack:
If you already have Windows Server discovered, you might not need to create a new SQL Server credential or run a separate discovery session for SQL Servers if the PowerShell credential information is the same as that used for the Windows Server credential. In this scenario, you need only to install the Microsoft: SQL Server Enhanced PowerPack and ensure that the Windows user account used in the credential has the appropriate permissions, as outlined in the Prerequisites section.
Prerequisites for Monitoring SQL Servers
To configure the SL1 system to monitor SQL servers using the Microsoft: SQL Server Enhanced PowerPack, you must first have the following information about the SQL Servers that you want to monitor:
  • IP addresses and ports for the SQL Servers
  • Username and password for a Windows user account with access to the SQL Servers
The SQL Servers that you monitor must be running PowerShell version 3.0 or later and need to have the SQL Server PowerShell (SQLPS) module installed. This SQLPS module is installed by SQL Server Management Studio. You can also install the SqlServer PowerShell module found here: https://www.powershellgallery.com/packages/Sqlserver/21.1.18218
The InvokeSqlCmd cmdlet must be present on the server and is available in the SQLPS and SqlServer PowerShell modules mentioned above. To determine if the proper cmdlets are available for this PowerPack to collect, run Get-Command Invoke-SqlCmd to see if the Invoke-SqlCmd cmdlet is installed.
In addition, the Microsoft: SQL Server Enhanced PowerPack requires the following permissions for the user account used for monitoring:
  • SQL 2014 and newer versions require one of the following configurations:
  • The user account has an enabled login on every instance and database to be monitored, with CONNECT SQL, VIEW SERVER STATE, and CONNECT ANY DATABASE permission granted to the login on each instance. The login should have VIEW DATABASE STATE permission and DB_DATAREADER role granted on the 'master' database, and the DB_DATAREADER role granted on the 'msdb' database.
  • The user account has an enabled login on every instance and has the SYSADMIN role.
  • SQL 2012 requires one of the following configurations:
  • The user account has an enabled login on every instance and database to be monitored, with CONNECT SQL and VIEW SERVER STATE granted to the login on each instance. The login should also have VIEW DATABASE STATE permission and the DB_DATAREADER role granted on the 'master' database, and the DB_DATAREADER role granted on the 'msdb' database. In addition, every database in the instance should have CONNECT access granted to the login.
ScienceLogic provides a PowerShell script on that automates the permissions-granting that is required as stated above. The script is included with the Microsoft: Windows Server PowerPack.
  1. When you download the Microsoft: Windows Server PowerPack from the ScienceLogic Support site, a .zip file for the WinRM Configuration Wizard Script(winrm_configuration_wizard.ps1) will be in the folder with the PowerPack's EM7PP file.
  2. Copy the WinRM Configuration Wizard Script .zip file to the Windows server where Microsoft SQL Server is installed and from which you will be collecting data. Unzip the file
  3. Using the credentials for an account that is a member of the Administrator's group, log in to the Windows server you want to monitor. You can log in directly or use Remote Desktop to log in.
  4. Copy the PowerShell script named winrm_configuration_wizard to the Windows server that you want to monitor with SL1.
  5. Right-click on the PowerShell icon and select Run As Administrator.
  6. At the PowerShell prompt, navigate to the directory where you copied the PowerShell script named winrm_configuration_wizard.
  7. At the PowerShell prompt, enter the following to enable execution of the script:
  8. Set-ExecutionPolicy -ExecutionPolicy Unrestricted -Scope Process -Force
NOTE: The execution policy setting persists only during the current PowerShell session.
  1. After the warning text, select Y.
NOTE: If your Windows configuration requires further steps to allow execution of the script, PowerShell will display prompts. Follow the prompts.
  1. To set the required, least-privileged permissions for the user account SL1 will use to monitor all SQL Server instances and databases on the server, run the following script:
.\winrm_configuration_wizard.ps1 -user <domain>\<username> -sql_only
Microsoft SQL Server Database Discovery Prerequisites
To discover SQL databases, users must have grant permissions to connect to the "master" and "ms_db" database, and permissions to create a new login on each SQL instance monitored.
