The following workflows describe how to configure SL1 and PowerFlow to work with the "AWS Incident Manager" SyncPack.
Configuring SL1
- Edit the AWS Incident Manager run book actions
- Enable the AWS Incident Manager run book automations
Configuring PowerFlow
- Create and align a PowerFlow configuration object
- Configure the PowerFlow applications
Configuring SL1
The following topics cover how to set up your SL1 instance to work with the "AWS Incident Manager" SyncPack.
You will need to create a SOAP/XML credential in SL1 so that the automation actions included in the PowerPack can access your PowerFlow system.
- Click and select Create SOAP/XML Credential. The Create Credential window appears.
Editing the AWS Incident Manager Run Book Actions
The "AWS Incident Manager Automation" PowerPack includes run book actions that use the "Run Integration Service Application" action type to trigger the PowerFlow applications that trigger, acknowledge, and resolve incidents and events between SL1 and AWS.
To utilize the run book automation policies included in the PowerPack, you must edit the following run book actions to communicate with your PowerFlow system:
- "AWS: Create Timeline Event"
- "AWS: Resolve Incident"
- "AWS: Trigger Incident"
- Go to the Actions page (Registry > Run Book > Actions).
- Locate the AWS run book action that you want to use, and then click its wrench icon (
- credential_id. Change the value to the credential ID that you noted in the previous procedure when creating a credential for your PowerFlow system. This field is required.
Enabling the AWS Incident Manager Run Book Automations
The "AWS Incident Manager" PowerPack includes three run book automation policies that you will need to enable:
- In SL1, go to the Automations page (Registry > Run Book > Automation).
- Locate the "AWS: Create Timeline Event" automation policy and click its wrench icon (
- Available Actions. If it is not already selected, select "Run Integration Service Application: Ansible:Command" (or "Ansible:Tower" for the "Ansible:Tower" automation policy) and click the arrows to move it to Aligned Actions.
- Repeat steps 2-4 for the "AWS: Resolve Incident" and "AWS: Trigger Incident" run book automation policy.
The following topics cover how to set up your PowerFlow instance to work with the "AWS Incident Manager" SyncPack.
For this SyncPack, you can make a copy of the "AWS Incidents Base Config" configuration object, which is the sample configuration file that was installed with the "AWS Incident Manager" SyncPack.
The "AWS Incidents Base Config" configuration object contains all of the required variables. Simply update the variables from that object to match your SL1 and AWS settings.
For more information about the AWS terms and concepts in this section, see the AWS documentation.
To create a configuration object based on the "AWS Incidents Base Config" configuration object:
Click the button (
) for the "AWS Incidents Base Config" configuration object and select Edit. The Configuration pane appears.
- sl1_host. Type the hostname or IP address of the SL1 system the alerts will synchronize to.
- aws_region_name. Type the region of your AWS system.
- aws_access_key_id. Type the access key ID of your AWS system.
- aws_secret_access_key. Type the secret access key ID of your AWS system.
- aws_service. Keep the default value.
- aws_default_response_plan_arn_1. Type the ARN for the default AWS response plan for PowerFlow to use when creating an incident in AWS.
- add_template. Toggle the JSON editor to define the template to translate SL1 event information to an AWS incident.
- summary_template. Toggle the JSON editor to define the summary format to translate an SL1 event to an AWS incident.
- event_response_plan_map. You can configure specific SL1 event criteria to trigger alternative response plans in AWS. To define an alternative response plan, toggle the JSON editor and enter an event property, search key to match to the event, and the ARN for the alternative AWS response plan. For example, if you want to trigger an alternative response plan for an SL1 event that contains "database" in the event message, enter the JSON code as follows:
- resolve_from_aws. When enabled, this parameter resolves SL1 events from AWS incidents. The default value is 'enabled'. To disable this parameter, change this value to 'disabled'.
- populate_external_url. The option to add an AWS incident URL to the corresponding SL1 event. The default value is 'enabled'.
- time_delta. Type the time configuration in days to synchronize your AWS incidents and SL1 events. The "Bulk Resolve SL1 Events from AWS" application will only collect incidents that have been updated within the number of days defined in this parameter.
"event_property": "%M",
"response_plan": "arn:aws:ssm-incidents::XXXXXXXX:response-plan/XXXXXXXXX",
"search_key": "database"
With this SyncPack, any status changes made to an SL1 event are sent to AWS to update the corresponding incident. Any status changes to the AWS incident are synced back to the corresponding SL1 event. You will need to align the AWS Incident Manager applications with the relevant configuration object in PowerFlow, and, if needed, update any other fields on the Configuration pane for the applications.
- "Bulk Resolve SL1 Events From AWS"
- "Create Timeline Event In AWS Incident Manager"
- "Resolve AWS Incident"
- "Send SL1 Event to AWS Incident Manager"
- On the Applications page of the PowerFlow user interface, open one of the PowerFlow applications listed above and click (
). The Configurations pane for that application appears.
The values for sl1_hostname and the other parameters that appear in the Configuration pane with a padlock icon () are populated either by the configuration object you aligned with the application or by the run book action. Do not modify these values. If you encounter an error, make sure your run book action is configured properly.
To trigger the "Bulk Resolve SL1 Events From AWS" application, you must schedule the application so it runs on a regular basis.
To create a schedule:
- On the Applications page (
- Click the down arrow icon (
) and select.
When either multiple SL1 instances or multiple AWS instances are involved with PowerFlow, you should create an individual configuration object for each SL1 or AWS instance. Next, create an individual schedule for each configuration object. Each schedule should use a configuration object that is specific to that single SL1 or AWS instance. Creating copies of a PowerFlow application from a SyncPack for the purpose of distinguishing between domains is not supported, and will result in issues on upgrades.
