The following workflows describe how to configure SL1 and PowerFlow to work with the "Infoblox: Inventory" SyncPack.
Configuring SL1
Configuring PowerFlow
- Create and align a PowerFlow configuration object
- Align a configuration object and configure the Infoblox PowerFlow applications
Configuring SL1
The following topic covers how to set up your SL1 instance to work with the "Infoblox: Inventory" SyncPack.
Enabling the Infoblox Event Policy
The "Infoblox: Workflow Configuration" PowerPack includes the "Infoblox: Mismatched IP address" event policy, which check to see if the IP address is mismatched between the device in SL1 and the Infoblox host record. If a mismatch exists, the policy triggers an event in SL1 with the relevant details.
To enable the event policy:
- In SL1, go to the Event Policies page (Events > Event Policies).
- Click the check box for the "Infoblox: Mismatched IP address" event policy. A row of buttons appear at the top of the list.
- Click . The Status for the policy is updated to "Enabled".
For this SyncPack, you can make a copy of the "Infoblox Base Config" configuration object, which is the sample configuration file that was installed with the "Infoblox: Inventory" SyncPack.
The "Infoblox Base Config" configuration object contains all of the required variables. Simply update the variables from that object to match your SL1 and Infoblox settings.
To create a configuration object based on the "Infoblox Base Config" configuration object:
Click the button (
) for the "Infoblox Base Config" configuration object and select Edit. The Configuration pane appears.
- infoblox_username. Type the username for your Infoblox system.
- infoblox_password. Type the password for your Infoblox system.
- infoblox_url. Type the URL for your Infoblox system.
- organization_id. Type the SL1 organization ID that you want recently discovered Inflobox IP addresses to be added to.
- zone_name. Type the zone you want an SL1 device to be assigned when added to Infoblox.
- aligned_device_template. Type the ID of the SL1 device template that you want recently discovered Infoblox IP addresses to use when added to SL1 using the following format, in which you replace [ID] with the device template ID:
/api/device_tempalte/56
You can find your device template IDs on the Templates page (Devices > Templates).
- credentials. Type the credential type and list of SL1 credentials that you want to use using the following format, in which you replace [type] with the credential type and [ID] with the credential ID:
/api/credential/[type]/[ID]
The credentials field accepts the following credential type values:
- snmp
- db
- soap
- basic
- ssh
- powershell
You can find your credential IDs on the Credentials page (Manage > Credentials). For example, If the device has an SSH/Key credential with the ID 105, then you would type "/api/credential/ssh/105".
If the devices have a PowerShell and SOAP/XML credentials with the ID 100 and 120, then you would type "/api/credential/powershell/100,/api/credential/soap/120".
- device_groups. Type the ID of the SL1 device group that you want recently discovered Infoblox IP addresses to be added to in SL1 using the following format, in which you replace [ID] with the device group ID:
- aligned_collector. Type the ID of the collector in SL1 that you want recently discovered Infoblox IP addresses to use when added to SL1.
- scan_ports. Type the list of ports that you want recently discovered Infoblox IP addresses to scan when added to SL1.
- infoblox_id. Type the name of the custom attribute you want to use when synchronizing SL1 devices and Infoblox IP addresses.
- time_period. Type the default time configuration in hours to synchronize your Infoblox IP addresses and SL1 devices.
/api/device_group/[ID]
You can find your device group IDs on the Device Group page (Devices > Device Groups). For example, if the device group you want to add Infoblox IP addresses to has the ID 10, then you would type "/api/device_group/10".
- Click . You can now align this configuration object with one or more PowerFlow applications.
You will need to align the "Infoblox: Inventory" SyncPack applications with the relevant configuration object in PowerFlow, and, if needed, update any other fields on the Configuration pane for the applications:
- "Get Device List From Infoblox and Add To SL1"
- "Get Device List From SL1 Add To Infoblox"
- "Get Mismatched IP List"
- "Update Infoblox Id"
On the Applications page of the PowerFlow user interface, open one of the Infoblox PowerFlow applications and click . The Configurations pane for that application appears.
- Repeat steps 1-4 for the other PowerFlow applications.
To create a schedule:
- On the Applications page (
- Click the down arrow icon (
) and select.
When either multiple SL1 instances or multiple Infoblox instances are involved with PowerFlow, you should create an individual configuration object for each SL1 or Infoblox instance. Next, create an individual schedule for each configuration object. Each schedule should use a configuration object that is specific to that single SL1 or Infoblox instance. Creating copies of a PowerFlow application from a SyncPack for the purpose of distinguishing between domains is not supported, and will result in issues on upgrades.
