The following workflows describe how to configure SL1 and PowerFlow to work with the "CrowdStrike Falcon" SyncPack.
Configuring SL1
- Enable the CrowdStrike event policy
- Edit the CrowdStrike run book action
- Enable the CrowdStrike run book automation
Configuring PowerFlow
- Align the configuration object and configure the PowerFlow applications
Configuring SL1
The following topics cover how to set up your SL1 instance to work with the "CrowdStrike Falcon" SyncPack.
Enabling the CrowdStrike Event Policy
The "CrowdStrike Falcon Automation" PowerPack includes one standard API event policy, "CrowdStrike: Alert to Event", which triggers the events detected by the PowerFlow applications included in the "CrowdStrike Falcon" SyncPack and the associated automation action policy.
To enable the event policy:
- Go to the Event Policies page (Events > Event Policies).
- Click the Actions menu (
) for the "CrowdStrike: Alert to Event" event policy and select Edit. The Event Policy Editor page appears.
- Click the Enable Event Policy toggle to enable the event policy and click .
You must create a SOAP/XML credential so that the action policies included in the PowerPack can access your PowerFlow system. The "CrowdStrike Falcon Automation" PowerPack includes the "PowerFlow CrowdStrike" sample credential that you can edit to use with your SL1 PowerFlow system.
- Locate the "PowerFlow CrowdStrike" sample credential, click its icon (
), and select Duplicate. A copy of the credential, called PowerFlow CrowdStrike copy appears.
- URL. Type the host name for your PowerFlow system.
- HTTP Auth User. Type the administrator username for your PowerFlow
- HTTP Auth Password. Type the administrator password for your PowerFlow system.
- Take note of the SL1-assigned ID number for the new credential on the Credentials page, in the ID column. You will need the ID number when editing the input parameters of the automation actions included in the PowerPack, below.
Editing the CrowdStrike Run Book Action
The "CrowdStrike Falcon Automation" PowerPack includes one action policy that uses the "Run Integration Service Application" action type to trigger the PowerFlow application that collects data from CrowdStrike. You can specify the credential ID in a JSON structure that you enter in the Input Parameters field in the Action Policy Editor modal.
- credential_id. Change the value to the credential ID that you noted earlier whencreating a credential for your PowerFlow system in the previous procedure. This parameter is required.
Enabling the CrowdStrike Run Book Automation
The "CrowdStrike Falcon Automation" PowerPack includes the "Crowdstrike: Clear Detection ID" automation policy that updates the SL1 event with the state of the associated CrowdStrike job. When a node is offline, a failure occurs, or a major event is detected in CrowdStrike, an SL1 event is created and the associated event is updated with any job details.
To enable the run book automation:
- In SL1, go to the Automations page (Registry > Run Book > Automation).
- Locate the "Crowdstrike: Clear Detection ID" automation policy and click its wrench icon (
- Available Actions. If it is not already selected, select "Run Integration Service Application: CrowdStrike: Clear Detection ID" and click the arrows to move it to Aligned Actions.
The following topics cover how to set up your PowerFlow instance to work with the "AWS Incident Manager" SyncPack.
For this SyncPack, you should make a copy of the "CrowdStrike Sample Configuration" configuration object, which is the sample configuration file that was installed with the "CrowdStrike Falcon" SyncPack.
The "CrowdStrike Sample Configuration" configuration object contains all of the required variables. Simply update the variables from that object to match your SL1 and CrowdStrike settings.
To create a configuration object based on the "CrowdStrike Sample Configuration" configuration object:
Click the button (
) for the "CrowdStrike Sample Configuration" configuration object and select Edit. The Configuration pane appears.
- crowdstrike_url. Enter the URL for your CrowdStrike system.
- crowdstrike_username. Type the username for your CrowdStrike system.
- crowdstrike_password. Type the password for your CrowdStrike system.
- job_name. Type the name for your CrowdStrike job.
- receiver_mail. Type the email address that you want to receive updates on SL1 events and your CrowdStrike jobs.
- sender_mail. Type the email address that you want updates on SL1 events and your CrowdStrike jobs to send from.
- sender_mail_password. Type the password for the sender email address that you entered.
- mailserver. Type the server for your sender email.
- mailserverport. Type the port for your sender email.
The following fields are required only if you choose to manually create a virtual device for your CrowdStrike instance:
- device_class_id. Type the device class ID for your CrowdStrike instance.
- collector_group_id. Type the collector group ID for your CrowdStrike instance.
- device_id.Type the device ID for your CrowdStrike instance.
For more information about the CrowdStrike terms and concepts in this section, see the CrowdStrike documentation.
You will need to align the following "CrowdStrike Falcon" SyncPack applications with the configuration object you just created in PowerFlow:
- "Fetch Detections from CrowdStrike and Send Alert to SL1"
- "Clear Detection from Cache"
- On the Applications page of the PowerFlow user interface, open one of the PowerFlow applications listed above and click . The Configurations pane for that application appears.
- Update any other fields on the Configuration pane for the application as needed.
- Repeat this process for the remaining PowerFlow application.
ScienceLogic recommends that you schedule the following PowerFlow applications:
- "Fetch Detections from CrowdStrike and Send Alert to SL1": every 60 seconds
- "Clear Detection from Cache": at least once a week
To create a schedule:
- On the Applications page (
- Click the down arrow icon (
) and select.
When either multiple SL1 instances or multiple CrowdStrike instances are involved with PowerFlow, you should create an individual configuration object for each SL1 or CrowdStrike instance. Next, create an individual schedule for each configuration object. Each schedule should use a configuration object that is specific to that single SL1 or CrowdStrike instance. Creating copies of a PowerFlow application from a SyncPack for the purpose of distinguishing between domains is not supported, and will result in issues on upgrades.
