The following sections provide an overview of VMware NSX and the VMware: NSX PowerPack:
What is VMware NSX?
NSX is VMware's software-defined network virtualization and security platform. NSX enables users to create virtual networks, including firewalls, switches, routers, ports, and other networking components, which are embedded in a hypervisor rather than a physical environment.
What Does the VMware: NSX PowerPack Monitor?
To monitor NSX virtual networks using SL1, you must install the VMware: NSX PowerPack. This PowerPack enables you to discover, model, and collect data about NSX virtual network devices.
The VMware: NSX PowerPack includes:
- An example credential you can use as a template to create Basic/Snippet credentials to connect to the NSX devices you want to monitor
- Dynamic Applications to discover, model, and monitor performance metrics and collect configuration data for NSX devices
- Device Classes for each of the NSX devices SL1 monitors
- Event Policies and corresponding alerts that are triggered when NSX devices meet certain status criteria
- A Run Book Action that automatically classifies the Device Classes for NSX devices
Installing the VMware: NSX PowerPack