You can use the following script to configure these permissions for monitoring SQL servers:
https://code.eng.sciencelogic.com/projects/TOOL/repos/powershell/browse/winrm_configuration_wizard.ps1
Creating a PowerShell SQL Server Credential
To configure SL1 to monitor SQL Servers, you must first create a PowerShell credential. This credential allows the Dynamic Applications in the Microsoft: SQL Server Enhanced PowerPack to connect with an SQL Server. An example PowerShell credential that you can edit for your own use is included in the PowerPack.
To create a PowerShell credential for an SQL Server:
  2. Locate the SQL PowerShell - Example credential, click its Actions icon () and select Duplicate. A copy of the credential, called SQL PowerShell - Example copy appears.
  3. Click the Actions icon () for the SQL PowerShell - Example copy credential and select Edit. The Edit Credential modal page appears:
  • Name. Type a new name for your SQL Server credential.
  • Timeout (ms). Type "18000".
  • Account Type. Select Active Directory from the dropdown.
  • Encrypted. Toggle this setting off.
  • Username. Type the username for a Windows user with access to the SQL Server.
  • Password. Type the password for the Windows account username.
The user account whose username and password are provided in the credential must have certain permissions in all SQL Server instances that SL1 will monitor. For a list of these permissions, see the Prerequisites section.
  • Hostname/IP. Type "%D".
  • Port. Type "5985".
  • PowerShell Proxy Hostname/IP. Leave this field blank.
  • Active Directory Host/IP. Specify the hostname or IP address of the Active Directory server that will authenticate the credential.
  • Active Directory Domain. Specify the domain where the monitored SQL Server resides.
The PowerShell credential test is not supported by the Microsoft: SQL Server Enhanced PowerPack.
Creating a PowerShell SQL Server Credential in the SL1 Classic User Interface
  1. Locate the SQL PowerShell - Example credential, and then click its wrench icon (). The Edit PowerShell Credential modal page appears.
  • Profile Name. Type a new name for your SQL Server credential.
  • Account Type. Select Active Directory.
  • Timeout. Type "18000".
  • Encrypted. Select no.
  • Active Directory Hostname/IP. Specify the hostname or IP address of the Active Directory server that will authenticate the credential.
  • Domain. Specify the domain where the monitored SQL Server resides.
  1. Click the Save As button.
SQL Cluster Monitoring
For SQL Clusters that only include SQL Instances in an Active/Active configuration, follow the steps in the Discovering SQL Servers section.
For SQL Clusters that include an SQL Instance in an Active/Passive configuration, additional discovery steps are required and listed below.
NOTE: SL1's Active/Passive SQL Instance monitoring leverages the SL1 GUID Component Identifier to allow the SQL Instance component and its child database components to move between SQL Servers during a failover. Adding this GUID Component Identifier on SL1 versions prior to 8.12.1 will create a duplicate SQL Instance component on any already discovered SQL Servers. To prevent this, the GUID Component Identifier is not used by default. The "Enable Active Passive Cluster Failover" threshold in the "Microsoft: SQL Server Cache and Discovery" Dynamic Application provides the option to use the GUID Component Identifier when enabled. A value of "0" in the Threshold Value disables Active/Passive cluster failover; a value of "1" enables it.
Monitoring SQL Clusters on SL1 8.12.1 or greater.
  • Go to the Dynamic Applications Manager page (System > Manage > Applications).
  • Click the wrench icon () for the "Microsoft: SQL Server Cache and Discovery" Dynamic Application to open the Dynamic Applications Properties Editorpage.
  • In the Thresholds tab, click the wrench icon () for the "Enable Active Passive Cluster Failover" threshold and change the Threshold Value to 1.
  • Click Save.
  • Follow the steps in the Discovering SQL Servers section on each Windows Server in the cluster.
Monitoring SQL CLusters on SL1 8.8.1 to 8.12.0
  • In the Properties tab, change the Operational State field to Disabled.
