The following sections describe how to configure and discover VOSS Insights appliances for monitoring by SL1 using the VOSS Insights: Appliance Monitoring PowerPack:
Creating a SOAP/XML Credential for VOSS Insights Appliances
To configure SL1 to monitor VOSS Insights appliances, you must first create a SOAP/XML credential. This credential allows the Dynamic Applications in the VOSS Insights: Appliance Monitoring PowerPack to connect with the VOSS Insights appliance.
To configure the SOAP/XML credential:
  2. Locate the VOSS Insights: Appliance Sample credential, click its Actions icon () and select Duplicate. A copy of the credential appears.
  3. Click the Actions icon () for the "VOSS Insights: Appliance Sample copy" credential and select Edit. The Edit Credential page appears:
  • Name. Enter a name for the VOSS Insights credential.
  • URL. Enter the IP address of the VOSS Insights appliance you want to monitor.
  • HTTP Auth User. Enter the username for a user with access to the VOSS Insights appliance.
  • HTTP Auth Password. Enter the password for the VOSS Insights account username.
If you would like to test your credential using the Credential Tester panel, click Save & Test. For detailed instructions on using the Credential Tester panel, see the Testing the VOSS Insights Credential section.
Creating a SOAP/XML Credential for VOSS Insights Appliances in the SL1 Classic User Interface
  2. Locate the VOSS Insights: Appliance Sample credential, then click its wrench icon (). The Edit SOAP/XML Credential modal page appears:
  • Profile Name. Enter a name for the VOSS Insights credential.
  1. Click the Save As button.
SL1 includes a Credential Test for VOSS Insights. Credential Tests define a series of steps that SL1 can execute on demand to validate whether a credential works as expected.
The VOSS Insights Rest Cred Tester can be used to test a SOAP/XML credential for monitoring VOSS Insights using the Dynamic Applications in the VOSS Insights: Appliance Monitoring PowerPack. The "VOSS Insights Rest Cred Tester" performs the following steps:
  • Test Reachability. Checks to see if the VOSS Insights device is reachable using ICMP.
  • Test Port Availability. Checks to see if the appropriate port is open.
  • Test Silo Rest Pack. Attempts to collect data using the REST protocol collector using the given snippet argument.
To test the VOSS Insights credential:
  1. Locate the credential you wish to test, select the Actions button () next to it and click Edit/Test. The Edit Credential modal page appears:
  1. In the Credential Tester pane on the right, supply values in the following fields:
  • Select Credential Test. Select the "VOSS Insights Rest Cred Tester".
  • Select Collector. Select the All-In-One Appliance or Data Collector that will run the test
  • IP or Hostname to test. Enter the IP address or hostname of your VOSS Insights appliance.
  • Step. The name of the step.
  • Status. The result of this step indicates whether the credential or the network environment is configured correctly (Passed) or incorrectly (Failed).
Testing the VOSS Insights Credential in the SL1 Classic User Interface
The VOSS Insights Rest Cred Tester can be used to test a SOAP/XML credential for monitoring VOSS Insights using the Dynamic Applications in the VOSS Insights: Appliance Monitoring PowerPack. The VOSS Insights Rest Cred Tester performs the following steps:
  1. Locate the VOSS Insights Rest Cred Tester and click its lightning bolt icon (). The Credential Tester modal page appears:
Creating the VOSS Insights Virtual Device
To monitor your VOSS Insights appliance, you must create a virtual device that represents that appliance. A virtual device is a user-defined container that represents a device or service that cannot be discovered by SL1. You can use the virtual device to store information gathered by policies or Dynamic Applications.
To create a virtual device that represents your VOSS Insights appliance:
  1. Click Actions and select Create Virtual Device from the menu. The Virtual Device modal page appears.
  • Device Class. Select VOSS Insights | VOSS Insights: Arbitrator or VOSS Insights | VOSS Insights: Reporter depending on the VOSS Insights appliance you are discovering.
Manually Aligning and Verifying Dynamic Application Alignment
After creating the VOSS Insights virtual device, you must manually align the VOSS Insights Dynamic Applications to the VOSS Insights virtual device.
To manually align the VOSS Insights Dynamic Applications:
  1. Go to the Devicespage (Devices > Device Manager).
  1. Locate your VOSS Insights virtual device and click its name.
  3. Click the Edit button at the top of the page, then click the Align Dynamic App button.
  1. In the Align Dynamic Application modal, click Choose Dynamic Application.
Select the following Dynamic Applications to a VOSS Insights Reporter appliance:
Dynamic Application Credential Type
VOSS Insights Reporter: Configuration Snippet Configuration
VOSS Insights Reporter: CPU Snippet Performance
VOSS Insights Reporter: Memory Snippet Performance
VOSS Insights: Service Status Snippet Configuration
REST: Performance Metrics Monitor Snippet Performance
Select the following Dynamic Applications to a VOSS Insights Arbitrator appliance:
VOSS Insights Arbitrator: Configuration Snippet Configuration
VOSS Insights Arbitrator: CPU Snippet Performance
VOSS Insights Arbitrator: Disk Snippet Performance
VOSS Insights Arbitrator: Memory Snippet Performance
VOSS Insights Arbitrator: Processing Rate Snippet Performance
  1. When you have finished selecting Dynamic Applications, click Select.
  2. In the Align Dynamic Application modal, de-select the Use Device SNMP Credential box. Click the Choose Credential option that appears.
  3. Select the VOSS Insights credential you created and click Select.
  1. Click Align Dynamic App to align the Dynamic Application with the VOSS Insights virtual device.
Manually Aligning VOSS Insights Dynamic Applications in the SL1 Classic User Interface
  1. Click the wrench icon () for your VOSS Insights virtual device.
  3. Click the Actions button and select Add Dynamic Application from the menu.
  1. In the Dynamic Application Alignment modal:
  • In the Dynamic Applications field, select a Dynamic Application to align. Depending on the type of VOSS Insights appliance, align Dynamic Applications according to the tables below.
Align the following Dynamic Applications to a VOSS Insights Reporter appliance:
Align the following Dynamic Applications to a VOSS Insights Arbitrator appliance:
  • In the Credentials field, select the credential you created for your appliance.
  1. Click Save to align the Dynamic Application with the VOSS Insights virtual device.
