Ticket source is a description of where the ticket originated. Super Service Provider uses the following types of Ticket Sources:
- Email. Email ticket created by a customer and received by the NOC staff.
- Portal. Ticket created by a customer through the portal.
- Phone. Telephone call from a customer to the NOC staff. The NOC staff creates a ticket and assigns the ticket to an Engineering queue for resolution.
- Event. Event created by an automated management system. The NOC staff creates a ticket and assigns the ticket to an engineering queue for resolution.
- Other. Any ticket opened not as a result of one of the sources list above. For example, a ticket that was opened when an internal employee of Super Service Provider suggests an improvement.
Email and Phone are default values that appear in the Source drop-down list in the Ticket Editor page. The remaining values are not the default values that appear in the Source drop-down list in the Ticket Editor page. However, you can edit the values that appear in the Source drop-down list. This chapter explains how to customize these values.
The Select Objects Editor page allows you to define and edit the entries that appear in drop-down fields in the the user interface.
Deprecating the Default Values for Source
Before you can add new values for the Source drop-down list in the Ticket Editor page, you must deprecate the current default values that Super Service Provider does not plan to use.
To deprecate the default values:
- Go to the Select Objects Editor page (System > Customize > Select Objects).
- On the Select Objects Editor page, use the Filter drop-down list to select Ticketing: Source.
- The Select Objects Registry pane updates with all of the entries for the Source drop-down list.
- Find the entry for Automated and click its wrench icon (
). The Select Objects Editor section at the top updates with the values from Automated. - Select the Deprecate checkbox. When you select this checkbox, Automated no longer appears in the Source drop-down list. In instances of a page where Automated was previously selected, the entry still appears as the selected value for the Source drop-down list. In instances of a page where Automated was not previously selected, it no longer appears in the Source drop-down list.
- Repeat steps 2-6 for the following entries:
- External
- Internal
Creating New Values for Source
On the Select Objects Editor page, you can create the three new entries for the Source drop-down list on the Ticket Editor page.
To create a new entry for the Source drop-down field:
- In the Select Objects Editor page, use the Filter drop-down list to select Ticketing: Source. The Select Objects Registry pane updates with all the entries for the Source drop-down list.
- To add an entry to the selected drop-down list, go to the top pane in the Select Objects Editor page and supply values in the following fields:
- Definition/Value. Type "Portal".
- Access. Select >=Users to allow users of account type "user" and users of account type "administrator" to see this new entry.
- Permission Keys. Do not select any entries.
- Ignore Keys for New Tickets. Do not select this checkbox.
- Deprecate. Do not select this checkbox.
- Click the button to add the new entry. The entry now appears in the Select Objects Registry pane for the selected drop-down list, and the entry also appears in the Source drop-down list on the Ticket Editor page.
- Repeat steps 3-4 for the remaining new entries, using the following values:
Definition/Value |
Access | Permission Keys | Ignore Keys for New Tickets | Deprecate |
| Event | >=Users | Do not select any entries | Do not select this checkbox | Do not select this checkbox |
| Other | >=Users | Do not select any entries | Do not select this checkbox | Do not select this checkbox |
NOTE: If a page in the user interface includes a gray plus sign icon (+) next to a drop-down list, you can create a new entry in the drop-down list directly from that page. To add an entry, click the plus icon and type the text you want to appear in the drop-down list. Click the button on that page to save the entry. The entry is added to the Select Objects Registry page.