  • Click Save.
  • Go to the Device Components page (Registry > Devices > Device Components).
  • Click the wrench icon () for one of the Windows Servers that make up the SQL Cluster to open its Device Properties page.
  • In the Thresholds tab, under Dynamic App Thresholds | Microsoft: SQL Server Cache and Discovery, change Enable Active Passive Cluster to 1.
  • Repeat steps 7 and 8 for each of the Windows Servers that make up the SQL Cluster.
  • In the Properties tab, change the Operational State field to Enabled.
  • Click Save.
When you discover SQL Servers in SL1, SL1 auto-aligns a series of Dynamic Applications to discover, configure, and monitor the following SQL Server component devices:
  • SQL Servers
  • SQL Server instances
  • SQL Server databases
To discover SQL Servers and their component devices, perform the following steps:
  1. On the Credentials page, locate and select the PowerShell credential you created.
  • List of IPs/Hostnames. Type the IP addresses or the range of IP addresses for the SQL Servers you want to discover.
Discovering SQL Servers in the SL1 Classic User Interface
  • SQL Servers
  1. Click the Create button. The Discovery Session Editor page appears:
  • IP Address/Hostname Discovery List. Type the IP addresses or the range of IP addresses for the SQL Servers you want to discover.
  • Other Credentials. Select the PowerShell credential you created.
  • Discover Non-SNMP. Because the discovery session is not using an SNMP credential, select this checkbox.
  2. Click the Save button.
  3. The Discovery Control Panel page will refresh. Click the lightning bolt icon () for the discovery session you created.
SL1 can automatically build relationships between SQL servers and other associated devices:
  • If you discover Windows server clusters using the Dynamic Applications in the Microsoft: Windows Server Cluster PowerPack version 100 or later, SL1 will automatically create relationships between SQL servers and Windows server clusters.
SQL Cluster Node and SQL Cluster Instance Relationships
When discovering clustered SQL Server instances you will see multiple component device trees that represent the clustered SQL server. In these component device trees, the SQL servers are described as Nodes and the instances described as Roles.
NOTE: Discovering clustered SQL instances is the same process as discovering standalone SQL servers.
The following SQL cluster configurations are supported by the PowerPack. The relationship between the SQL cluster nodes and instances are described for each:
  • Active/Active. The default configuration. After discovery, the roles (instances) will be modeled in both nodes (servers). To determine which instances belong to a specific node, go to the Devices page and click on the node device. Click the Configs tab from the Device Investigator and click "Microsoft: SQL Server Instance Discovery" in the pane on the left. There you will see which roles (instances) belong to the node.
  • Active/Passive. To enable this configuration, you must find the "Microsoft: SQL Server Cache and Discovery" Dynamic Application in the Dynamic Applications Manager page (System > Manage > Dynamic Applications). Click its wrench icon () and then click the Thresholds tab. Click the wrench icon () for the Enable Active Passive Cluster Failover threshold object. In the Override Threshold Value dropdown, select Enabled and then click Save. This configuration is more intuitive, as the roles (instances) will be modeled only under the node (server) that they belong to, and in the event of a failover the instances will move between nodes.
NOTE: If a node has been stopped it won't be discovered.
Viewing SQL Server Component Devices
In addition to the Devices page, you can view the SQL Server and all associated component devices in the following places in the user interface:
  • The Device Components page (Devices > Device Components) displays a list of all root devices and component devices discovered by SL1 in an indented view, so you can easily view the hierarchy and relationships between child devices, parent devices, and root devices. To view the component devices associated with a SQL Server, find the server and click its plus icon (+):
  • The Component Map page (Classic Maps > Device Maps > Components) allows you to view devices by root node and view the relationships between root nodes, parent components, and child components in a map. This page makes it easy to visualize and manage root nodes and their components. SL1 automatically updates the Component Map as new component devices are discovered. The platform also updates each map with the latest status and event information. To view the map for a SQL Server, go to the Component Map page and select the map from the list in the left NavBar. To learn more about the Component Map page, see the section on Maps.
